Paige_Turner
- 44
- 9
Why doesn't it repel things... or just pass through and leave distance unchanged?
Mass doesn't "bend space". It bends spacetime. More precisely, stress-energy bends spacetime; that includde mass (more precisely, energy density), but it also includes other things, like pressure. The particular way stress-energy bends spacetime depends on the particular properties of the stress-energy; for example, "dark energy" (which has positive energy density but negative pressure) pushes things apart instead of pulling them together (that's why it causes the expansion of the universe to accelerate).Paige_Turner said:Why doesn't it repel things... or just pass through and leave distance unchanged?
PeroK said:> Particles in curved spacetime move according to the principle of maximal proper time
No, it's maximal proper time.Paige_Turner said:Do you mean, "minimal proper time?"
Does this make any sense?PeroK said:No, it's maximal proper time.
Yes.Grasshopper said:Does this make any sense?
Only if you are in free fall. Don't confuse proper time with coordinate time. In fact, I would advise forgetting about coordinates and frames altogether when thinking about this. The rest of your post is simply compounding that error.Grasshopper said:In your own rest frame, you don't move through space, but you always move through time. That is an instance of "maximal proper time," right?
No, because the action for an object moving through spacetime is the object's rest mass times minus the proper time. So maximizing the proper time is the same as minimizing the action.Paige_Turner said:isn't it inconsistent with he principle of least action?
Light moves on null geodesics, which do not maximize proper time; proper time is a meaningless concept for null curves.Paige_Turner said:Light takes the path of the sum of histories, but that adds up and cancels out to the path that takes the least time, right?
Not a timelike geodesic on a Lorentzian manifold, no. A timelike geodesic is the longest possible path between two points.Paige_Turner said:A geodesic is the shortest possible path on the 4D manifold, etc?
WOH.Action is one of the things I'm currently trying to understand.PeterDonis said:> the object's rest mass times minus the proper time.
No. Heuristically, the minus sign comes from the fact that the Lagrangian is kinetic energy minus potential energy, and rest mass is part of potential energy in relativity.Paige_Turner said:Would that minus sign happen to be the same as the minus sign in the interval metric equation?
Yaaack! That was the key.PeterDonis said:No. Heuristically, the minus sign comes from the fact that the Lagrangian is kinetic energy minus potential energy, and rest mass is part of potential energy in relativity.
Note that if the question involves Planck's constant, it probably belongs in the quantum physics forum.Paige_Turner said:i have more more questions about action and the Planck constant, but I'll ask them in another thread.
No way. I'm staying away from that quantum stuff. It's scary.PeterDonis said:> it probably belongs in the quantum physics forum.
You can't stay away from quantum stuff if you ask questions involving Planck's constant.Paige_Turner said:I'm staying away from that quantum stuff. It's scary.
According to Newton's Law of Universal Gravitation, the force of gravity between two objects is directly proportional to their masses. This means that the larger the mass of an object, the stronger its gravitational pull will be.
The greater the mass of an object, the stronger its gravitational pull will be. This is because the more mass an object has, the more it will bend the fabric of space-time, creating a stronger gravitational field.
Earth has a larger mass than the moon, which means it has a stronger gravitational pull. The Earth's larger mass also means it has a greater effect on the fabric of space-time, creating a stronger gravitational field.
Yes, according to Newton's Law of Universal Gravitation, the force of gravity decreases as the distance between two objects increases. This means that the closer two objects are, the stronger their gravitational pull will be.
Weight is the measure of the force of gravity pulling on an object. The more mass an object has, the greater its weight will be because it will have a stronger gravitational pull. This is why objects with more mass feel heavier than objects with less mass.
