Why does one form need to be used over the other?
In summary, the usual curl operation in differential geometry is generalized to ^*dA, where A is a one-form. In three dimensions, this gives back a one-form with components \sqrt{g} \epsilon_{ijk} \partial^j A^k. However, the corresponding contravariant components are \frac{1}{\sqrt{g}} \epsilon^{ijk} \partial_j A_k. To obtain the formula we learn in elementary calculus, the second form must be used. The same applies for the generalization of the gradient, where the formula for covariant components of d\phi = \partial_i \phi must be used to get the usual formula for the gradient. The reason for choosing one form over another
  • #36
mathwonk said:
what is del ? or nabla, or whatever?
what is A? presumably A is the vector of coordinates of the differential one form Ar dr + Atheta dtheta, but maybe not?
what coordinates are yoiu using? spherical? are del and A both in spherical coords?
this very old fashioned notation is just to me a clumsy way of obscuring the quite simple differential calculus as now used in terms of differential forms, and it is so out of date, i have never even seen it! (believe it or not.)
(i took elementary calculus out of loomis and sternberg and was never exposed to this old maxwellian version of vector calc notation, that originally arose using quatern ions, and has been outmoded in mathematics for over 50 years.)
but i agree it would be fun to see then turn out the same. but i am confident there is no difficuklty about this if we just make clear what the symbols mean.
yes, this is the expression in spherical coordinates.
This is the expression given for example in undergraduate electricity and magnetism formula when applying the curl of electric or magnetic fields (or of the vector potential) in spherical coordinates.
  • #37
Hurkyl said:
Is [itex]\nabla \times A[/itex] not equal to [itex]({}^\star d(A^t))^t[/itex]?
(Where the transpose of a vector is the one-form you get by contracting with the metric, and conversely)
Yes, that sounds right! This is what I am getting from reading Frankel. And I *think* this *does* correspond to the formula [itex] \sqrt{g} \epsilon^{ijk} \partial_j A_k [/itex] I mentioned early on. I have to check this.
What about the gradient? It would be [itex] d \phi [/itex], not [itex] (d \phi)^t [/itex], right? (i.e. we would not go back to a vector by contracting with the metric)
Thanks!
  • #38
It depends on what you mean by "gradient". I always thought it meant the covector that yields directional derivatives, but I've seen people insist that it means the vector pointing in the direction of greatest ascent.
If you mean the vector, then you'll have to transpose.
  • #39
this may seem simple minded but think what i am asking is whether del means (d/dx, d/dy)
or whether it means (d/dr, d/dtheta).
i suspect the reason this curl expression looks funny, is that it stands for the polar transfrom of d of the cartesian transform of a one form given in polar coords.i.e. (d/dx,d/dy) X (Ar, Atheta) is going to look different from
(d/dr, d/dtheta) X (Ar, Atheta).there is to me still no reason at all to bring in any stars or duals or metrics into this calculation.
  • #40
It seems almost right except for one very nagging detail.
To make it work, I would instead need to use [itex]({}^\star d(A))^t[/itex], i.e. I would have to treat the components of the "vector field [itex] \vec{A}[/itex]" as if they were already the components of a one-form. This is strange.
  • #41
this seems to me to be an object lesson in the unnecessary confusion introduced by trying to pretend that a space is isomorphic to its dual, by means of a metric, when it is clearer to keep dual spaces distinguished.
  • #42
ok, i think i see you are saying "curl" as an operation on a vector field, which of course makes no sense unless you have a metric, since properly it means the exterior derivative of a one form.
so you have to change your vector field into a one form, then take d, then change it back. uggh. all this compounded by changing coordinates.
same confusion for "gradient" which to me is just a one form associated to a function, but to some people is a vector field (artificially) dual to that one form.
this may be the underlying mystery you are grappling with, i.e. i think curl of a vector field is not a natural operation, undefined without a metric, but d of a one form is.
  • #43
agreed. Unfortunately, in elementary physics the distinction is not made. So as physicists, we learn to calculate the curl of vector fields (well, they are called vector fields but in restrospect it's not clear if they were vector fields or components of differential forms), to take divergence and gradient, to integrate, to use Stokes and Green's theorems, and so on without ever using differential forms.
Now I am trying to connect everything I have learned to the more powerful language of differential forms but this requires that I disentangle everything that was patch together in physics. Unfortunately, this is very difficult because most physicists don't know well (or at all) the language of differential forms and mathematicians are not necessarily used to physics applications. And in addition it's ahrd to find references explaining clearly the connection between the two languages.
  • #44
That doesn't work, because dA is gibberish. d acts on forms, A is not a form. What's wrong with what I wrote? When I worked it out, I thought I got the right answer, except possibly with the wrong overall sign. (Which is easy to fix)
  • #45
thank you. i think iam beginning to grasp the situation. do you want the curkl of a vector field to be VECTOR FIELD?
so poerhaps do you first turn the vector field into a one form using a metric? then take d of the one form, getting a 2 form, then take the hodge dual of the 2 form getting a one form?
then turn that back into a vector field using the metric?
No wonder it is complicated. then there are the changes of coordinates for all these operations!
so do we have two dual operations, between one forms and 2 forms, and also between vectors and one forms, and we are also changing coordinates?
I am feeling too much on vacation to deal with this mess. but hurkyl seems up for it.
you might look in loomis and sternberg, or nickerson, spencer and steenrod, or spivak, or marsden and tromba, or maybe wendell fleming.
  • #46
I understand that it makes only sense to apply the exterior derivative on a one-form.
What I mean is that it seems to me that in order to get the usual expression (that I learned in undergraduate school), it looks as if I must assume that the three components of the "vector field" [itex] A_r, A_{\theta} [/itex] and [itex] A_{\phi} [/itex] must be treated as the three components of a one -form. In undergrad E&M, say, everything is called a vector field so when three components of something is given, it's not clear if it's really the components of a vector field or the components of a one-form (or who knows, maybe even the three independent components of a two form in 3 dimensions!). It seems to me that I need to treat the three components of the supposed vector field as really being the components of a one-form.
I will post the details a bit later (maybe tomorrow).
Do you see what I am trying to say?
  • #47
we seem to be converging on the same point of view.
  • #48
If you intend to define a vector field valued curl of a covector field, then [itex]({}^\star dA)^t[/itex] does appear to be a reasonable definition.
  • #49
You see, this is part of the difficulty I am having. Because in undergraduate physics, everything si called a vector field. Let's say we are working with three functions [itex] A_r, A_{\theta} [/itex] and [itex] A_{\phi} [/itex] (where the position of the indices has no special meaning). Then it's not clear at all if these are meant to be the components of a vector field, or the components of a differential one-form (or, who knows, the three independent components of a two form in 3 dimensions!). This is part of what makes my job so hard:frown:. I need to figure out if three functions are really the components of a vector field or of a one-form. In the end, I wlaso want to figure out what the different physical quantities (electric field, magnetic field, current density etc etc ) that we use in undergraduate physics are vector fields, one-forms, etc.
So I was trying to {\bf use} the expressions given in undergraduate physics textbooks for the curl, gradient and divergences to figure out if those functions that are differentiated are truly components of vector field or something else.
so poerhaps do you first turn the vector field into a one form? then take d of the one form, getting a 2 form, then take the hodge dual of the 2 form getting a one form?
then turn that back into a vector field?
yes, but the point was that if I could get an expression in terms of exterior derivatives and hodge dual and so on, the result would be completely coordinate independent. This is what I was trying to get at!
so we have two dual operations, between one forms and 2 forms, and also between vectors and one forms, and we are also changing coordinates?
:smile: Believe it or not, I am on vacation too and I am going insane with that stuff!
  • #50
Double the size of everything: that will tell you what you need to know.
3-forms will be divided by 8.
2-forms will be divided by 4.
1-forms will be halved.
scalars will be unchanged.
vectors will be doubled.
bivectors will be quadrupled
trivectors will be octupled.
(Note that if you chance coordinates (x', y', z') = (x/2, y/2, z/2), then the rescaled thing in (x', y', z') coordinates looks the same as the original in (x, y, z) coordinates -- except, of course, that the metrics are different)
For example, consider mass density. A 1 kg cube 1m on a side has density 1 kg / m^3. A 1 kg cube 2m on a side has density (1/8) kg / m^3. Thus, mass density is best represented by a 3-form.
You could see this directly too: density directly tells you how much mass there is in a volume, which is precisely what 3-forms do.
Rescaling by -1 gives a simpler test, but can't distinguish between everything. But it helps for some things -- e.g. it tells you that a vector-valued cross product of vectors is not a very good idea.
  • #51
well we just need a symbol for the duality between vector fiedls and covector fields, i.e.one forms, let's call it #, so # of a one form is a vector field and vice versa.
then curl of a vector field V, should be something like
#(*d#V),
i.e. #V is a oneform, then d#V is a 2 form, then *d#V is a oneform,
then #*d#V is a vector field.,
but this looks too complicated.
nonetheless i have seen some pretty complicated expressions in my life.
the reason i thought this was simple, is that the only part of this that is purely differential forms, to me, is the d part.
duality is always confusing. and using metrics to identify spaces that are dual, makes it harder to tell them apart, and harder to recognize which operations are natural for them.
  • #52
metrics are useful in the study of differential forms however, in hodge theory as follows:
when oine studies one forms say, it is interesting to examine which one forms are d of a function (i would say which ones are gradients).
a necessary condition which is locally sufficient, but not globalkly so, is to have curl = 0, or d =0.
then one wants to know how far from sufficient this condition is, so one studies the quotien space {w: dw=0}/{df: all f}.
this space is often finite dimensional, and choosing a metric allows one to pick a natural space of one forms which is orthogonal to the denominator space, called the harmonic forms.
this has some computational advantages, analogous to studying complex holomorphic functions by their real and imaginary (harmonic) parts.
  • #53
#(*d#V),
That's indeed what Hurkyl wrote except that he used a small "t" to indicate that: [itex] (\,^* d V^t)^t [/itex]
:smile: I hope this is not taking too much time away from your vacations!
True. But this is the case in physics from the very start.
You see now why I have asked so many stupid questions in the past (and I am still doing that) as I am trying to "unconfuse" everything that was tangled up together in my physics background!
Regards
  • #54
well you may have interested me in learning the physics of these matters, since i have realized it is also connected to hodge theory, so thank you!
  • #55
:smile: You are very welcome. I am glad that this whole exercise did not end up being a complete waste of time for you. And I am glad that it got you interested in physics applications. If you have any thoughts or you realize anything about the physics applications of these concepts, please post them. But you are warned that in conventional physics or engineering books (or even in most undergraduate books of mathematical physics such as Arfken for example), vector calculus is developped without any mention of differenatial forms so it's a mess to sort out. (For example, Arfken obtains the expressions for the curl and divergence in arbitrary coordinates by taking a ratio of integrals over volumes of surfaces in a certain limit.) This brings up a mental block for physicists learning differential forms: almost everything that they seem to be useful form can be derived without their help, or so it seems.
Best regards
  • #56
Very interesting!
But I am a bit confused by this trick. In other words, the units would give the answer, it would be given by how many factors of "meter" appears in the units.
So a velocity and an acceleration would be vectors. Ok. Butthen, a force would also be a vector. Ok.
Now, using
[tex] \vec{F} = q \vec{E} + q \vec{v} \times \vec{B} [/itex]
this would seem to indicate that the E field is a vector but t hat the B field is a scalar!:confused:
So I am using this trick incorrectly?
  • #57
Well, the first thing is that cross products should always make you suspicious. :smile:
While the test I listed does distinguish amongst the things I listed, it can't tell the difference between a scalar and a rank-(1,1) tensor. :frown: I was assuming we weren't considering any of those!
If, by B, you mean the "thing that takes a velocity as input and gives you the value of magnetic force", then B really should be an (antisymmetric) rank-(1,1) tensor.
But I usually hear B specified as a pseudovector -- which usually means that you really should be using bivectors. In that case, the cross product becomes the dot product of velocity along one index of B -- in particular, the metric appears. (And the quadrupling of B exactly cancels the one-fourth that gets applied to the metric)
I'm not really sure about the "right" definitions of things if you stick to three-vectors. It's all behaves much more nicely in 3+1 dimensions.
  • #58
There is a group of electrical engineering professors at BYU that uses differential forms to teach electromagnetic theory. They have a website related to using differential forms in teaching EM theory. You might look around this site. The site does include stuff they hand out to students that give correct derivations of the laws of electromagnetism using differential forms and hodge star duality. (Note that if you do a google search on 'differential forms', this is one of the links on the first page at present.) Here is the page. Hope the materials are as useful to you as they have proved to me:
http://www.ee.byu.edu/forms/forms-home.html
  • #59
Thank you. Very nice link. I appreciate you posting this.
  • #60
Lest the answer the question get buried...
(Edit: Sorry all, just noticed that nrqed resurrected a thread from back in June rather than starting a new thread, which might have been a better idea.)
nrqed said:
In differential geometry, the usual curl operation that we are familiar with from elementary calculus is generalized to [itex] \,^*dA [/itex] (where A is a one-form). In three-dimensions, this gives back a one-form.
Now, the components of this one-form are [itex] \sqrt{g} \epsilon_{ijk} \partial^j A^k [/itex].
however, the corresponding contravariant components are [itex] \frac{1}{\sqrt{g}} \epsilon^{ijk} \partial_j A_k [/itex].
Now, to obtain the formula that we learned in elementary calculus, it is the second form that must be used. Why is that the case?
Because the elementary vector calculus results depends upon a coincidence of small dimensions, that two-forms are dual to one-forms, and the second formula expresses that duality.
By the way, I'd urge you to use frames and to lose the \sqrt{g} factors, which aren't helping. For example, the classic book by Flanders, Differential Forms with Applications to the Physical Sciences, Dover reprint, uses frame fields. You'll learn other cool things, like how to do Riemannian geometry with frames and coframes (bases of orthonormal vectors and covectors, resp.).
nrqed said:
On the other hand, if one looks at the generalization of the gradient, it's the formula for the covariant components of [itex] d \phi = \partial_i \phi [/itex] that one must use to get the usual formula we have learned for the gradient.
Right, no duality involved in this one, so curl of function = gradient in all dimensions.
nrqed said:
I am sure there is something fundamental going on here that I am obviosuly completely missing.
The Hodge dual is your friend :wink:
Here's another question to make you think: what can you say about the variety of closed one-forms? (A form [itex]\sigma[/itex] is closed if [itex]d \sigma=0[/itex]).
  • #61
Recommend some reading
Glad you are interested in learning how physics employs exterior calculus! One good books for mathematicians who wish to learn a bit about physics might be:
Frankel, Geometry of Physics, Cambridge University Press. (Just skim the mathematical exposition; there is plenty of exposition of physics to be found.)
Going in the other direction:
Isham, Modern Differential Geometry for Physicists, World Scientific, 2005. (Covers basic manifold theory and exterior calculus too.)
  • #62
The two vector expressions for the curl (with contravariant and covariant basis vectors, respectively, inserted into the sums) are not equal. Only the second form (with covariant basis vectors and contravariant components) can be derived rigorously from the curl, a vector defined in the Cartesian frame. (Note, you must equate vectors, not components.)
You cannot transform the second (correct) form into the first form because elements of the metric tensor do not commute with the differential operator. If the generalized frame metric tensor components are all constants the two forms give the same result for the curl.
  • #63
I did not read the pages 2-4, but think about what happens when there is no metric: if you can define something without using a metric, it is more fundamental than the dual.
  • #64
Sorry about this, but none of these formulas seem to work out for me so
could someone tell me where I'm going wrong? I
guess starting with the simplest one, the proposed form for the gradient of
a scalar field in terms of the exterior derivative is:
[tex](d\phi)^t[/tex]
where the transpose of a covariant vector is obtained by applying the
contravariant metric tensor. I'm going to write a one-form as [tex]df[/tex] and a directional derivative along a coordinate x as [tex]\partial x[/tex]. I'll only write [tex] \partial_x [/tex]
when I'm taking a derivative of a function rather than talking about a vector field.
In a euclidean space the contravariant metric tensor can be expressed in cartesian
coordinates as:
[tex]g = \partial x \otimes \partial x + \partial y \otimes \partial y +
\partial z \otimes \partial z [/tex]
Let's pretend I'm interested in cylindrical coordinates
[tex](r,\theta,z)[/tex] because they require the least typing:
[tex]
x = rcos(\theta)
[/tex]
[tex]
y = rsin(\theta)
[/tex]
[tex]
z = z
[/tex]
I can take some derivatives to obtain:
[tex]
\partial x = (x/r)\partial r + (-y/r^2)\partial \theta = cos(\theta)\partial
r - (sin(\theta)/r) \partial \theta
[/tex]
[tex]
\partial y = (y/r) \partial r + (x/r^2) \partial \theta =
sin(\theta)\partial r + (cos(\theta)/r) \partial \theta
[/tex]
I then will get by substitution that:
[tex]
\partial x \otimes \partial x = cos^2(\theta) \partial r \otimes \partial r
+ (sin^2(\theta)/r^2) \partial \theta \otimes \partial \theta +
(-cos(\theta)sin(\theta)/r) \partial \theta \otimes \partial r +
(-cos(\theta)sin(\theta)/r) \partial r \otimes \partial \theta
[/tex]
[tex]
\partial y \otimes \partial y = sin^2(\theta) \partial r \otimes \partial r
+ (cos^2(\theta)/r^2) \partial \theta \otimes \partial \theta +
(cos(\theta)sin(\theta)/r) \partial \theta \otimes \partial r +
(cos(\theta)sin(\theta)/r) \partial r \otimes \partial \theta
[/tex]
Substituting those into the metric tensor in cartesian coordinates I get:
[tex]
g = \partial r \otimes \partial r + (1/r^2) \partial \theta \otimes \partial \theta
+ \partial z \otimes \partial z
[/tex]
I'm pretty sure that's the standard result you should get because it's the inverse of the covariant metric guy.
So to obtain the cylindrical coordinates gradient, I start by taking the
0-form [tex]\phi[/tex] and applying an exterior derivative:
[tex]
d\phi = (\partial_r \phi) dr + (\partial_\theta \phi) d\theta + (\partial_z \phi) dz
[/tex]
He's a one-form, and I'm interested in a vector, so I apply the metric tensor:
[tex]
(d\phi)^t = \partial r <\partial r,(\partial_r \phi) dr + (\partial_\theta \phi) d\theta + (\partial_z \phi) dz> + (1/r^2) \partial \theta <\partial \theta, (\partial_r \phi) dr + (\partial_\theta \phi) d\theta + (\partial_z \phi) dz> + \partial z <\partial z, (\partial_r \phi) dr + (\partial_\theta \phi) d\theta + (\partial_z \phi) dz>
[/tex]
[tex]
= (\partial_r \phi)\partial r + ((\partial_\theta \phi)/r^2) \partial \theta
+ (\partial_z \phi) \partial z
[/tex]
That's sort of messy but those [tex]<x,y>[/tex] are supposed to be a natural pairing as Bishop and Goldberg say it.
If I'm supposed to assume that the classical gradient is this where you substitute
[tex]
\partial r \rightarrow \hat{r}
[/tex]
[tex]
\partial \theta \rightarrow \hat{\theta}
[/tex]
[tex]
\partial z \rightarrow \hat{z}
[/tex]
then this is off by a factor of [tex]1/r[/tex] along the [tex]\theta[/tex] direction from the normal definition:
[tex]
(\partial_r \phi)\hat{r} + ((\partial_\theta \phi)/r) \hat{\theta}
+ (\partial_z \phi) \hat{z}
[/tex]
Any thoughts on where I went wrong?
  • #65
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
In your derivation above, you used coordinate vectors. This is very natural when you are using the modern differential geometry approach. However, the equation for the gradient is often presented using unit vectors rather than coordinate vectors. I think this is the source of your problem. It looks like [tex]\hat{\theta}[/tex] represents a unit vector, whereas [tex]\partial \theta[/tex] is a coordinate vector. The correct substitution is:
[tex]
\partial \theta = r \hat \theta
[/tex]
I believe that the overall derivation was correct. It seems to just be the last step substituting coordinate vectors with unit vectors that caused problem. The unit vector substitutions for r and z were OK since unit vectors and coordinate vectors are the same length for r and z in cylindrical coordinates.
  • #66
Alright, thanks. That seems to be my whole problem. It looks like I get the right expression for div A from
[tex]
*d(*A^t)
[/tex]
and curl A from
[tex]
(*dA^t)^t
[/tex]
just like it says in the thread as long as I consider my components to be in the form of the [tex]A^i[/tex] in
[tex]
\Sigma_i \frac{A^i \partial_i}{g(\partial_i,\partial_i)^{1/2}}
[/tex]
