Why does conducting liquid moving in a loop produce DC
In summary, pumping a conducting liquid through two electrodes in a strong magnetic field produces a D.C current due to the steady movement of the fluid in one direction. It is possible to produce A.C by using a special pump to pump the fluid in two different directions. This process is known as Magnetohydrodynamics and can be used for propulsion or to generate electricity. Using metal instead of fluid can achieve similar results, but there are specific situations where Magnetohydrodynamics is beneficial, such as measuring the speed of a boat through seawater.
Richie Smash
293
Hi suppose you have a conducting liquid in a strong magnetic field, and this is pumped in a continuous loop through two electrodes, why does this produce a D.C current?
My thinking is a simple answer, and that is that the D.C current is produce because the fluid is moving in one direction steadily.
Would it be possible to get this same conducting fluid in the magnetic field to produce A.C instead? I am thinking I would need a special pump to pump the fluid in two different directions.
The set up could be two permanent magnets, a holder to hold an element of fluid and the electrodes, and copper wire connecting it to a load.
Likes sophiecentaur
You are describing an example of Magnetohydrodynamics (see this link). The effect can be used for propulsion or for producing an electric current with any moving conducting fluid and a magnetic field.
The same effect can usually be achieved by using metal rather than a fluid and you get more out of it. But it does have its uses, where a high speed plasma is available or when you want to measure the speed of a boat through seawater, for instance.
Likes Richie Smash
Related to Why does conducting liquid moving in a loop produce DC
1. Why does conducting liquid moving in a loop produce DC?
Conducting liquid moving in a loop produces DC because of the phenomenon known as electromagnetic induction. When a conductor, such as the liquid, moves through a magnetic field, it creates a flow of electrons, or current, in the conductor. This flow of current is what we refer to as direct current, or DC.
2. How does electromagnetic induction work?
Electromagnetic induction is the process by which a changing magnetic field induces a current in a conductor. This is possible because a magnetic field and an electric field are closely related. When a conductor moves through a magnetic field, the magnetic field lines cut through the conductor, creating a change in the electric field. This change in the electric field causes a flow of electrons, or current, in the conductor.
3. What is the difference between AC and DC?
The main difference between AC (alternating current) and DC (direct current) is the direction of the flow of electrons. In AC, the flow of electrons alternates back and forth, changing direction periodically. In DC, the flow of electrons is always in one direction. This is why AC is used for long distance power transmission, while DC is used for smaller, more precise applications.
4. Can any type of liquid be used to produce DC?
Yes, any liquid that is a good conductor of electricity can be used to produce DC. This includes both metallic and non-metallic liquids. However, the efficiency of the process may vary depending on the specific properties of the liquid, such as its conductivity and viscosity.
5. What are some real-world applications of conducting liquid producing DC?
One common application of conducting liquid producing DC is in hydroelectric power plants. Water, a good conductor, is used to turn turbines in the presence of a magnetic field, producing DC electricity. Another example is in batteries, where a chemical reaction between liquid electrolytes and metal electrodes produces a flow of DC current. Conducting liquid producing DC is also used in various electronic devices, such as power supplies and motors.
  • Electrical Engineering
