Why does my if-statement not work when I have (x-100) instead of x?
  • Thread starter Thread starter Darkmisc
    godot
The discussion centers on creating a shoot 'em up game where enemies fire at the player after a delay. The original code for enemy behavior was not firing shots as intended when using a condition that included a positional offset. The issue was resolved by modifying the firing condition to include a random value, ensuring the enemy would fire when it approached the player's position. Debugging tips were shared, emphasizing the importance of printing variable values to understand unexpected behavior. The final solution involved placing the firing condition within the physics process function, which allowed the enemy to successfully launch shots at the player.
Darkmisc
TL;DR Summary
I'd like enemies to fire a shot once they get behind the player. I have an if-statement to fire a shot if position<x. This works. However, the if-statement doesn't work if I write "if position<x-100".
Hi everyone
I'm making a shoot 'em up in which enemies travel right to left towards the player. If they get behind the player, they are supposed to fire a shot at the player.
The code below for the enemy works, but I'd like a slight delay before the shot is fired.
[CODE title="enemy"]func _physics_process(delta):
position+= speed*movement_vector*delta
if position.x <=Global.player_pos.x and shot_fired==false:
launch_proximity()
[/CODE]
[CODE title="shoot_laser" highlight="6"]func launch_proximity():
shot_fired=true
player_pos=Global.player_pos.x
shoot_pos = player_pos
if position.x<shoot_pos:
print("bam")
var child_node = $EnemyBarrel/Muzzle
Global.rot = $EnemyBarrel.rotation
var l = LASER.instance()
get_parent().add_child(laser_parent)
laser_parent.add_child(l)
l.global_position = child_node.global_position
l.rotation = $EnemyBarrel.rotation
add_child(l)[/CODE]
However, the enemy won't fire if I have this at line 6
[CODE title="line 6"] if position.x<shoot_pos -100:
[/CODE]Does anyone know why?
Thanks
EDIT: I have the player in the middle of the screen when the enemies pass, so I don't think it's because the enemies are off-screen by the time they are 100 pixels behind the player.
Also, I've used position.x<shoot_pos - rand_range(0, 200) and they've never fired with that code either.
Technology news on Phys.org
To debug this kind of problem, insert a line print(position.x, shoot_pos) before the test that is not doing what you expect. Edit: If it is still doing something strange, try print(type(position.x), type(shoot_pos)).
When you post code here, make sure you select an appropriate language: GDScript is based on Python, so use Python.
You will find that it is much easier to debug code if you use consistent spacing, so for instance
[CODE lang=Python title="shoot_laser" highlight="6"]func launch_proximity():
shot_fired = true
player_pos = Global.player_pos.x
if position.x < shoot_pos:
print("bam")
var child_node = $EnemyBarrel / Muzzle
add_child(l)
[/code]
It is a good idea to follow the Python style guide https://peps.python.org/pep-0008/.
Likes berkeman, FactChecker and Darkmisc
I think some statements about GDscript operator precedence and short-circuit evaluation are a little vague.
This might be over-cautious and make no difference, but if things are acting strange, I would use more parentheses to force the operation order as you want it:
Python:
if ( position.x < (shoot_pos -100) ):
Likes Darkmisc and phinds
Some general debugging advice:
1.State the language you are using - don't make us guess. This looks like a precedence problem, which can be language-specific.
2. Give us the shortest possible piece of code that shows the problem. Often the process of finding this also provides a strong hint as to the answer.
Likes Darkmisc and FactChecker
Making it more complicated is not likely to help. A lot of things could go wrong. Is position.x global?
I see a recent edit. Have you tried any of our suggestions? Especially try @pbuk 's suggestion in post #2 to print the values of interest. When things are behaving strangely, it is often because the variable values are not what you expected.
Thanks. It works now.
This is the code I'm using
[CODE lang="python" title="func _physics_process(delta):" highlight="6"]func _physics_process(delta):
if position.x + rand <=Global.player_pos.x and shot_fired==false:
launch_proximity()[/CODE]
[CODE lang="python" title="shoot_laser"]func launch_proximity():
shot_fired=true
add_child(l)[/CODE]
I think I needed to have my if-statement in the physics process.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
