Why does Newton's 3rd law holds macroscopically?
  • Thread starter ELB27
  • Tags
    Law
In summary, the conversation discusses the breakdown of Newton's 3rd law in electrodynamics and how it applies to macroscopic interactions. It is explained that while the 3rd law may not hold, it generalizes to the conservation of momentum, which does hold if the momentum of the fields is included. Various interpretations and sources are discussed, including the idea that matter exerts a "force" on the field and gains momentum. The significance of this in understanding electrodynamics is also considered.
ELB27
117
Hi all,
I recently learned about the breakdown of Newton's 3rd law in electrodynamics and this got me thinking. The forces we consider in classical mechanics like friction and normal forces are microscopically electromagnetic interactions (repulsions?) of the atoms of two surfaces. If Newton's 3rd law doesn't hold for those interactions (which are certainly not static), how come it holds macroscopically? Perhaps it holds just as a good approximation, "on average"?
Thanks in advance for any comments!
It actually does not break down. You simply have to consider the momentum carried by the electromagnetic field as well.
Likes ELB27 and Vatsal Sanjay
Can you suggest me a few sources to read about this in detail? Please prefer research papers if possible. I had been fascinated by this problem and a little sceptic about this very explanation but could never find reliable relevant sources.
I hope this isn't out of on going discussion domain.
As Orodruin mentioned, the key is to recognize that while the 3rd law may not hold, it generalizes to the conservation of momentum, which does hold provided that you include the momentum of the fields as well. Then the reason that the 3rd law holds macroscopically follows from the fact that there are no "macroscopic" fields carrying away momentum.
Likes ELB27
It does hold if you consider the force to have a corresponding (local) force acting on the electromagnetic field, i.e., imparting momentum on it. The SR version is simply the conservation of the total energy momentum tensor, i.e., if you have two components of energy and momentum, ##\partial_\mu (T_1^{\mu\nu} + T_2^{\mu\nu}) = 0##. Each term can be considered to be a 4-force density.
Agreed completely. That is why I used the word "may". I tend to favor exactly the interpretation you mentioned where the matter exerts a "force" on the field which gains momentum, but I haven't seen that as an "official" interpretation so I didn't want to push it.
Even if you take the contrary view and consider the "force" on a field to not be a valid force (so that Newton's 3rd is violated in some cases) you still have conservation of momentum and, if no macroscopic fields carry momentum, then Newton's 3rd is recovered.
Thank you for the replies! I need to think about it a bit more from this point of view of momentum conservation.
By the way, Orodruin, is your name a reference to Mount Doom?
Yes, but that is off-topic. :rolleyes:
Likes ELB27
FAQ: Why does Newton's 3rd law holds macroscopically?
What is Newton's 3rd law and why is it important?
Newton's 3rd law, also known as the law of action and reaction, states that for every action, there is an equal and opposite reaction. This means that when an object exerts a force on another object, the second object exerts an equal force in the opposite direction. This law is important because it helps us understand the relationship between forces and motion, and it is the basis for many fundamental principles in physics.
How does Newton's 3rd law apply to macroscopic objects?
Newton's 3rd law applies to macroscopic objects in the same way that it applies to microscopic objects. Any time two objects interact, they exert equal and opposite forces on each other. For example, when you push a book across a table, the book exerts an equal and opposite force on your hand.
What evidence supports Newton's 3rd law at the macroscopic level?
There is a lot of evidence that supports Newton's 3rd law at the macroscopic level. One of the most compelling pieces of evidence is the fact that objects in motion tend to remain in motion unless acted upon by an external force. This is known as inertia, and it is a direct result of Newton's 3rd law. Additionally, the laws of conservation of momentum and conservation of energy also support Newton's 3rd law.
Are there any exceptions to Newton's 3rd law at the macroscopic level?
There are a few rare cases where Newton's 3rd law may appear to be violated at the macroscopic level. For example, when two objects are in contact and one object is significantly more massive than the other, the force exerted by the less massive object may not have a noticeable effect on the more massive object. However, upon closer examination, it can be seen that the forces are still equal and opposite.
How does Newton's 3rd law contribute to our understanding of the world?
Newton's 3rd law is a fundamental principle in physics that helps us understand how objects interact with each other. It allows us to predict the motion of objects based on the forces acting on them, and it also helps us design and improve technology, such as rockets and airplanes. Additionally, Newton's 3rd law has implications in other fields, such as biology and chemistry, where forces and reactions are also important factors to consider.
