Why does light travel radially in the FRW universe?
In summary: In contrast, given a geodesic you can't always choose a coordinate system that intersects the geodesic at the same point.This is because curvature bends light; which is indeed the reason why we can see stars that are really behind the sun (the first successful test of GR). The light that travel from these stars certainly must have dΩ≠0 for otherwise they would be absorbed by it (the sun).
center o bass
560
When deriving different properties from the FRW-metric $$ds^2 = -dt^2 + a^2 (d\chi^2 + S_k^2(\chi) d\Omega^2)$$ -- considering the propagation of light such that ##ds^2 = 0## -- one always assumes ##d\Omega = 0##. But how do we know that ##d\Omega## always vanish for propagating light?
Space news on Phys.org
This is obvious for k=0; but why is it also true for the other geometries?
In general, light rays will have non-zero angular motion. But as we are orienting the coordinate system such that we are at the center, the only light rays we see are the ones that are pointed directly towards the center. If they had non-zero ##d\Omega##, then they wouldn't be pointed directly at the center and we wouldn't see them.
Curvature doesn't change this argument at all.
Sounds like somebody is trying to backdoor a personal theory here.
I do not see why the argument that "the only light rays we see are the ones that are pointed directly towards the center" remains true when curvature is added to the picture. This is because curvature bends light; which is indeed the reason why we can see stars that are really behind the sun (the first successful test of GR). The light that travel from these stars certainly must have dΩ≠0 for otherwise they would be absorbed by it (the sun).
What do you think the ##\chi## coordinate describes?
You could very well have light rays traveling along geodesics with ##d\Omega\neq 0## just as you can have straight lines in ##\mathbb R^2## that do not cross the origin. However, given a straight line you can always choose your coordinate system such that it does cross the origin.
Related to Why does light travel radially in the FRW universe?
1. Why does light travel radially in the FRW universe?
In the FLRW (Friedmann-Lemaitre-Robertson-Walker) model, the universe is homogeneous and isotropic, meaning it has the same properties in all directions. As light travels, it travels in all directions equally, thus creating a radial pattern.
2. How does the radial pattern of light in the FRW universe relate to the expansion of the universe?
The radial pattern of light is a result of the expansion of the universe. As the universe expands, the space between objects, including light, also expands, causing the radial pattern of light.
3. Does light travel radially in all parts of the FRW universe?
Yes, light travels radially in all parts of the FRW universe because the FLRW model assumes a homogeneous and isotropic universe, meaning the properties of the universe are the same in all locations.
4. How does the speed of light in the FRW universe remain constant if the universe is expanding?
The speed of light is a fundamental constant in our universe, and it remains constant even as the universe expands. This is because the expansion of the universe affects the space between objects, not the fundamental properties of light itself.
5. Can light travel radially faster or slower depending on its direction in the FRW universe?
No, the speed of light is constant in all directions in the FRW universe. This is a fundamental principle of Einstein's theory of relativity, which states that the speed of light is the maximum speed at which all objects can travel in the universe.
  • Cosmology
  • Cosmology
  • Cosmology
