Irfan Nafi
- 34
Jupiter's spins the same way the Earth does, so the Coriolis effect should make the Great Red Spot spin clockwise, but it's an anti-cyclone. Why is that?
Same as if you blow up a balloon.Irfan Nafi said:Why does gas try to flow away in a high pressure region?
Yes, the air masses are attempting to reach equilibrium.Irfan Nafi said:So because of the high pressure the surrounding is trying to find equilibrium?
The Great Red Spot is a giant storm on the planet Jupiter that has been continuously observed for over 300 years. It is a swirling, oval-shaped disturbance in the planet's atmosphere that is larger than Earth.
The Great Red Spot gets its name from its red color, which is caused by the presence of trace amounts of compounds such as phosphorus and sulfur in the planet's atmosphere. These compounds react with sunlight and produce a red hue.
The Great Red Spot is located in the southern hemisphere of Jupiter and is influenced by the planet's strong winds and jet streams. These winds move eastward, causing the storm to spin in a counter-clockwise direction.
The Great Red Spot has been observed since the 17th century, making it one of the longest continuously observed weather phenomena in our solar system. However, it is possible that the storm has been spinning for even longer, as there is evidence of a similar storm in ancient recordings from the 12th century.
While the Great Red Spot has been observed for hundreds of years, it is not known if it will last forever. Scientists have observed changes in its size and shape over time, and some believe that it may eventually dissipate or merge with other storms on the planet.
