sameeralord
- 662
- 3
Hello guys,
This is from an article I recently read. I have not done any aerodynamics but I'll be so greatful if anyone can explain what this guy means. What I'm thinking is if turbulent air delays the separation of air and the smooth air separates wouldn't the ball swing to the smooth side first and then to the turbulent side when that separates. Also why does turbulent air have lower pressure, in a tube if a fluid is turbulent wouldn't it exert higher pressure on the walls. Thanks guys![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So how and why does a cricket ball swing in the conventional mode?
Let us see what happens to the flow over a cricket ball released with the seam angled (Fig. 1). Between about 30 and 70 mph, the laminar boundary layer along the bottom surface separates at about the apex of the ball. However, the boundary layer along the top surface is tripped by the seam into a turbulent state and its separation is therefore delayed. This asymmetry results in a pressure differential (lower pressure over the top) and hence side force which makes the ball swing in the same direction that the seam is pointing (upwards).
