Why does piezoelectric need amplifying?
In summary, a piezoelectric device, such as an ultrasound machine, works by converting electrical impulses to vibrations in the piezoelectric crystal. This vibration causes a potential difference, which produces a current that is amplified and sent down the cable. The signal from the device needs amplification because the echoes received by the transducer are weak and do not produce a detailed image on their own. The ultrasound machine display is digital and has a threshold level, but the specific range of values it responds to is unknown.
Daniel2244
125
Descibe[/B] in detail the contruction of a piezoelectric device (ultrasound machiene) and how it works. And explain why the singal from that device need amplification
Electrical current passes to the piezoelectric crystal (non-conductive material, no charge in any arrangement) and electrical pressure is experienced. The pressure causes the crystals to contarct/expand and virbate which causes the molecules to move causing an imbalance of charge making one electrode more positive then the other producing soundwaves. These soundwaves reflex from organs etc and are received by the transducer probe. The pressure from the waves casue the molecules in the crystals to move causing an imbalance in charge making one metal plate positively charged and the other negitively charged creating a potential difference producing a current which flows down the cable.
Amplification is used to increase the size of the electrical pulses coming from the transducer after an echo is received. This is becasue the electrical signal is too small to produce a detailed image
(I am really struglying with why the signal needs amplifying as I can't find an explanation)
As you say, it is non conducting, so it's a matter of potential, not current.
What is electrical pressure? Do you mean potential?
Yes, apart from the typos.
You have correctly described going from electric impulses to vibration, but now you seem to be going back the other way. Delete this.
Again, it is more a matter of potential than current.
Not so much a question of detail, just too small to produce any image.
Likes Daniel2244
I think that is a good start. Why is the signal too small to produce an image? (And please note @haruspex comment - it's not the detail that is the problem.) What kind of device are you using to display an image?
Is it analog? If so, what range of values of the input signal does the display device respond to?
Is the image a bitmap? What is the display's threshold level?
Is it a digital representation in which each pixel has a range of potential values? What is the range of inputs of the A/D converter?
How does the output level of the piezoelectric crystal compare to the input level(s) of the display device?
Could I say voltage is passed to the crystals?
Yes
I read somewhere that the crystals are non conductive and they have a neutral charge because the charges of the molecules cancel each other out. And when pressure was put on this material it caused the molecules to move making one plate positively charge and the other negatively charged creating a potential difference . (link to video: ).Another website put it saying as the material got hit, squeezed etc it increasing or decreasing the space between the atoms by squeezing, hitting, or bending the crystal can cause the electrons to redistribute themselves and cause electrons to leave the crystal, or create room for electrons to enter the crystal. A physical force on the crystal creates the electromotive force that moves charges around a circuit. (link: https://www.allaboutcircuits.com/technical-articles/how-piezoelectric-speakers-work/)
creating a potential difference producing a current which flows down the cable. //
So could I say voltage?
The signal is to weak to produce an image because the echoes received by the transducer has less energy as the sound wave diminishes as it propagates through the body and when it is reflected therefore only produces small electrical impulses.
I am using the ultrasound machine display.
I have wrote that it is digital but other than that I couldn't find anything else.
I don't know what that is, will do some research
The output is larger than the imput because the waves diminish
Yes, but in what you wrote you confused the two directions of the effect.
When a voltage is applied, it causes the crystal to expand or to contract. This is the effect the device uses to create the ultrasound.
Conversely, when the crystal is stretched or compressed it generates a voltage. This is the effect used to detect the reflected ultrasound.
Because the voltage generated by the reflection is much smaller than the one used to drive the vibration, some clever electronics disables the detection circuit during the driving phase.
Note also that if applying a positive voltage to one side causes contraction then compressing the material will cause a negative voltage on that side. This 'reversal' is common to many reactive processes. E.g. in electromagnetism.
Likes Daniel2244
Related to Why does piezoelectric need amplifying?
1. Why is amplification necessary for piezoelectric materials?
Amplification is necessary for piezoelectric materials because they produce very small electrical signals when pressure is applied. These signals are not strong enough to be used in most applications, so they need to be amplified to be useful.
2. Can't piezoelectric materials be used without amplification?
While it is technically possible to use piezoelectric materials without amplification, the resulting signals would be too weak to be of any practical use. Amplification is necessary to make the signals strong enough to be measured and used in applications.
3. How does amplification work in piezoelectric materials?
Amplification in piezoelectric materials works by using an external power source to increase the voltage of the electrical signal produced by the material. This can be done through a variety of methods, such as using an amplifier circuit or a transformer.
4. What are the benefits of amplifying piezoelectric materials?
Amplification allows piezoelectric materials to be used in a wide range of applications, such as sensors, actuators, and energy harvesting devices. It also improves the accuracy and sensitivity of the material's response to pressure, making it more useful for precise measurements.
5. Are there any drawbacks to amplifying piezoelectric materials?
One potential drawback of amplifying piezoelectric materials is that it can introduce noise into the signal. This can be mitigated through careful design and selection of amplification methods. Additionally, amplification requires an external power source, which adds complexity and cost to the overall system.
  • Electrical Engineering
15K
