Why does water not follow the law of motion?
In summary, the conversation discusses an event where the speaker's jacket sleeve gets wet with a drop from a leaking emergency exit on a bus. They question why the water droplet flew back towards them instead of falling straight down, and speculate that it could be due to the bus's motion, the polarity of water, or air currents. They also mention the possibility of the bus accelerating forward while the droplet was falling.
doglover9754
39
So I was in the bus going to school. I sat in the back not directly underneath the emergency exit but more like behind it. Anyways, since it’s been raining consistently, the emergency exits sometimes leak. So I’m sitting down and my jacket sleeve gets wet with a drop from the emergency exit. I remember the law of motion states that and object in motion stays in motion and and object at rest stays at rest until acted upon by an unbalanced force. (I asked a similar question in the past about throwing a ball in a plane)
Wouldn’t that mean that the water, which is “connected” to the bus would go with the motion of the bus? But that doesn’t solve my question to why it flew back towards me. If it’s supposed to go with the motion of the bus, then it would’ve just fallen straight down right? If it doesn’t follow the bus’s motion, then would it be because water is a polar molecule? Or maybe it’s because a bus isn’t as fast as an airplane so it doesn’t have the same result?
Likes kent davidge
It is difficult to speculate about an event for which we have very limited details. But might the bus have been accelerating forward while the water droplet was falling?
Likes russ_watters, CWatters and doglover9754
@jbriggs444 beat me to it. Was the bus accelerating at the time? If the bus wasn't moving, the drop would fall straight down, and that should also be the case if the bus was moving at a constant speed. If the bus happened to be decelerating, the drop would appear to fall in front of you.
The polarity of water has nothing to do with its motion.
Likes doglover9754
Another possible cause is air currents. If a window was open/cracked, or if the bus has air vents, it could have generated a current of air at the top of the bus, pushing the droplet backwards.
Likes Chestermiller and doglover9754
We are all speculating here, but it's also possible that the water leaked through quickly so that it hadn't acquired all the bus's momentum.
Certainty, if it came in through a definite gap, it would be going backwards relative to the bus.
Likes doglover9754
Actually, yes. I’m not sure if it was at a solid consistent speed, but it shouldn’t have too much effect right?
I never thought of that. Huh. The busses that are in Hawaii don’t have windows that can open. But I assume there was at least a little because of the fact that water was able to deep through.
It depends on how much effect you expect. One tenth of a gee of forward acceleration would result in a 6 degree rearward deflection. You could add additional deflection if the bus were on an up-slope.
Likes doglover9754
As a safety hazard, busses are required to have their emergency exits closed unless there is an actual emergency. The hatches usually have a seal to prevent leaks but I don’t think that the bus that I was in had a good seal.
The bus was moving forward. I couldn’t tell the difference in speed so I’m not too sure if the speed was consistent enough.
Another question would be how smooth was the bus ride? A drop of water clinging to a surface could have come loose due to a small jolt or vibration of the bus. The drop would have taken on some of the motion of that jolt relative to the bus. In effect, it could have been "tossed" backwards by whatever caused the drop to come free.
Likes Comeback City, doglover9754 and sophiecentaur
If you watch raindrops on the side window of a moving bus, they move backwards. The air outside may be squeezing them thru the seal at an angle.
Likes doglover9754
Not sure I buy that one. Raindrops on a side window tend to have their slow downward creep (surface tension/viscosity versus gravity) biased rearward by wind. The resulting rearward velocity is rather small and likely to be completely negligible after having squeezed through a leak in a seal.
Perhaps, but if there were a draught thru the seal, then the cold air would also be disobeying Newtons laws in the same way.
Likes doglover9754
Did it actually fly directly towards you, or did it maybe flow along the ceiling, and dropped on you?
Likes DaveC426913
I don’t remember a bump.
It flew towards me.
doglover9754 said:
It flew towards me.
The salient part of that question was: do you know from where it fell?
Can you be certain it fell directly from the crack, or could it have dribbled along the underside of the ceiling a few inches?
I am very sure it fell from the crack. Not directly from the crack, but like right outside of it. Like you know how a crack in an emergency exit is like a crevice? So it literally rolled down the crack and eventually flew towards me. I was watching it as there is not much entertainment on a public bus.
Related to Why does water not follow the law of motion?
1. Why does water not follow Newton's First Law of Motion?
According to Newton's First Law of Motion, an object will remain at rest or continue moving in a straight line at a constant speed unless acted upon by an external force. Water does not follow this law because it is a fluid and is constantly in motion due to its molecular structure and interactions with other molecules.
2. How does water's molecular structure affect its motion?
Water molecules are polar, meaning they have a positive and negative end. This causes them to attract and repel each other, resulting in constant movement and flow. Additionally, the hydrogen bonds between water molecules allow them to slide past each other, making it difficult for water to remain at rest.
3. What external forces can affect the motion of water?
There are several external forces that can affect the motion of water, such as gravity, wind, and temperature. Gravity pulls water downward, causing it to flow downhill. Wind can also push water in a certain direction, creating waves and currents. Changes in temperature can also affect the density of water, causing it to rise or sink.
4. Why does water move differently in different environments?
The movement of water can vary depending on the environment it is in. For example, in a calm lake, water may appear still and follow a more predictable pattern. But in the ocean, with its constantly changing tides and currents, water can move in a more chaotic manner. This is due to the influence of external forces and the varying density of water in different environments.
5. Can water ever be completely at rest?
No, water can never be completely at rest due to its molecular structure and the constant presence of external forces. Even in a seemingly calm body of water, there is still molecular movement and interactions occurring. However, water can reach a state of equilibrium where its motion is balanced and appears still to the human eye.
  • Mechanics
  • Thermodynamics
10K
  • Mechanics
  • Classical Physics
