MHB Why Does d and 1 Being Associates Imply 1 is a GCD?
  • Thread starter Thread starter Math Amateur
    domains Modules
The discussion centers on understanding why the associates property of \(d\) and \(1\) implies that \(1\) is a greatest common divisor (gcd) of a set of non-zero elements \(\{ a_\alpha \}\). It is established that if \(c\) is any common divisor of the set, then \(c\) divides \(d\), and since \(d\) and \(1\) are associates, \(d\) divides \(1\). This leads to the conclusion that \(c\) must also divide \(1\). Therefore, since \(c\) is arbitrary, \(1\) qualifies as the gcd of the set by definition. The explanation highlights the importance of the associates relationship in determining the gcd in a commutative ring.
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am focused on Section 4.3: Modules Over Principal Ideal Domains ... and I need some help in order to fully understand the proof of Proposition 4.3.12 ... ...
Proposition 4.3.12 reads as follows:View attachment 8314In the above proof by Bland we read the following:
" ... ... Since $$x$$ is primitive, $$d$$ is a unit, so $$d$$ and $$1$$ are associates. Thus $$1$$ is a greatest common denominator of $$\{ a_\alpha \ \mid \ a_\alpha \neq 0 \}$$. ... ... "Can someone please explain exactly why $$d$$ and $$1$$ being associates implies that $$1$$ is a greatest common denominator of $$\{ a_\alpha \ \mid \ a_\alpha \neq 0 \}$$ ... ...Peter==============================================================================
It may help MHB readers of the above post to have access to Bland's definition of a primitive element ... so I am providing the same as follows:View attachment 8315Hope that helps ...
Peter
Re: Free Modules Over Prncipal Ideal Domains ... Bland, Proposition 4.3.12 ... ...
Hi Peter,
If $c$ is any common divisor of $\{a_{\alpha}: a_{\alpha}\neq 0\}$, then $c|d$ by definition of gcd. Since $d$ and $1$ are associates $d|1\Longrightarrow c|1,$ because $c|d$. Since $c$ is arbitrary, $1$ is a gcd of $\{a_{\alpha}: a_{\alpha}\neq 0\}$ by definition.
GJA said:
Hi Peter,
Thanks for the help GJA ...
But ... just a clarification ...
I can verify that $$d \mid 1$$ and that $$d|1\Longrightarrow c|1$$ ... but I cannot follow your argument from there ... that because $c$ is arbitrary, $1$ is a gcd of $\{a_{\alpha}: a_{\alpha}\neq 0\}$ ... ? ... ... can you please explain more fully ...
... essentially ... how does $$d \mid 1$$ and $$d|1\Longrightarrow c|1$$ together with $$c$$ being arbitrary imply that the gcd of $\{a_{\alpha}: a_{\alpha}\neq 0\}$ is $$1$$ ... ... ?
Thanks again ...
Peter
Hi Peter,
The definition of a gcd in a commutative ring (which $R$ is since it's a PID) is that any common divisor must also divide the gcd. By showing that the arbitrary common divisor $c$ divides $1$, we have shown $1$ is a gcd by definition. See the "GCD in Commutative Rings" section for a reference https://en.wikipedia.org/wiki/Greatest_common_divisor
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 16 ·
