Why does liquid co2 goes back to solid at atmospheric press
In summary, when looking at the phase diagram, it can be observed that CO2 is in a liquid state at 5.11 atm and a temperature of -56°C. However, it immediately converts to a solid state at 1 atm. This is due to the pressure drop causing the temperature to decrease, resulting in the CO2 transitioning from a liquid to a solid state. In the experiment described, the pressure is initially increased, causing liquid CO2 to appear. As the pressure continues to increase, the liquid begins to boil and eventually all solid CO2 is gone. When the pressure is then dropped to 1 atm, the CO2 reforms into a solid state due to the cooling effect of some of the CO2 evaporating.
vlajky
I you look at the phase diagram, CO2 is in liquid state at 5,11 atm and t= -56 C. But why does he convert directly to solid state at 1 atm? Again, if you go down from five to one atm, you should be in gaseous state ? Is it have something to do with temperature ? What happens with temperature during the pressure drop?
I am specifically asking about liquid to solid transition that occur in the experiment explained below and why it happens during the pressure drop. On phase diagram if pressure drop from 5 to 1 atm at t= -56,6 c you are in the gaseous state? It must be the temperature drop all so ? If it is, why it happens ?
experiment :
Dry ice is placed into an PET plastic cylinder. A valve is closed and pressure in the cylinder increases. When the pressure reaches 511 kPa it stops increasing and liquid CO2 appears. The liquid begins to boil and when all solid CO2 is gone, the pressure increases further. The valve is opened and the pressure drops again to 1 atm. Eventually solid CO2 reforms, the liquid disappears? WHY THE SOLID STATE REFORMS AGAIN ( from liquid ) RATHER THEN GASEOUS ?
Without knowing the details I can hazard a guess. With the pressure drop some of the CO2 evaporates cooling the rest which becomes solid.
I think you're right. That's the only reasonable explanation. Thank you!:)
FAQ: Why does liquid co2 goes back to solid at atmospheric press
Why does liquid CO2 turn into a solid at atmospheric pressure?
Atmospheric pressure is the amount of force that the air exerts on its surroundings. When liquid CO2 is at atmospheric pressure, it is under high levels of pressure and temperature. This causes the molecules of CO2 to be tightly packed together, making it easier for them to form a solid state.
What is the process of CO2 turning from a liquid to a solid at atmospheric pressure?
When liquid CO2 is exposed to atmospheric pressure, it begins to lose energy in the form of heat. As the temperature decreases, the molecules slow down and come closer together, eventually forming a solid lattice structure.
Is there a specific temperature at which liquid CO2 turns into a solid at atmospheric pressure?
The exact temperature at which liquid CO2 turns into a solid at atmospheric pressure is -78.5°C (-109.3°F). At this temperature, the pressure and temperature are in equilibrium, and the CO2 molecules are able to form a solid state.
Can liquid CO2 turn back into a solid at atmospheric pressure?
Yes, liquid CO2 can turn back into a solid at atmospheric pressure. This process is known as sublimation, where the solid state of a substance turns directly into a gas without passing through the liquid phase. This can occur at temperatures below -78.5°C (-109.3°F).
How does atmospheric pressure affect the properties of liquid CO2?
Atmospheric pressure plays a crucial role in the properties of liquid CO2. At high pressures, it can exist as a liquid, while at low pressures, it can exist as a gas. This is known as the triple point, where all three phases (solid, liquid, and gas) of a substance can coexist in equilibrium.
