Why does heart rate increase in inspiration?
In summary, during inspiration, the diaphragm depresses and blood flows more easily into the lungs. The pulmonary circulation is a low-pressure system with the ability to accommodate an increase in blood flow without a major increase in pressure. This is achieved through vascular distension and recruitment of unperfused capillaries. During inspiration, there is a decrease in left atrial input and stroke volume, leading to an increase in heart rate. This is known as pulsus paradoxus in clinical terms.
sameeralord
662
Hello everyone,
Can anyone explain simply why heart rate increases in inspiration. Also why does the aortic valve close before pulmonary valve in inspiration? In inspiration does superior vena cavae get more blood? From what I read there was something to do with blood pooling inside the lungs during inspiration? Why does blood pool I don't understand?
Thanks :smile:
Biology news on Phys.org
Lungs are described as an accessory cardiac pump.
In inspiration, there is a depression (diaphragm) and blood goes more easily in lungs.
Hey somasimple did you mean blood goes less easily in lungs in inspiration. We learned this in class today!
I said the contrary:
http://www.nda.ox.ac.uk/wfsa/html/u12/u1211_01.htm
Blood supply
The lungs have a double blood supply, the pulmonary circulation for gas exchange with the alveoli and the bronchial circulation to supply the parenchyma (tissue) of the lung itself. Most of the blood from the bronchial circulation drains into the left side of the heart via the pulmonary veins and this deoxygenated blood makes up part of the normal physiological shunt present in the body. The other component of physiological shunt is from the thebesian veins, which drain some coronary blood directly into the chambers of the heart.
The pulmonary circulation is a low-pressure (25/10mmHg), low-resistance system with a capacity to accommodate a substantial increase in blood flowing through it without a major increase in pressure. Vascular distension and recruitment of unperfused capillaries achieve this. The main stimulus which produces a marked increase in pulmonary vascular resistance is hypoxia.
A pressure gradient is required to generate flow. In spontaneous respiration inspiratory flow is achieved by creating a sub-atmospheric pressure in the alveoli (of the order of -5cmH2O during quiet breathing) by increasing the volume of the thoracic cavity under the action of the inspiratory muscles. During expiration the intra-alveolar pressure becomes slightly higher than atmospheric pressure and gas flow to the mouth results.
In my case there seems to be a rather big difference. My heart rate is now about 45 bpm, but I notice that when I'm breathing in, it is above 50 bpm (the beats come almost every second). When I'm exhaling, my heart rate becomes very slow, below 40 bpm.
Heart rate and blood pressure are different things. :wink:
Heart rate increases whereas primarily, it is the blood pressure that decreases. During inspiration, negative intrathoracic pressure fills the pulmonary vasculature temporarily reducing the left atrial input and therefore the stroke volume. An increase in heart rate is a consequence of this.
In the clinical condition known as pulsus paradoxus, there is exaggeration of these events.
Related to Why does heart rate increase in inspiration?
1. Why does heart rate increase during inspiration?
During inspiration, the diaphragm and other respiratory muscles contract, causing a decrease in intrathoracic pressure. This decrease in pressure allows for increased blood return to the heart, leading to an increase in stroke volume and cardiac output. In order to maintain normal blood pressure, the body responds by increasing heart rate.
2. Is an increase in heart rate during inspiration normal?
Yes, an increase in heart rate during inspiration is a normal physiological response. It is a result of the body's efforts to maintain adequate blood pressure and oxygen delivery to tissues during changes in intrathoracic pressure.
3. How does the autonomic nervous system affect heart rate during inspiration?
The autonomic nervous system, specifically the sympathetic branch, plays a major role in regulating heart rate during inspiration. It responds to changes in pressure and oxygen levels in the blood by stimulating the heart to increase its rate and force of contraction.
4. Does heart rate always increase during inspiration?
No, heart rate does not always increase during inspiration. In some cases, such as during intense exercise or in individuals with certain medical conditions, the body may already be pumping blood at a high rate, and further increases during inspiration may not be necessary.
5. Can changes in heart rate during inspiration indicate any health issues?
In some cases, changes in heart rate during inspiration can indicate underlying health issues. For example, a significant increase in heart rate during inspiration could be a sign of heart or lung disease. It is important to consult a healthcare professional if you experience abnormal changes in heart rate during inspiration or at rest.
  • Biology and Medical
  • Science Fiction and Fantasy Media
25K
  • Mechanical Engineering
11K
