Why does water freeze differently when leaves are present on a shelter roof?
  • Thread starter Trying2Learn
  • Tags
    Water
In summary, the presence of leaves on the roof of a shelter during the first freeze of early winter can result in the water freezing in a pattern that resembles the veins of a leaf. This is because the layer of wax on the surface of the leaf can affect the precise freezing temperature of the water, causing it to freeze in a particular pattern. This effect can also be seen with other substances, such as slug trails on a window, and is influenced by the structure and imperfections of the surface. When the leaves are not present, the resulting frost patterns are more random and may be caused by small imperfections in the surface.
Trying2Learn
375
57
Hello!
I wait for the tram in a shelter. The roof of the shelter is made of transparent material (glass like). Leaves fall onto the roof and remain there in early winter during the first freeze.
If there are no leaves on the roof (recently cleared by wind), the ice freezes with no discernible pattern.
However, when there are leaves clumped up in the corner of the roof, the water freezes in a way the resembles the veins of a leaf.
Why is this?
Trying2Learn said:
Summary:: Why does water freeze in patterns
Hi @Trying2Learn!
I think it is cool that you are observant and see things like this!
I ask you:
Is a leaf perfectly flat? What I mean by this is if you would run your finger across the leaf, would you estimate it to be perfectly flat or would you feel any structure`? Would you feel the veins, for instance?
Oh, by the way, are the observed "freezed" patterns similar to the actual leaf patterns, or are they more like random leaves with random structures? The reason I ask is because this would indicate something else than what I first thought.
I would suggest that the reason is to do with the pattern of contact of the leaves with the glass/plastic. There is a layer of wax on the surface of a leaf and that can affect the precise freezing temperature of the water that condenses on the surface. Any subtle pattern of any parameter may change the precise timing of the freezing process and that will turn up as a pattern in the resulting 'frost'.
It could be a thermal effect or a chemical effect but any pattern can end up as a frost pattern. Ice crystals form to follow the pattern of the previous crystals.
"Jack Frost" is a real artist!
Likes Andy Resnick
DennisN said:
Hi @Trying2Learn!
I ask you:
Sorry it took so long to respond to this and previous.
No, not flat. But how does that impact the ice. Are you saying that the ice begins to freeze, more thickly (I do not know what that means either :-) What are you suggesting?
It looks just like the leaves.
And if the leaves are not present, there is no pattern of ice.
That does make sense. But here, the leaves have been dead and dried up for weeks. Still, what you wrote does make sense.
Time wouldn't affect the situation until the leaves had disintegrated and the traces washed from the glass. In fact, I would expect any chemical effect to be more dramatic after the chemicals had leached through to the leaf surface.
PS we get a similar effect with slug trails on an apparently clean window on a frosty morning.
Likes anorlunda
What I was thinking was that the structure of the leaves somehow effect the formed pattern, either due to the structural "imperfections" themselves or a combination of this and what @sophiecentaur wrote above.
Ok, because if they were random it would rather be due to small imperfections in the glass:
http://www.bbc.co.uk/weatherwatchers/article/38144457/what-causes-different-frost-patterns/
Do the patterns look like something like this? :
(i.e. does the frost form where there are no veins or does the frost form along the veins?)
Wouldn't the water film be thinner on the raised parts and thicker in the valleys?
I speculate that nucleation in water to begin freezing is influenced by many factors. It seems that all of those factors vary across the leaf. That makes it nearly impossible to name one of them as "the cause".
Related to Why does water freeze differently when leaves are present on a shelter roof?
1. Why does water freeze differently when leaves are present on a shelter roof?
Water freezes differently when leaves are present on a shelter roof due to the insulating properties of the leaves. Leaves act as a barrier between the water and the cold air, preventing the water from freezing as quickly as it would without the leaves present.
2. How do the leaves affect the freezing process of water on a shelter roof?
The leaves on a shelter roof affect the freezing process of water by creating a layer of insulation. This layer traps heat and prevents it from escaping, which slows down the freezing process of the water.
3. Can the type of leaves on a shelter roof affect the freezing of water?
Yes, the type of leaves on a shelter roof can affect the freezing of water. Leaves with larger surface areas, such as broad leaves, will provide more insulation compared to smaller, needle-like leaves. Additionally, the thickness and density of the leaves can also impact the freezing process.
4. Why does water still freeze when leaves are present on a shelter roof?
Although leaves can slow down the freezing process of water, they cannot completely prevent it. Eventually, the cold air will penetrate the layer of insulation and cause the water to freeze. Additionally, if there is a large amount of water present, it may freeze despite the presence of leaves.
5. Are there any other factors that can affect the freezing of water on a shelter roof?
Yes, there are other factors that can affect the freezing of water on a shelter roof. These include the temperature and humidity levels, the amount of water present, and the angle and orientation of the shelter roof. All of these factors can impact the rate at which water freezes on a shelter roof, with or without leaves present.
  • Thermodynamics
15K
  • Mechanics
18K
