Why Does Subtraction Become Addition in Composite Functions?
In summary, the conversation is discussing the concept of composite functions and how the minus symbol can be transformed into an addition symbol. The key point is that subtracting a number is the same as adding the negative of that number.
mitchconnor
g(x)=−4x2−5x
f(x)=−3x2+7x−5(g(x))
f(g(−1))=?
First, let's solve for the value of the inner function, g(−1). Then we'll know what to plug into the outer function.
g(−1)=−4(−1)2+(−5)(−1)I don't understand why they transformed the minus symbol into an addition symbol. This has happened a few times now. Every time I think I get an answer, I get hoodwinked by this change!
Help would be much appreciated.
Mathematics news on Phys.org
Re: Composite function troubles~
Note that:
\(\displaystyle -4(-1)^2+(-5)(-1)=-4(-1)^2-5(-1)\)
I would choose to write it they way it is on the right, but both are equivalent. It boils down to the fact that subtracting a number is the same as adding the negative of that number:
\(\displaystyle a-b=a+(-b)\)
FAQ: Why Does Subtraction Become Addition in Composite Functions?
What is a composite function?
A composite function is a mathematical concept that involves combining two or more functions to create a new function. The output of one function becomes the input of the other function.
Why do composite functions sometimes cause troubles?
Composite functions can be tricky because they involve multiple steps and can be difficult to simplify. Additionally, errors in the composition process can lead to incorrect results.
How do I evaluate a composite function?
To evaluate a composite function, you must first substitute the inner function into the outer function. Then, simplify the resulting expression using algebraic rules and properties.
Can I use the same variable for both functions in a composite function?
Yes, it is common to use the same variable for both functions in a composite function. However, it is important to pay attention to the order in which the functions are composed to avoid confusion.
How can I avoid mistakes when working with composite functions?
To avoid mistakes when working with composite functions, it is important to carefully follow the order of operations and use parentheses to clearly indicate which function will be applied first. It can also be helpful to double-check your work and use a calculator to check your results.
