John Constantine
- 19
- 4
- TL;DR Summary
- Energy consumption and transmission of muscles
This may seem like an obvious and foolish question intuitively, but I am curious about something. Let's assume we are performing a biceps curl exercise. To properly analyze human movement, a much more complex process is needed, but I will simplify it as much as possible. As the name of the exercise suggests, most of the energy required for this exercise will come from the biceps. However, there are also the forearm and hand that support the object, and the shoulder that stabilizes the entire arm and object.
The work done by the forearm and hand on the object is the product of the force supporting the object and the distance the object has moved. This will undoubtedly have a specific value. The shoulder also does work on the entire arm. This is defined as the force the shoulder exerts to support the arm multiplied by the distance the center of mass of the arm has moved. Thus, the work done by the forearm and hand on the object, and the work done by the seemingly stationary shoulder on the entire arm, can both be defined.
If A does work on B, B's kinetic energy increases, but it does not always mean that A has to lose the same amount of energy. Therefore, even though there is work done by the shoulder and forearm on the object, they do not need to use a corresponding amount of energy. It is intuitively clear that the forearm, hand, and shoulder do perform work on the object, but their energy consumption is low, and most of the energy comes from the biceps.
However, aside from intuitive methods, is there a more physical approach to understand why the biceps primarily consumes energy? I do not want specific numbers or diagrams, but I am curious about how energy transfer or consumption occurs.
You don't necessarily have to use human exercise as an example. For instance, in an excavator, most of the mechanical energy is converted from electrical energy, but the arm lifting the object and the body providing support also do work, which can be defined. Even if A does work on B, A's energy consumption can be minimal, or A might consume more energy than the work done on B. How do we distinguish this?
