MHB Why Does \( p \) Divide \( f \) in Nicholson's Theorem 11?
Math Amateur
MHB
I am reading W. Keith Nicholson's book: Introduction to Abstract Algebra (Third Edition) ...
I am focused on Section 4.2:Factorization of Polynomials over a Field.
I need some help (with an apparently very simple issue) with the proof Theorem 11 on pages 217 - 218 ... just seem to have a mental block ... :(
The relevant text from Nicholson's book is as follows:https://www.physicsforums.com/attachments/4594
https://www.physicsforums.com/attachments/4595In the above text we read the following:
" ... ... In the second case, $$p = ad, a \in F$$, so $$p$$ divides $$f$$ (because $$d$$ divides $$f$$) ... ... "Nicholson argues that because $$d$$ divides $$f$$ we then have that $$p$$ divides $$f$$ ... ... but I cannot frame a formal and rigorous argument to show this ...
I must say that I suspect the argument is very simple ... but I would welcome help to get over this sticking point ...
Hope someone can help ...
Peter
Hi Peter,
There is a difference between using simple or strong induction.
Suppose we want to prove some property $P$ for all natural numbers.
If we use simple induction then we will do what you expect, assume $P(n)$ is true and then prove $P(n+1)$.
But, if we use strong induction we will assume $P(i)$ true for all $i<n$ and then prove $P(n)$, and that's what Nicholson is doing here.
He assumes that every polynomial of degree $d<n$ has a unique factorization, and then proves that a polynomial of degree $n$ also has a unique factorization.
EDIT:POSTED IN THE WRONG THREAD
Hi Peter,
$a$ is a non zero element in the field $F$, and we got the two equalities:
$p=ad$, or equivalently $a^{-1}p=d$ (remember $F$ is a field so every non zero element has an inverse)
$f=kd$ for some $k\in F[X]$.
Hence, $f=k(a^{-1}p)$.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
