Why does diode breakdown into conduction when reverse biased?
In summary, a PN junction acts like a hill for electrons, allowing them to easily flow in one direction but requiring a high amount of energy for them to flow in the opposite direction. When enough reverse bias is applied, two processes, Zener and avalanche breakdown, can occur to facilitate this flow of electrons and create a large current. These processes are non-destructive and reversible, as long as the current does not reach damaging levels.
samy
why does diode breakdown into conduction when reverse biased?
i didn't get, so could you please elaborate my above statement ?
Elaborate on what? You must be more precise in your question.
http://en.wikipedia.org/wiki/P–n_junction#Reverse_bias
The strength of the depletion zone electric field increases as the reverse-bias voltage increases. Once the electric field intensity increases beyond a critical level, the p–n junction depletion zone breaks down and current begins to flow, usually by either the Zener or the avalanche breakdown processes. Both of these breakdown processes are non-destructive and are reversible, as long as the amount of current flowing does not reach levels that cause the semiconductor material to overheat and cause thermal damage.
These links explains the two reverse breakdown modes.
http://en.wikipedia.org/wiki/Zener_breakdown
http://en.wikipedia.org/wiki/Avalanche_breakdown
While the above is correction, a handwavy, more pop-science version would be:
If you put enough reverse bias on a diode than you can accelerate electrons hard enough that when they hit a lattice site they can release more electrons and so on, making a chain reaction that causes a large current to flow.
I'll try an explanation. Think of the PN junction as a hill with a steep angle, not 90 say 80 degrees or so. When a bowling ball is sent down the hill, no problem it just rolls down the hill and proceeds on. But try to send one up the hill and you need a very high velocity to achieve this. The PN junction is an energy hill in one direction the voltage "pressure" that pushes it down the hill only takes a little energy to travel that distance. However in the opposite direction much more energy is needed, and the two mechanisms, as pointed out in Baluncore's response are Zener or avalanche breakdown process. Both present a tipping point (particular voltage or pressure) of the necessary energy to achieve useful amounts of current in the reverse direction. Then analogdesign's response elaborates further on the events that occur in the atomic lattice.
FAQ: Why does diode breakdown into conduction when reverse biased?
1. Why does a diode breakdown into conduction when reverse biased?
When a diode is reverse biased, the electric field across the depletion region increases. This causes a phenomenon called avalanche breakdown, where free electrons in the depletion region gain enough energy to knock additional electrons free. This results in a sudden increase in current flow, allowing the diode to conduct in the reverse direction.
2. What causes the electric field across the depletion region to increase in a reverse biased diode?
The depletion region is an area in a diode where there are no free charge carriers due to the depletion of dopants on either side of the junction. When a diode is reverse biased, the positively charged P-region and the negatively charged N-region create an electric field that pushes the few remaining free electrons in the depletion region towards the P-region, causing the electric field to increase.
3. Can a diode breakdown when forward biased?
Yes, a diode can also experience breakdown when it is forward biased. This is known as Zener breakdown or Zener diode breakdown. It occurs when the electric field across the depletion region becomes strong enough to cause the reverse current to increase dramatically, resulting in the diode behaving like a voltage-controlled switch.
4. Is diode breakdown a reversible process?
No, diode breakdown is not reversible. Once a diode has undergone avalanche or Zener breakdown, it will permanently lose its ability to block current in the reverse direction and will continue to conduct even when reverse biased. This is why it is important to operate diodes within their specified voltage limits to avoid damaging them.
5. How can diode breakdown be prevented?
To prevent diode breakdown, it is important to operate the diode within its specified voltage limits. This can be achieved by using a reverse voltage protection circuit, such as a series resistor, in order to limit the reverse voltage applied to the diode. Additionally, using a diode with a higher breakdown voltage can also prevent breakdown from occurring.
