Why does the permeability of free space invoke pi?
In summary, the permeability of free space is defined as 4pi x 10^-7 N*A^-2, which is not a magical value but rather a result of the definition of the Ampere and its relationship to magnetism. This value is also related to the speed of light due to the quadrature relationship between electric and magnetic forces, which is represented by pi. This can be seen in Maxwell's equations, where the value of 4pi is absorbed into the constant mu_0 when using Gaussian units.
connorb1542
I'm not asking a question of what is permeability, but rather why is pi involved in its definition of 4pi x10^-7? As far as I know, pi is generally only used whenever dealing with a circle. How does the idea of magnetism relate to a circle?
Astronomy news on Phys.org
That value for the permeability of free space has the units N*A-2. The A being amperes. The Ampere is defined as being the current maintained in two wires a distance of 1 meter apart that would generate a force of 2x10-7N/m. Given this definition, along with Ampere's force law, F=([itex]\mu[/itex]0I2)/(2[itex]\pi[/itex]r), we can see that the permeability of free space is exactly 4[itex]\pi[/itex]x10-7N*A-2. There's nothing magical about it, unfortunately, it's just the way we define the ampere that makes that value the way it is. Any constant could have any value if we just change the units and how they are defined =)
Likes tefekkur_yolcusu and yucheng
True, but then why is it that 1/sqrt(με) is equal to the speed of light? How is it that two arbitrarily defined constants can be combined in this way to produce the speed of light?
Eugene Wigner's article "The Unreasonable Effectiveness of Mathematics in the Natural Sciences," in Communications in Pure and Applied Mathematics, vol. 13, No. I (February 1960) opens with almost the exact same question. It's an excellent article, well worth reading.
http://www.dartmouth.edu/~matc/MathDrama/reading/Wigner.html
Likes yucheng
Using Maxwell's equations you can derive the wave equation for an electromagnetic wave, it turns out that the velocity of that wave would be 1/sqrt(mu * epsilon). Those constants are not arbitrary, they are determined experimentally. When Maxwell first derived the wave equation for an electromagnetic wave he realized the velocity was extremely close to the value of the speed of light. He used that fact to realize that light must be an electromagnetic wave.
so then if the constants are derived experimentally, and mu is not just a result of how we define the ampere, I go back to my first question: why pi? where does the pi come from?
Pi has been known to be associated with spheres as well as circles.
Whenever you deal with two things that relate to each other in a quadrature relationship at right angles, where some total vector is always the quadrature sum of these two, then you are dealing with a circle. At least you'll have to deal with squares and square roots. Then if you need to work with the circumference or area, the value of Pi will kick in as the non-arbitrary relationship between vectors and the containing area. Magnetism will relate to this because it also involves electrical forces which are at right angles, and together form a circle.
I hope I explained it enough without having to stick you with the formulas that you were questioning in the first place. I know a lot of math oriented people think of the formulas themselves as the absolute foundation and never question why that formula is the way it is. For them, the formula is the way it is. I do like to question why, and explain things in a non-mathematical way. But it's hard to completely get away from at least some math.
The best way I can possibly explain it (given my limited knowledge) is that it certainly has to do with circles/spheres. Take a look at the difference in the way Maxwell's equations look in different units (e.g. SI units and Gaussian units). In Gaussian units you will notice that there are these extra 4pi's. Where as they disappear when you look at Maxwell's equations in SI units.
Ampere's law in SI units (with constant electric field):
[tex]
\vec{\nabla} x \vec{B} = \mu_0 \vec{J}
[/tex]
Ampere's law in Gaussian units (with constant electric field):
[tex]
\vec{\nabla} x \vec{B} = \frac{4\pi}{c} \vec{J}
[/tex]
So you can see in Gaussian units that we have a 4pi whereas in SI units we don't. The 4pi gets absorbed into the constant [tex]\mu_0[/tex]
Is that satisfactory for you?
The free-space permeability is defined, not measured in MKS units. The free-space permittivity is measured.
no it isn't. not since 1983 when they defined the meter to fix c to be 299792458 m/s.
[itex]\mu_0, \epsilon_0, c, Z_0[/itex] are all exact because of the definition of the meter and ampere.
you should take a class in E&M. the last two Maxwell's equations together can form a wave equation and you can derive the wavespeed as [itex] \frac{1}{\sqrt{\mu_0 \epsilon_0}} [/itex] from that wave equation.
it's actually [itex]4 \pi [/itex] and that comes from the formula for the surface area of a sphere. and what the surface area of a sphere has to do with it is about how the inverse-square law fundamentally works. check that out in Wikipedia.
also go to the NIST site for the definition of the Ampere. it's because how the Ampere got defined is why [itex] \mu_0 [/itex] takes on the value it does.
i just graduated from high school, and i took a calculus-based e&m class (AP physics c). unfortunately we didnt cover maxwell's equations together in one place with respect to electromagnetic waves, only independently with emphasis on problem-solving and not theory. so as I'm looking, I'm seeing that the pi either comes from the circular relationship between right angle vectors or from the surface area of a sphere.
it's because how the Ampere got defined is why μ0 takes on the value it does.
if that were true then by redefining the ampere, we would redefine μ0. and by redefining μ0, using the wave equation from maxwells equations to get the wavespeed as 1/sqrt(μ0ϵ0) would yield a different value of c then what we observe, would it not? that's why I've been saying that it can't just have come from the way we define some unit of measurement, because if you redefine the ampere you redefine μ0, and by redefining μ0 you redefine the speed of an electromagnetic wave. and also, if the 4pi came from an INVERSE square law, wouldn't it be on the bottom, in the inverse part? like 1/4pi? in addition, not all equations using μ0 are inverse square laws
If you redefined μ0 by changing the ampere and then proceeded to use 1/sqrt(μ0ϵ0) for the speed of light, you would not be changing the actual speed of light, you would just be changing the units that the speed of light is defined in. The 4pi absolutely comes from surface area of the volume that we are working in.
ah, ok. thank you. I am still not completely certain of the relation between permeability and a spherical volume
I wonder if the pi comes from making an Ampererian loop. But then again when you use amperes law you never draw spheres, just circles or boxes. So I am not sure.
There is a 4[itex]\pi[/itex] inthe permeability of free space due to the way the Ampere is defined, yes, it does have something to do with spheres and inverse square force laws. If you change the definition of the ampere, it doesn't change the speed of light, it just changes the units you're measuring it is, as someone stated. Gotta involve amperes in the permittivity of free space too, I believe, for the units to check out, and then you probably get your SI value for c back or something.
does the 4pi come from the Biot–Savart law and if it does, does the 4pi come from surface area of a sphere?
While thinking this over myself. I do think it came from the Biot-Savart law. I think that they set up some arbitrary magnetic field that can be calculated using the Biot-Savart law. Then they measure the actual magnetic field and compare it to the magnetic field calculated from the Biot-Savart law which enables them to define the constant necessary to make the two equivalent. Since the the law has a 4pi on the bottom, the 4pi was introduced into the permeability of free space in order to cancel them. They did this because you can think of the 4pi in the Biot-Savart law as being a part of the constant of proportionality between calculated and measured magnetic fields. And yes that 4pi certainly comes from an integration over spherical coordinates.
Almost, the Ampere is up for a re-definition quite soon (in a few years). It is likely (not absolutely certain) what will happen is that we will define the value of the electron charge, and then define the Ampere using number of charges/second (instead of the current definition, which no ones is using because it is so awkward to realize, the ampere is in reality usually realized via the Volt and the Ohm).
Now, from what I remember (this has more to do with politics than science, so I've heard various suggestions) this will in turn mean that epsilon_0 will be a measured ("inexact") value whereas mu_0 will still be defined (mainly because the pi is so convenient, there is no "deep" reason). The value of c will of course stay the same.
Note that all of this is provisional, we should now more after the next CGPM meeting.
Also, to those of you who are looking for a "physical" reason for the p: there isn't one; the current definition of the ampere was (arbitrarily) chosen so that mu_0 would have "nice" value; simply because it is convenient.
There should be some relevant links on the wiki for the SI, including info about future re-definitions.
the electric field at distance r from a stationary charge Q is E = Q/4πε0r2
the magnetic field at distance r from a charge Q with speed v (<< c) is B = µ0Qv/4πr2
this is so that the fluxes through a sphere of radius r (with area A(r) = 4πr2) are​
∫ E dA = Q/ε0
and ∫ B dA = µ0Qv = µ0J :smile:
in other words: if we define the coulomb (and the amp) so that the fluxes enclosing a charge Q or a current J are Q/ε0 and µ0J, then we need a 1/4π in the field formulas … we could avoid that by redefining the coulomb (and the amp), but then we'd get a 4π in the fluxes :wink:
i think I've gotten a satisfactory response, thanks to all who responded!
Isn't any definition of the Ampere a current definition? :devil:
Related to Why does the permeability of free space invoke pi?
1. Why is pi involved in the permeability of free space?
The constant pi (π) is involved in the permeability of free space because it is a fundamental mathematical constant that relates the circumference and diameter of a circle. The permeability of free space is based on the magnetic field created by a current flowing through a circular loop of wire, which can be represented by a circle. Thus, pi is necessary to calculate the magnetic field and permeability of free space.
2. How does pi affect the permeability of free space?
The value of pi affects the permeability of free space because it is used in the mathematical equation that relates the magnetic field strength to the current and distance in a circular loop. The higher the value of pi, the stronger the magnetic field and the higher the permeability of free space.
3. Can the permeability of free space be calculated without using pi?
No, the permeability of free space cannot be accurately calculated without using pi. Pi is a fundamental constant that is necessary to accurately represent the relationship between the magnetic field, current, and distance in a circular loop. Without pi, the calculations would be incorrect and the permeability of free space would not be accurately determined.
4. How is the value of pi determined in the calculation of permeability of free space?
The value of pi (π) is a constant that is determined by the ratio of a circle's circumference to its diameter, which has been calculated to be approximately 3.14159. This value is used in the equation for the permeability of free space to accurately calculate the magnetic field strength.
5. Why is the permeability of free space often referred to as "mu naught"?
The permeability of free space is often referred to as "mu naught" because it is represented by the Greek letter mu (μ) with a subscript of zero (0). This notation is used to distinguish it from other permeability values and to indicate that it is the permeability of free space. The use of "mu naught" is a common convention in scientific notation.
  • Astronomy and Astrophysics
  • Classical Physics
