Why does light travels in all directions?
In summary, time, gravity, and the speed of light are all interconnected and influenced by each other. While Earth and the Sun revolve around each other due to gravity, the movement of the Milky Way is also affected by gravity. However, photons, which are particles of light, are not affected by gravity because they are not mass particles like fermions. This means that when we see light traveling away from us, it is actually us moving away from the photons. However, this understanding does not fully explain why we see photons emitted at one time in all directions when we reach a different time.
atuldpatil
My understanding of time, gravity and speed of light:
Earth revolves around the Sun. Sun revolves around Milky Way centre. Milky Way also keeps moving. All these movements are caused by gravity. Thus, all that what is formed by fermions (particles causing mass) has been affected by gravity. But photons (particles of light) are not affected by gravity. Because unlike fermions, photons are not mass particles. Thus, actually it's we who move away from photons making us feel light travels away from us. (Please correct me if am wrong anywhere in my understanding)Question:
Now I have this question. Let's assume we are in space(vacuum) with a source of light with us. At any given time t1 when our source of light emits a photon, it should remain at same position (unaffected by gravity). And at the time t2 (say a second after t1) we'll move away (because of the gravity) from that photon, with the light source still with us emitting photons.
Thus, we should see trail of light only from t1 to t2 (and this should be 299,792,458 meters long as that much is "speed of light" means we've came away that much distance from first photon in a second after t1)
However, in reality this doesn't happen and we see photons emitted at t1 goes in all directions when we reach to t2. Can someone please explain this?
No, movement is not necessarily caused by gravity. It may be effected by it, but gravity is not necessary for movement.
Fermions do not cause mass. Also, there are massive particles which are not fermions. Do not confuse mass with matter.
This is not correct. Photons are affected by gravity.
This is a personal philosophy which has very little to do with actual physics. Please note that posting personal theories is not allowed at PF.
The rest of your post is based on the above misconception and therefore moot. Thread closed.
Related to Why does light travels in all directions?
1. Why does light travel in all directions?
Light travels in all directions because it is an electromagnetic wave. This means that it is made up of perpendicular electric and magnetic fields that oscillate in all directions as the wave moves through space.
2. Does light always travel in a straight line?
In a vacuum, light will travel in a straight line. However, when it travels through a medium such as air or water, it can bend or refract due to changes in the density of the medium.
3. How fast does light travel in all directions?
Light travels at a constant speed of approximately 299,792,458 meters per second in a vacuum. This speed is known as the speed of light and is the fastest speed possible.
4. Can light travel through anything?
Light can travel through most transparent materials, such as air, water, and glass. However, it cannot travel through opaque materials, such as walls or solid objects.
5. What determines the color of light?
The color of light is determined by its wavelength. Shorter wavelengths correspond to blue and violet light, while longer wavelengths correspond to red light. The visible spectrum of light consists of all the different wavelengths that can be seen by the human eye.
