Why does egg float upwards in stirred bottle of water?
In summary, the conversation discusses why an egg floats upwards in a stirred bottle of water and the possibility of conducting a similar experiment with other objects. The speaker also mentions a second experiment using solid materials with the same weight and shape as the egg, as well as shaking instead of stirring. The link to a video is provided and the possibility of the vessel's shape influencing the outcome is mentioned.
MulderFBI
Hello, why does the egg float upwards in a stirred bottle of water? I have tried making same experiment with other objects in different shapes but only the egg shape seems to float upwards. Here's the link to the video:
Second experiment:
Thank you for help.
Have you tried the 2nd experiment with solid materials having close to the same weight and shape as the egg? Have you tried the 2nd experiment with shaking the same way as the first experiment (rather than with a stirrer)?
Likes MulderFBI and berkeman
For the second video I think it might also have something to do with the fact that the vessel bulges out in the middle. The centrifugal force will naturally make it go to the widest part of the vessel.
Likes MulderFBI
FAQ: Why does egg float upwards in stirred bottle of water?
Why does the egg float upwards in a stirred bottle of water?
The egg floats upwards in a stirred bottle of water due to the difference in density between the egg and the water. The egg is less dense than the water, so it experiences an upward buoyant force that causes it to float.
Why does the egg sink initially when placed in the water?
Initially, the egg sinks when placed in the water because it is denser than the water. The weight of the egg is greater than the buoyant force acting on it, causing it to sink.
Is the stirring motion necessary for the egg to float?
Yes, the stirring motion is necessary for the egg to float. The motion of the water helps to distribute the egg's weight evenly, making it easier for the upward buoyant force to overcome the force of gravity and allow the egg to float.
Will the egg continue to float if the stirring stops?
If the stirring stops, the egg will eventually sink back to the bottom of the bottle. This is because the egg will settle into a position where the upward buoyant force is equal to the force of gravity, resulting in a state of equilibrium where the egg neither sinks nor floats.
Can any other objects float in a stirred bottle of water?
Yes, any object that is less dense than water can float in a stirred bottle of water. This includes objects such as pieces of cork or plastic, which will also float upwards due to the difference in density between them and the water.
