gary350
- 274
- 66
- TL;DR Summary
- WHY does Sun set look different than Sunrise?
WHY does Sun set look different than Sun rise?
Since you didn't say how you think they look different and I've never noticed such a thing, I can only speculate as to what you mean or why: The weather at sunset is usually warmer than at sunrise and the relative humidity lower, wind stronger, clouds higher, atmosphere more turbulent, etc. These factors will affect the way sunset vs sunrise look, but they are not going to be consistent. They can be inverted.gary350 said:WHY does Sun set look different than Sun rise?
Kind of. Yes, there will generally be a little bit more absolute humidity in the evening, but not much. The relative humidity on the other hand is vastly different (lower in the evening), and that's what affects the transparency of the atmosphere.hmmm27 said:...if true - I suspect it may have to do with the amount of water vapour in the atmosphere : more in the evening, less in the morning.
Well let's try to analyze that in the context of the OP.256bits said:An old saying "Red sky at night, sailor's delight. Red sky in morning, sailor's warning." was actually a line of sight weather prediction of an approaching storm, or clear skies, which for a sailor you might want to know of rough seas ahead or wind for your sails.
It would matter if weather comes from the east or west. No.russ_watters said:Well let's try to analyze that in the context of the OP.
The atmosphere scatters blue light and makes direct sunlight redder. But it isn't "red sun" it is "red sky", so what is needed is a low transparency of the sky to reflect the red light from the sun. So that means high relative humidity. Frankly it seems at first counter intuitive to me, since red sky in the morning should be a normal thing whereas red sky at night should mean very humid air and clouds/storms.
...but maybe someone has another interpretation?
256bits said:It would matter if weather comes from the east or west.
256bits said:don't cyclones and hurricanes come from the east
Quite right.PeterDonis said:They generally travel westward in the tropical latitudes, but typically recurve back eastward as they move to higher latitudes.
gary350 said:Summary:: WHY does Sun set look different than Sunrise?
gary350 said:Look at sun set every evening it is 90% red light. Look at early morning sun set not much red light. I read atmosphere on horizon makes red light but why not early morning? Sun is about 8 minutes ahead of what we actually see. Morning sun is already up 8 minutes above horizon before we actually see it. Evening sun is 8 minutes below horizon and we still see it. I wonder if angle of light is doing something simular like rainbow does refractor makes all other color light be gone on horizon so we only see red.
Most people go crazy over a red sun set but that is like comparing a dark gray over cast rainy day to a nice sunny day. I like nice bright morning sun rise much better than dark red sun set.anorlunda said:I hope this is not too off-topic. It is related.
My experience standing watch at sea is that the moon illusion, is more noticeable at moonrise than at moonset. The illusion is that the Moon appears to be larger when near the horizon.
But I also have a human psychology theory for the asymmetry. Moonrises at sea are startling, and thus memorable. Unlike sunrise, moonrise is not preceded by a glow in the sky giving advance warning. As you scan the horizon, all of a sudden a big red light appears. Your heart skips a beat as you fear getting run over by a huge vessel. It takes 5 seconds for the brain to analyze and conclude that it is the moon. That moment of fear makes the memory strong. My wife and I found that no matter how many times it happened before, we were still surprised and startled by the next moonrise.
But moonset is uneventful and forgettable, so you tend to stare at it less and you miss seeing the moon illusion.
So my theory is just that we scrutinize and remember moonrises more than moonsets. It is a self-created illusion. That is similar to what I said in #9 about sunrise/sunset.
Edit: I should have mentioned that this applies only when the moon rises at night.
But rainbows are seen when the Sun is behind you. Red sky is caused by scattering and not by refraction.gary350 said:Sunset is actually a red color rainbow when sunlight is at 42 degree angle to our eyes.
During sunset and sunrise, the light from the sun has to travel through more of Earth's atmosphere before reaching our eyes. This causes the shorter blue and green wavelengths of light to scatter more, leaving longer red and orange wavelengths to reach our eyes, giving the sky its vibrant colors.
When the sun is near the horizon, it is actually farther away from us than when it is directly overhead. This is due to the curvature of the Earth, which makes the sun's position appear lower in the sky. This creates an optical illusion that makes the sun appear larger.
The purple color in the sky during sunset and sunrise is caused by a combination of the scattering of light and the Earth's shadow. As the sun sets or rises, its light passes through more of the Earth's atmosphere, causing the blue and green wavelengths to scatter. This leaves behind the longer red and orange wavelengths, which mix with the Earth's shadow to create a purple hue.
Similar to the purple color, the pink hue in the sky during sunset and sunrise is also caused by the scattering of light and the Earth's shadow. However, in this case, the Earth's shadow is not as prominent, allowing more of the red and orange wavelengths to reach our eyes, creating a pinkish color in the sky.
During sunset and sunrise, the sun's position in the sky changes due to the Earth's rotation. This change in position can create an illusion that the sun is changing shape, when in reality it is just appearing to move closer or farther away from us due to the curvature of the Earth.
