Why does infinite potential well give rise to standing wave?
In summary, for a particle in a box described by a wave function, the infinite potential well prevents the particle from tunneling through the barrier and creates a zero probability of finding it on the other side. This results in a standing wave bounded by the walls, as the wave function must vanish at the edges of the well. This is an idealization, and in reality, there will always be a finite probability of finding the particle outside the well, although it may be very small in some cases.
baouba
41
For a particle in a box that is described with a wave function, why can there only be a standing wave when there is an infinite potential well? From my understanding, the infinite potential well makes it impossible for the particle to tunnel through the barrier and so the wave function cannot permeate the walls and there is a zero probability of finding the particle on the other side. Is this why there is a standing wave bounded by the walls?
Since we could never have an infinite potential well (That I know of?) does this mean that this is just a generalization and that this is always a probability of finding the particle outside the box?
Can someone let me know if I'm on the right track?
Thanks
Yes you are. Since the wave function must exactly vanish on the edges of the well this is, by definition, a standing wave since the total length will always be a multple of [itex]\lambda/2[/itex]. Moreover, yes, this is a generalization. The probability of tunneling outside the well will always be finite, even if extremely small in many cases.
The proper word is "idealization", not "generalization."
Related to Why does infinite potential well give rise to standing wave?
1. What is an infinite potential well?
An infinite potential well is a theoretical model in quantum mechanics that represents a confined system with boundaries that have infinitely high potential energy. This means that particles within the well are unable to escape and are completely confined to the inside of the well.
2. How does an infinite potential well give rise to standing waves?
When a particle is confined within an infinite potential well, it is only able to occupy discrete energy levels. These energy levels correspond to different standing wave patterns, which are determined by the boundary conditions of the well. As the particle moves back and forth between the boundaries of the well, it creates a standing wave pattern, leading to the formation of standing waves.
3. What are the properties of standing waves in an infinite potential well?
The standing waves in an infinite potential well have distinct energy levels and are characterized by a specific wavelength, amplitude, and frequency. They also have nodes and antinodes, which are points of zero and maximum amplitude, respectively.
4. How does the width of the infinite potential well affect the standing wave patterns?
The width of the infinite potential well determines the spacing between energy levels and the wavelengths of the standing waves. The narrower the well, the closer the energy levels and the shorter the wavelengths of the standing waves. Conversely, a wider well will have wider spacing between energy levels and longer wavelengths of standing waves.
5. What is the significance of standing waves in an infinite potential well?
Standing waves in an infinite potential well play a crucial role in understanding the behavior of particles in confined systems. They provide a mathematical description of how particles behave within the well and help to explain phenomena such as quantum tunneling and the quantization of energy levels. They also have practical applications in fields such as quantum computing and nanotechnology.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
