Cobalt101
- 27
Why does light (or indeed any object) travel the shortest path between two points (whether for flat or curved space/space-time) ?
Well, it DOESN'T travel on a geodesic if there is a force acting on it, only if it is in freefall (no forces).Cobalt101 said:Why does light (or indeed any object) travel the shortest path between two points (whether for flat or curved space/space-time) ?
Cobalt101 said:if there is no force acting on it (i.e. free fall) why does it travel on the geodesic?
PeterDonis said:Do you mean the shortest path in space or the shortest path in spacetime?
If you mean the shortest path in space, it's not always the case that light, or any object, takes that path. You need to be more specific about what scenario you are talking about.
If you mean the shortest path in spacetime, that concept as you state it has no meaning for light, since the spacetime interval along a light ray's worldline in spacetime is always zero. For ordinary objects, if they are in free fall, then the path they take through spacetime is the longest path between two events, not the shortest.
Geodesics in space-time is a human made model. It's our interpretation of the world. Why we use that interpretation? Because it works for making quantitative predictions.Cobalt101 said:why does a planet follow the geodesic around the sun ?
Cobalt101 said:I guess my question is at the basic end of things, trying to understand how the bending of space actually "works", what is the mechanism- for example, why does a planet follow the geodesic around the sun ?
Cobalt101 said:what is the mechanism- for example, why does a planet follow the geodesic around the sun ?
Light travels the shortest path because of a principle known as Fermat's Principle of Least Time. This principle states that light will always take the path that requires the least amount of time to travel.
Fermat's Principle is based on the fact that light travels at a constant speed in a vacuum. When light encounters a medium, such as air or water, it will slow down. The principle states that light will take the path that minimizes the amount of time spent in the slower medium, resulting in the shortest path.
No, light can still travel in curved paths as long as it minimizes the time spent in the slower medium. This is why we can see objects through curved lenses or in a curved fiber optic cable.
Light travels the shortest path to minimize the time it takes to reach its destination. This is crucial for many applications, such as communication systems, where even a small delay can cause significant issues.
There are certain cases where light may not travel the shortest path, such as when it undergoes total internal reflection. However, these are rare cases and the principle generally holds true in most situations.
