Why does the amount of Refraction depend on wavelength?
In summary, the refractive index of a material is influenced by the natural frequency of its electrons and the phase difference between incident light and electron oscillations. However, the resonance of these electrons occurs outside of the visible region, so the refractive index for red light is lower than for violet light. This suggests that the electrons of all materials may resonate or nearly resonate with red light's frequency, but the maximum and minimum refractive indices for different materials will occur at different wavelengths outside of the visible region.
Fiona Rozario
55
I understand that electrons of a material have a natural frequency of vibration and the refractive index results from the phase difference between the incident light's field oscillations and the field oscillations of these electrons. (https://physics.stackexchange.com/questions/71126/why-does-the-refractive-index-depend-on-wavelength) So the refractive index will be the least for a light frequency which is close to the natural frequency of the electrons of that material.
So how is it that refractive index of materials is the least for red and most for violet? Does this mean that electrons of all materials resonate or nearly resonate with red light's frequency? Shouldn't each material's refractive index be maximum for a different wavelength (frequency) and minimum for a different wavelength (frequency)?
Science news on Phys.org
" Does this mean that electrons of all materials resonate or nearly resonate with red light's frequency?"
Any resonance occurs OUTSIDE the visible region. If you look at the curve in the stack exchange post, you will see that the index n is higher for blue than red, whether the resonance is above or below the visible region.
Related to Why does the amount of Refraction depend on wavelength?
1. Why does the amount of refraction change with different wavelengths of light?
The amount of refraction changes with different wavelengths of light because different wavelengths of light travel at different speeds through a medium. This is due to the fact that the refractive index of a medium is dependent on the wavelength of light. As a result, the amount of bending or refraction of light will also vary with different wavelengths.
2. How does the refractive index of a medium affect the amount of refraction?
The refractive index of a medium is a measure of how much the speed of light is reduced when it passes through that medium. The higher the refractive index, the slower the speed of light. Therefore, the amount of refraction will be greater in a medium with a higher refractive index compared to a medium with a lower refractive index.
3. What is the relationship between wavelength and refractive index?
The relationship between wavelength and refractive index is inverse. This means that as the wavelength of light decreases, the refractive index of a medium will increase. This is why different wavelengths of light experience different amounts of refraction in a medium.
4. Why does refraction occur in the first place?
Refraction occurs because light travels at different speeds through different mediums. When light travels from one medium to another, it changes speed and this causes a change in direction. This change in direction is known as refraction.
5. Can the amount of refraction be controlled?
Yes, the amount of refraction can be controlled by changing the angle at which light enters a medium. This is known as the angle of incidence. By changing the angle of incidence, the amount of refraction can be increased or decreased. Additionally, the refractive index of a medium can also be altered by changing its temperature or pressure, which will in turn affect the amount of refraction.
