Why does light transmit through glass/diamond, but not solid
  • B
  • Thread starter Nicholas Lee
  • Tags
    Light Solid
In summary, the conversation discussed the concepts of energy bands in electrons, valence bands, and conduction bands, as well as the differences in band gaps in different materials. The conversation also touched on the idea of energy levels and how they relate to the movement of electrons in different materials. Ultimately, the conversation encouraged the individual to continue learning and to focus on the concept of solid band structure.
Nicholas Lee
27
I am getting my head around energy bands in electrons, valence bands, and conduction bands, but its complicated to understand.
But If if I ask the question this way it is more simple to me.
Photons pass through the material because they don't have sufficient energy to excite a glass electron to a higher energy level.
Energy levels exist together in regions known as energy bands.
In between these bands are regions, known as band gaps, where energy levels for electrons don't exist at all.
Some materials have larger band gaps than others.
In glass, or a diamond the material is solid but light can transmission through, no problem.
In a solid carbon block in the picture below, light gets absorbed.
So a object being amorphous (noncrystalline) does not effect transmission, its the energy.
If an electron is in the first energy level, it must have exactly -13.6 eV of energy. If it is in the second energy level, it must have -3.4 eV of energy.
Let's say the electron wants to jump from the first energy level, n = 1, to the second energy level n = 2. The second energy level has higher energy than the first, so to move from n = 1 to n = 2, the electron needs to gain energy. It needs to gain (-3.4) - (-13.6) = 10.2 eV of energy to make it up to the second energy level.
If it takes 10 eV to move the electron in shell 2 , in the glass, and the iron block, then why does the glass electron not get excited when hit by a photon.
Why is the carbon electron absorbing, I understand its a solid, and dense, but so is glass, and the diamond just as much.
I am almost sure its the energy, or the electrons not the amount of electrons in the shells of the carbon because carbons has 2 electrons in shell 1, and 4 electrons in shell two, silicone which is mostly what glass is made from has two electrons in shell 1,and 8 in shell 2, and 4 in shell 3.
So with silicone having more electrons it cannot be the reason for absorption, so its the energy of the electrons right
So it cannot be the amount of electrons I think just the energy of electrons, but can you explain why the energy levels are different for some electrons.
So an object being transparent cannot really be about how many electrons in its shells right,
BUT, every electron is every atom needs 10.2 eV of energy to make it up to the second energy shell level, to leave the ground state, doesn't it.
This is why I am confused, if glass electrons do not need 10 eV to move to the next shell level why is this.
Thank you for your help, remember I am still learning, sorry if some things are not accurate.
Again, you are mixing up ATOMIC ENERGY LEVEL and SOLID STATE ENERGY BANDS. It is confusing to figure out oif you are asking about atomic gasses or solid media. In the BANDS, there is no such energy state as a distinct 13.6 eV line!
In a metal, there are electrons in the conduction band need only an infinitesimal amount of energy to be excited, because it is sitting in a continuous energy band with unoccupied energies.
You really need to learn about solid band structure here. And stop making new threads on the same topic that you have already been asking!
Zz.
Related to Why does light transmit through glass/diamond, but not solid
1. Why does light transmit through glass/diamond?
Light is able to transmit through glass and diamond because they are both transparent materials. This means that their molecular structure allows light to pass through without being absorbed or scattered. Glass is made up of tightly packed molecules that have a regular and uniform arrangement, allowing light to easily pass through. Diamond has a similar molecular structure, but is even more tightly packed, making it an excellent conductor of light.
2. How is light able to pass through glass/diamond without being absorbed?
Glass and diamond have a unique property called transparency, which allows light to pass through without being absorbed. This is due to their molecular structure, which allows light to travel through without any particles in the material absorbing or scattering the light. The molecules in glass and diamond are arranged in a way that allows light to pass through relatively unimpeded.
3. Why does light not transmit through solid objects?
Unlike glass and diamond, most solid objects are not transparent. This is because their molecular structure is not conducive to allowing light to pass through. In solid materials, the molecules are closely packed together and have a more irregular arrangement, which causes light to be absorbed or scattered rather than transmitted. This is why we are unable to see through solid objects.
4. Can light ever transmit through solid objects?
In some cases, light may be able to transmit through solid objects. This is dependent on the material's properties and the wavelength of the light being used. For example, X-rays are able to penetrate through solid objects because their wavelength is small enough to fit between the molecules in the material. However, this is not the case for visible light, as its wavelength is too large to pass through solid objects.
5. How does the thickness of glass/diamond impact light transmission?
The thickness of glass and diamond can impact light transmission to some extent. Thicker materials will have more molecules for the light to pass through, which may cause some absorption or scattering. However, glass and diamond are still considered transparent even at thicker sizes, as long as they do not contain any impurities or defects that could affect the transmission of light.
  • Atomic and Condensed Matter
