Why does it look dark between the distance stars at night?
  • Thread starter NnnTech
  • Tags
    Stars
In summary, light can only be seen if it enters our eyes. It is not dark because that would sort of mean opaque from eye to the ''edge of the visual universe''.
NnnTech
34
The nature of light!
Xn
Hello , I have to do some ''homework'' on the nature of light ! I have to write everything I can think of !
When I look in the night sky , between the distant stars it looks observably dark when there is electromagnetic radiation filling that space .
Why does it look dark ?
NnnTech said:
Homework Statement:: The nature of light!
Relevant Equations:: Xn
What does it take for something not to "look" dark?
Likes NnnTech
Google Olber's Paradox
Likes NnnTech
Thank you , I don't see any paradox though but don't want to speculative in fear of warnings . I thought , my opinion , is that it is because there is nothing to see within visual range between these body . I thought the space was transparent . I think it is an optical illusion and not actually dark at all . Additionally in vector terms I thought it was Xn , an unspecified distance ? Have I solved Olber's paradox ?
This is definitely putting your toes over the line entitled "speculation starts here".
The baseline illumination you get from the gaps between the stars is pretty much the same as what you get emitted from a lump of black soot at about 2.725 degrees kelvin. It's called the Cosmic Microwave Background Radiation.
In a [rather strained] sense, it is an "optical illusion" and is "not actually dark at all". The Cosmic Microwave Background Radiation was emitted by an incandescent plasma and was very bright. We see it as dark because the expansion of the universe has reduced both its intensity and its frequency. The measured effect is real, not an illusion.
Eye sight ?
Yes, that is the short answer to @PeroK 's question but the issue is WHY is there nothing in the visual range? In other words, your answer is "it's dark because it's dark".
How are you suppose to answer replies if you can't add opinion based on facts ? Between the distant stars there is electromagnetic radiation ? For something to look in ''darkness' when there is lots of light must be an optical illusion unless you know a better answer ?
NnnTech said:
Eye sight ?
Okay. What does it take for your eyes to see something?
Likes NnnTech
Arr yes , that's an easy one , the information has to enter your eyes via light wave function ?
It isn't dark though because that would sort of mean opaque from eye to the ''edge of the visual universe'' wouldn't it ?
There is nothing to see in these spaces because our telescopes can only see so far ?
The light was denser and higher frequency when the universe was young. It is sparser and lower frequency now. Google CMBR.
It is not an optical illusion. It is real. Space-time curvature messes with intuitions about how things must remain the same. Keep your eyes out for Noether's theorem.
So it's not a question of whether space contains EM radiation, it's a question of whether any of it is coming in your direction.
PS Olbers paradox is something else.
Cosmic microwave background radiation , yes that is detectable light from the early universe . So you are saying that between the distant bodies it is really dark ? The space itself is dark ?
I see what you are saying but even without us to observe the universe , the sun would still be a bright ball , orange looking in the sky ?
Yes. Space is both dark and transparent. You can see through it all the way to the incandescent plasma that is the CMBR. But you see it hideously red-shifted so that it is dark now even though it was bright then.
When I say that "space is dark", I mean that the space around us is not carrying much light. What you see is what is there. It is not brightly illuminated except in the neighborhood of stars.
How can it be red-shifted light when the distant stars are local relatively to that distant ?
Are you saying if an Earth like body was traveling -ve towards the Earth and came within visual range where the distant stars were positioned , we wouldn't see that body ?
That's not the point. You can't see light unless it enters your eyes. When you see a searchlight shining up into the sky, what you are seeing is some of the light being scattered off particles in the air. If A searchlight was shining up through a vacuum you would see nothing.
The solar system is permanently flooded with light from the Sun, but we don't see it at night except where it reflects off the moon or the planets.
Cosmological red shift due to the expansion of the universe.
That is +ve not -ve ! My question asked about -ve , which would blueshift wouldn't it ?
The surface of last scattering is red-shifted. That's a cosmological red shift.
I do not know why you are babbling about an incoming planet with a kinematic blue shift.
Between the distant stars is Xn ? An unspecified distance ?
The surface of last scattering is not composed of stars. It is composed of incandescent and, accordingly, opaque plasma. No stars. Galaxy formation had not yet begun. We are talking about a time about 380,000 years after the big bang.
Einsteins space-time xyzt is based on visual matter . I have drawn up a quick doodle of my question for clarity .
NnnTech said:
Einsteins space-time xyzt is based on visual matter.
No. It is not.
jbriggs444 said:
No. It is not.
I am impressed if you can measure distance with only one point of reference ! Can you explain how to measure A to ?
I agree we can't see light unless it enters our eyes because I can't see if I close my eyes or I am in a dark room . However the light still exists without us and has a nature doesn't it ?
The radiation is there - in terns of measurable EM fields- but we on Earth can't see it.
Likes NnnTech
You appeared to be trying to expound on the Special Theory of Relativity, relating it to some diagram with circled x's. Einstein's 1905 paper does a much better job. Modern textbooks do better still.
However, we need the General Theory of Relativity from Einstein's 1915 paper to create a model compatible with modern cosmology. An expanding universe. The Big Bang.
This is well accepted textbook science.
Likes NnnTech
Thanks to type 1a supernovae it is possible!
  • #31
Sorry I assumed you'd understand that the circles represented bodies that reflect of emit light , our visual reference frame that we require to work out any distances . The Xn being a defined vector into ''outer space'' , space that is beyond the furthest bodies we can presently observe . Isn't Xn correct then ? An unspecified length ?
  • #32
I have doodled a better picture that you'll probably relate more too that is asking a question ?
  • #33
NnnTech said:
Sorry I assumed you'd understand that the circles represented bodies that reflect of emit light , our visual reference frame that we require to work out any distances . The Xn being a defined vector into ''outer space'' , space that is beyond the furthest bodies we can presently observe . Isn't Xn correct then ? A unspecified length ?
I struggle to understand what you are thinking.
So your two-dimensional drawing is for a section of sky that we are looking at. The X's are stars that we can see. The Xn is a direction where no stars are visible.
So this "Xn" is a direction from which no visible light is received. It is not a distance. It is an angle.
Yet if we point radio-telescopes in that direction, microwave radiation is received. Remarkably uniform microwave radiation from all directions. At a wavelength corresponding to a black body temperature of some 2.7 degrees Kelvin.
So we surmise that we are looking through space at something -- a surface of last scattering. We know how far away from us it is. Light from the surface of last scattering is about 13.8 billion years old. Converting that to a distance can be done in a number of ways (distance is not a simple concept in an expanding universe). It is just as well for us to leave it as an age rather than a distance.
Likes NnnTech
  • #34
+1 on that
  • #35
So your two-dimensional drawing is for a section of sky that we are looking at. The X's are stars that we can see the the Xn is a direction where no stars are visible.
Thank you for that very useful information ! Aren't angles relative to the observer ?
You now understand my question perfectly with the explanation you replied back .
There is nothing to visually observe by the human eye in this region of space because there is no spatial bodies emitting or reflecting light between 450nm-750nm , the visible spectrum ! Is that a correct statement ?
We can detect from these ''dark'' regions of space a microwave radiation that has a specific uniform wavelength that is relative too a black body temperature . I am not sure how distance can apply to such a detection to be honest , that seems a nonsense way and rather vivid imagination . If it is a constant or uniform as you say , how do you know it isn't just electromagnetic radiation we are detecting or a ''white noise'' ?
In my last doodle I supplied the reference , R^n which represents real coordinate space and is n-dimensional . Isn't it true that xyzt can always ''fit'' within a R^n reference frame ?
Isn't our visual universe based on visual matter rather than ''dark'' regions of space ?
Could it be possible these ''dark'' regions of space using vectors can be (X^n,Y^n,Z^n) ?
Does our visual universe exist within a R^n universe ?
