Why does the potential energy get lower as atoms get closer?
In summary, the potential energy between two atoms decreases as they get closer to form a molecule due to the increase of the atoms' kinetic energy. This is a result of the electron density being in a certain configuration, which can change the form of the potential energy curve. When the atoms are far apart, the potential energy is due to gravitational attraction, but as they get closer, the repulsive force between the nuclei becomes dominant and the potential energy increases again. Additionally, the potential energy can reach negative values as the kinetic energy increases, and this is due to the different electron density configurations. Finally, as the atoms get very close, the potential energy increases due to the repulsive force between the nuclei, similar to two N pole magnets pushing each
diogo_sg
Hello. I'm new to this forum and to Physics and Chemistry in general and I have a question that's making me go crazy: why does the potential energy decrease as two atoms (say, hydrogen atoms) get closer to form a molecule? I'm talking about this graphic:
I've read that it's related to the increase of the atoms' kinetic energy, but I'm having a hard time figuring out how and why that happens.
Also, why does the potential energy get negative values and why does it increase again as it passes a certain value (4,52 eV in hydrogen's case)?
I understand that the potential energy changes with the distance between the atoms but I'd like to know why it changes the way it does. And please explain this as good as you can, using whatever Maths you need. I just want to understand this whole situation.
Thank you very much. Diogo
Chemistry news on Phys.org
First you need to know that such potential energy form is a result of the electron density being in a certain configuration. That means, if the electronic density is in another configuration the potential energy curve will have a different form. In the picture above, the electron state is said to be in bonding state because it allows for the two atoms to bind together to form an equilibrium arrangement (this corresponds to the minimum in that curve). Usually in such bonding state, most electrons are found in the volume in between the two nuclei. That's why they can bring those nuclei closer. However, if the two nuclei gets too close past its equilibrium, the repulsive force between them will start to dominate and at some point (when the curve cross the x axis) they will break. As is mentioned in the beginning, different electron density can lead to different potential curve. One worth to mention is the so-called repulsive state where there is small chance to find electrons in the region between the nuclei so that there is no way the repulsive force between them can be compensated. The form of the corresponding potential curve exhibits a monotonically decreasing function (thus, no minimum/equilibrium) toward an asymptotic value when the internuclear distance approaches infinity.
Likes mishaq504 and diogo_sg
Thank you for your fast reply. I understand your explanation (except the final part — why would that function be that way?). Though I'm failing to get in what way your explanation answers my questions.
So...when the atoms are quite far apart it's gravitational attraction at work ... If you hold a ball above the ground it has potential energy , release it and it falls , the potential energy being converted to kinetic energy (velocity) ...it's the same with these atoms , apart the energy is potential and this is reduced the closer they get together , it has to go somewhere and is seen in the increased velocity of the atoms.
When the atoms get very close the two positive nuclei "see" one another and repel, this accounts for the upward movement in the graph (moving right to left) so first they pull together by gravity, then push apart , like two N pole magnets , just as when you push two N pole magnets together there is stored potential energy , so if two atoms become very close there is a force wanting to push them apart , this explains the increase in potential energy on the graph.
Likes diogo_sg
Huh? I always thought that gravitational attractions were too weak to even matter in the atomic scale. That's what I have read in several places, at least.
Thank you. I get all this well. But why does the potential energy (PE) fall to negative values as the kinetic energy (KE) increases? Shouldn't it reach zero and stop decreasing?
Also, as the atoms reach a stable state, their KE falls to zero, right? Because they wouldn't be moving. If so, shouldn't their PE rise? Why does it remain so low?
BvU said:
Correct. Electromagnetic forces are what keeps atoms & molecules busy.
https://en.wikipedia.org/wiki/Intermolecular_force
Then, which interaction(s) draw atoms closer to each other in order to form a molecule? If it isn't gravity, what is it? Can electromagnetic forces pull them together?
google http://ph.qmul.ac.uk/sites/default/files/CM_PHY108_Lecture2_Interatomic%20Forces1b.pdf , covalent bond, etc.
Yes there are errors in my first post concerning gravity..
diogo_sg said:
...why does the potential energy (PE) fall to negative values as the kinetic energy (KE) increases? Shouldn't it reach zero and stop decreasing?
This negative value -4.75 is the energy required to separate them to infinity , they have -ve potential energy , they're stuck together ..
This excelent 3 min video explains all ...
So, let me see if I'm getting this right:
Two atoms are drawn to each other by attractive forces between their nuclei and their electrons. When the atoms are separated, their PE is zero. As they get closer, their PE decreases — it is transformed into KE, which will increase as the atoms are pulled together. When the atoms reach a certain distance, which gives them the stability they need, they form a molecule — this is when the attractions and the repulsions become stable and the PE gets as low as possible. At that point, they will start vibrating (why?) and the values of their PE, KE and internuclear distance will be constantly changing (and is the energy preserved?), with the PE having negative values (I'm still not quite getting why that happens — is it because of the stability of the molecule i.e. the balance between repulsions and attractions? If it is, why does it get to negative values instead of reaching zero and stopping decreasing?). From that point on, if the two atoms get even closer, their PE will increase (and what about their KE?) because the repulsions between the two nuclei will become more and more intense (what about electronic repulsions? Will the electrons move to opposite zones of the electronic cloud in order to lower repulsive forces between them?) (and shouldn't the PE stop growing as it reaches zero? Because at that point is when the molecule breaks, so there shouldn't be any PE left — we would be back to the beginning state, correct?).
What do you think?
Generally, when you form a very stable bond (stable bonds have very deep potential energy wells), the energy gets released as heat (e.g. think of the explosions that result when some chemical reactions occur).
As for why the PE is negative, remember that the potential energy values don't matter. It's only the changes between potential energy values that matter. We arbitrarily define the state where PE = 0 to be the case where the two atoms are completely isolated from each other. So here, the negative value of the potential energy just means that bonded atoms have a lower potential energy than unbonded atoms. Why is this? Well, as others have mentioned, atoms attract each other (do you understand the nature of these attractive forces?). In other words, the atoms exert forces on each other. As the atoms move closer together, these forces are doing work and, because the force is acting in the same direction as the movement, the work decreases the potential energy.
Likes diogo_sg
I didn't quite get what "very deep potential energy wells" means. As for the rest, I think I get it. So, when a molecule is formed, there is a decrease of the PE between the atoms, because the PE is transformed into KE. Then, as the molecule becomes stable (as it stops?), it will release some energy as heat.
Ah, that makes a lot more sense, yes. I wasn't looking at things that way, but now I get it.
Correct me if I'm wrong, but aren't those electrostatic interactions i.e. attractive forces between two opposite charges (a proton and an electron)?
Why does the direction of the force being the same as that of the movement lower the PE?
By deep, I mean values that are more negative.
Think of the potential energy curve as an actual landscape, and imagine rolling a ball down the PE curve. The ball will roll down to the minimum of the curve, but it's kinetic energy will carry it past the equilibrium and up the steep repulsive slope of the curve. The ball will eventually fall back down, and if no energy was lost, the ball will have enough momentum to carry it back out to where PE = 0. This happens a lot in intermolecular interactions—two molecules colliding in an unproductive reaction.
How a chemical bond forms is when your molecules have collided together and collide with a third molecule, transferring some of their kinetic energy to that molecule. Now, the total kinetic + potential energy of the system will not allow the two molecules to fly apart. If you think back to the rolling ball analogy, consider the effect of friction. Friction will cause the ball to lose some of its initial energy, so that when the ball rolls back up the initial slope, it cannot get to the original PE = 0 position, so it rolls back down and is trapped in the "potential energy well" formed by the intermolecular attraction. Just like the ball will roll back and forth in the PE well, the molecule will vibrate as the atoms move toward and away from each other as if connected by a spring. Further collisions with the surroundings will gradually remove energy from the system until the total energy of the system is close to the minimum PE energy on the potential energy curve. (For reasons related to quantum mechanics, the molecules never stop vibrating, leading to a "zero point energy").
Yes. The forces are attractive, so if you consider the force of atom A pulling on atom B, the force exerted by atom A on atom B is toward atom A. If atom B moves in that direction (toward atom A), the potential energy will decrease. Moving atom B away from atom A (in the direction opposite to the force vector) requires an external input of work (which then raises the potential energy of the system).
Likes diogo_sg and Greg Bernhardt
Quantum mechanics, in particular the Schroedinger equation decides it.
See this picture (I think these are the first/lowest two potential curves of H2)
The curve you have there is just one possibility of many others. In the picture above, apart from the bonding potential there is also repulsive potential which decreases monotonically with intermolecular distance. You can also see the corresponding electronic arrangement for each curves. The lower (bonding) state can form bonds because electrons are more likely to occupy the region between the two nuclei. For repulsive potential, the electrons prefer to reside in places away from the middle region so that the repulsive forces between nuclei always prevails, no bond is possible in this case.
Likes diogo_sg
More thoughts on -ve potential energy ... when we look at the graph we could slide that horizontal line down and define zero potential energy as the lowest point ... that would make more sense , particularly if the world was only made of hydrogen atoms ... but convention has determined zero is when atoms are far apart ...in that way we have a measure of bonding energy , and can compare the bonding energy of different compounds ...Have I got that right ?
Likes diogo_sg
Excellent answers all ... this is just my 2-cents worth... Think of two elements being attracted to one another like the ends of a stretched spring (i.e., without exceeding it's elastic limit) ... The resistance forces are directed toward the center of the spring... This is 'High Potential Energy of Attraction' ... as the tension is released, less force is required to keep the ends of the spring apart ... This is releasing or reduction of the 'Potential Energy of Attraction' (an exothermic process, hence the negative trend of the graph tracing as the ends come closer together) ... As the tension continues to be released, there will come a point at which the coiled spring can be placed on a surface and the ends will no longer be attracted to one another (or, repelled by one another for that matter)... This is the minimum in the Attraction/Repulsion Potential Energy vs Separation Distance of the potential energy diagrams and represents the condition when two elements stabilize at their natural bond lengths. At this point, the 'Potential Energy of Attraction (& Repulsion)' = 0. If compressing the spring ends, resistance forces act away from the spring's center and result in a rapid increase in Repulsion Potential Energy as the ends come closer together, or in atoms due to nuclear +charge/+charge repulsion. This would be the rapid increase in Potential Energy as the nuclear centers are pushed closer together. Such is one of the primary reasons nuclear fusion requires such extremely high energies to initiate the fusion process;i.e., +/+ repulsion of nuclei H-isotopes.
Likes diogo_sg
Related to Why does the potential energy get lower as atoms get closer?
Why Does Potential Energy Get Lower as Atoms Get Closer?
The relationship between potential energy and the distance between atoms is a fundamental concept in chemistry and physics. Understanding why potential energy decreases as atoms get closer is crucial in explaining chemical bonding and interactions. Here are some common questions related to this phenomenon:
Q1: What Is Potential Energy in the Context of Atomic Interactions?
In atomic and molecular systems, potential energy refers to the energy stored within the system due to the relative positions of atoms or molecules. It is a measure of the forces of attraction or repulsion between the particles. Potential energy can be divided into different components, such as electrostatic potential energy and van der Waals potential energy, depending on the nature of the interactions.
Q2: Why Does Potential Energy Decrease as Atoms Get Closer?
The decrease in potential energy as atoms get closer is primarily due to the attractive forces between them. Atoms consist of charged particles, namely electrons (negatively charged) and nuclei (positively charged protons and neutrons). The primary factors contributing to this decrease are:
  • **Electrostatic Attraction:** Electrons are attracted to the positively charged nuclei of neighboring atoms. This attraction results in a decrease in potential energy as the electrons move closer to the nuclei.
  • **Bond Formation:** When atoms get close enough, they may share or transfer electrons, leading to the formation of chemical bonds. These bonds are associated with lower potential energy because they represent stable arrangements of atoms.
  • **Van der Waals Forces:** In addition to electrostatic attraction, van der Waals forces (dispersion forces, dipole-dipole forces) also contribute to the decrease in potential energy as atoms approach each other. These forces arise from temporary fluctuations in electron distribution.
Overall, the decrease in potential energy signifies that the atoms are moving toward a more stable and energetically favorable state, which is a characteristic of chemical bonding and molecular interactions.
Q3: What Happens When Atoms Reach Their Lowest Potential Energy?
Atoms reach their lowest potential energy when they are in a stable and energetically favorable arrangement. This typically corresponds to the formation of chemical bonds, where the atoms share or transfer electrons to achieve a more stable electron configuration. In this state, the atoms are part of a molecule, and the potential energy is at its minimum. Any further separation of the atoms would require an input of energy to overcome the attractive forces that hold them together.
Q4: How Does Potential Energy Relate to Chemical Reactions?
Potential energy is a key concept in understanding chemical reactions. During a chemical reaction, the potential energy of the reactants is transformed into the potential energy of the products. Chemical reactions involve the breaking and forming of chemical bonds, which are associated with changes in potential energy. Exothermic reactions release energy as potential energy decreases, while endothermic reactions absorb energy as potential energy increases.
Understanding the potential energy changes in chemical reactions is essential for predicting reaction outcomes, studying reaction mechanisms, and designing chemical processes.
In summary, potential energy decreases as atoms get closer due to attractive forces between them, such as electrostatic attraction and van der Waals forces. This decrease in potential energy corresponds to stable arrangements of atoms and is a fundamental concept in explaining chemical bonding and interactions.
13K
