Why does Nickel-62 have the highest BEPN?
  • B
  • Thread starter Jimmy87
In summary, the article explains that adding more nucleons to a small nucleus increases the binding energy per nucleon, but for larger nuclei, the strong force decreases and the electrostatic repulsion becomes dominant, reducing the binding energy per nucleon. Adding excess neutrons to a nucleus forces them into higher energy shells, making the nucleus more unstable and potentially decaying on its own. This also lowers the energy required to separate the nucleons in the nucleus. However, adding both protons and neutrons in a balanced amount results in a stronger strong interaction, but this cannot be achieved for larger nuclei due to the stronger Coulomb repulsion.
Jimmy87
686
Hi,
I have been looking for an answer to this question and came across this PF article (https://www.physicsforums.com/threads/why-is-iron-56-the-most-stable-nuclei.635183/) which explains most of the type of answer i was looking for.
So as I understand ( Quantum Pion's thread from above) if you have a small nucleus and add more nucleons you increase the binding energy per nucleon as each new nucleon creates more strong force in the nucleus. For larger nuclei since they have a much larger diameter the strong force dies off inside the nucleus causing the electrostatic proton-proton repulsion to dominate thus reducing the BEPN. It was pointed out in the thread that this answer would mean that adding more neutrons for heavier nuclei would solve the problem and goes on to talk about nuclear energy levels.
Could someone please explain how adding excess neutrons and thus forcing them into higher energy shells reduces the BEPN of the nucleus. I get that it makes the nucleus more unstable as the neutrons will decay into protons (i.e. radioactive nucleus) but I don't see how this process lowers the energy required to separate the nucleus?
Thanks
The nucleus has more energy. It needs less additional energy to transform to something else - or it might even have enough energy to decay on its own.
I see why it decays with excess neutrons but why does it require less energy to separate the nucleons in a nucleus i.e. why does it lower the BEPN? Say you have Nickel which requires the most energy to separate the nucleons in a nucleus, why does it require less energy to separate the nucleus if you added extra neutrons? This should increase the strong nuclear force and reduce electrostatic repulsion so BEPN should increase? Or is it just that extra neutrons always decay into protons if there are too many and this increases the electrostatic repulsion?
Consider a somewhat similar situation for electrons in atoms, e.g. lithium. You add one electron, it goes to the deepest available energy state. You add another electron, its binding energy will be smaller - the average goes down. You add a third electron, it now has to go to the second shell and is quite weakly bound - the average gets even lower.
Right.
If you add only neutrons to a nucleus then the extra neutrons occupy higher orbitals and are more weakly bound than an extra proton would be, which is why it tends to undergo beta decay. If you add too many neutrons, they are not bound at all and reach neutron dripline like H-4 or He-5.
If you add just protons, you have exact same problem as with neutrons, plus additional problem with Coulomb repulsion.
If you add both protons and neutrons then for small nuclei, up to Ni-62, balanced addition will result in stronger strong interaction.
But as you go further, you cannot add neutrons only (Fermi repulsion raises their energy and forces them to beta decay) and you cannot add neutrons and protons in a balanced amount (because the remaining Coulomb repulsion of protons, forced by Fermi repulsion of neutrons, is stronger than strong force attraction).
FAQ: Why does Nickel-62 have the highest BEPN?
Why is Nickel-62 considered to have the highest binding energy per nucleon (BEPN)?
Nickel-62 has the highest BEPN because it has a very stable arrangement of protons and neutrons in its nucleus, resulting in a strong nuclear force that binds the nucleons together. This leads to a lower amount of energy required to break apart the nucleus, giving it a higher BEPN compared to other nuclei.
How does the number of protons and neutrons in an atom's nucleus affect its BEPN?
The number of protons and neutrons in an atom's nucleus directly affects its BEPN. As the number of nucleons increases, the nuclear force becomes stronger, leading to a higher BEPN. However, if the nucleus becomes too large, the repulsive forces between protons can overcome the nuclear force, resulting in a decrease in BEPN.
What is the significance of BEPN in determining the stability of an atom?
BEPN is a measure of the stability of an atom's nucleus. The higher the BEPN, the more stable the nucleus is, as it requires more energy to break apart the nucleons. This is why Nickel-62, with its high BEPN, is considered to be one of the most stable nuclei.
How does the BEPN of Nickel-62 compare to other elements?
Nickel-62 has the highest BEPN of all naturally occurring elements, making it the most stable. However, some artificially created elements, such as Californium-251, have a higher BEPN. Generally, the BEPN of elements decreases as the atomic number increases.
Can the BEPN of an atom change?
The BEPN of an atom can change through nuclear reactions, such as fusion or fission. In these reactions, the nucleus can gain or lose protons and neutrons, altering its BEPN. However, the BEPN of a stable nucleus, like Nickel-62, remains constant unless it undergoes a nuclear reaction.
