MHB Why does the equality hold for a symmetric matrix $A$ with $A = A^{T}$?
  • Thread starter Thread starter evinda
evinda
MHB
Hello! (Wave)For $A \in \mathbb{R}^{n \times n}$ with $A=A^{T}$ we set:
$$\lambda:= \max \{ \langle x, A x \rangle: ||x||_2=1\} \\ \mu:= \min \{ \langle x,A x \rangle: ||x||_2=1\}$$
Then for $x \in S_{||\cdot||_{2}}$ we have:
$$\langle x, Ax \rangle \leq |\langle x, A x \rangle| \leq ||x||_2 ||Ax||_2 \leq ||A|| ||x||_2^2=||A||$$
i.e. $\sup_{||x||_2=1} ||Ax||_2 \leq ||A||$
and since $\sup_{||x||_2=1} |\langle x, Ax \rangle|= \max \{ |\lambda|, |\mu|\}$ we have that $\max \{ |\lambda|, |\mu|\} \leq ||A||$.
  • Why does it hold that $\sup_{||x||_2=1} |\langle x, Ax \rangle|= \max \{ |\lambda|, |\mu|\}$ ?
Theorem
If $A \in \mathbb{R}^{n \times n}$ symmetric matrix then
$$||A||= \sup \{ ||Ax||_2: ||x||_2=1\}= \sup \{ |\langle x, Ax \rangle|: ||x||_2=1\}= \max \{ |\lambda|, |\mu|\}$$
Proof:
It remains to show that $||A|| \leq \sup \{ |\langle x, Ax \rangle|: ||x||_2=1\}:=a$
$$||Ax||_2^2=\frac{1}{4} (4 ||Ax||_2^2)=\frac{1}{4}(4 \langle Ax, Ax \rangle)=\frac{1}{4} ( 2 \langle Ax,Ax \rangle+2 \langle A^2 x, x \rangle) \overset{\text{ for an arbritary } \gamma>0}{=} \frac{1}{4}(\langle A(\gamma x+ \gamma^{-1} Ax), \gamma x+ \gamma^{-1} Ax \rangle- \langle A(\gamma x- \gamma^{-1}Ax), \gamma x-\gamma^{-1}Ax) \leq \frac{1}{4}(a ||\gamma x+ \gamma^{-1}Ax||^2+a ||\gamma x-\gamma^{-1}Ax||^2) \leq \frac{a}{2}(||x||_2^2 \gamma^2 + ||Ax||_2^2 \frac{1}{\gamma^2})$$
We set $f(\gamma)=||x||_2^2 \gamma^2 + ||Ax||_2^2 \frac{1}{\gamma^2})$ and check where $f$ achieves its minimum.
  • Could you explain me why the following equality holds?
$$\frac{1}{4} ( 2 \langle Ax,Ax \rangle+2 \langle A^2 x, x \rangle) \overset{\text{ for an arbritary } \gamma>0}{=} \frac{1}{4}(\langle A(\gamma x+ \gamma^{-1} Ax), \gamma x+ \gamma^{-1} Ax \rangle- \langle A(\gamma x- \gamma^{-1}Ax), \gamma x-\gamma^{-1}Ax) $$
Did you try to expand the right hand side of the wanted equality?
Yes, I did. I saw that the equality holds. (Nod)
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
