Why Doesn't Alcohol Just Evaporate when Cleaning Wipes are Left "Open"?
In summary: Someone it ALWAYS manages to stay damp/moist and doesn't (unless I'm wrong) lose its alcohol-ness. How is that possible. I'm presuming there are times when the wipes are untouched for a few hours. Is that not enough time to evaporate the alcohol on them? If I spill rubbing alcohol on my counter, it's gone within a few minutes and evaporated.
kyphysics
676
437
When shopping at grocery stores, they have these boxes of sanitizing wipes containing alcohol on them. You know the type: they are often in the front entrance area for people to wipe carts. The way these are designed is that you have one wipe sticking out of the container and the rest tucked away in the tube. The opening from which the wipes can come out is small.
I understand that the small opening prevents a lot of air probably from getting to the alcohol wipes inside the container and evaporating all the alcohol away. (Feel free to correct my reasoning if I'm wrong - not a science person, but a liberal arts/social sciences dude.)
However, what about that one wipe sticking out? Someone it ALWAYS manages to stay damp/moist and doesn't (unless I'm wrong) lose its alcohol-ness. How is that possible. I'm presuming there are times when the wipes are untouched for a few hours. Is that not enough time to evaporate the alcohol on them? If I spill rubbing alcohol on my counter, it's gone within a few minutes and evaporated.
Thank you for helping me understand.
Likes atyy
Chemistry news on Phys.org
Most certainly because of capillary action. It does evaporate, so it is only a matter of time. On the other hand, I expect the producers to combine the alcohol with a fluid that doesn't evaporate, e.g. some oil.
Likes kyphysics
You're instinct isn't wrong, it's just that it apparently doesn't evaporate as fast as you think and the traffic through the grocery store is enough to keep them fresh.
From a study on lab ventilation safety I did a few years ago and a wet paper towel I just weighed, a well saturated 10x10cm square wipe may contain up to about 10mg of fluid (usually 70% or 60% IPA) and will evaporate at a rate of around 0.3 g/min. So based on that, I wouldn't expect them to last more than about 10 min exposed. Obviously, that will depend on how much is sticking out and how well exposed it is -- e.g., if it is crumpled-up it will evaporate much slower.
A moderate traffic grocery store may have 10 people a minute go through the door, so as long as more than a few percent take a wipe, they should be fine.
But if you take a wipe and notice it isn't significantly wet, discard it and take a second. The second should be perfectly fine.
Likes BillTre, sysprog and kyphysics
They’re using alcohol wipes at the entrance to the store? Very unusual! I’ve only seen water/quaternary ammonium sanitizing wipes being used.
Likes symbolipoint and sysprog
Heh - good point. I don't actually know what they use, but if that's more common then it's probably right. Prior to this crisis I never used the ones at the grocery store, and now I use my own IPA wipes that I bring with me. The ones provided at the gym, which I do use, are definitely not IPA.
Likes sysprog
russ_watters said:
A moderate traffic grocery store may have 10 people a minute go through the door ...
I don't disagree w/ your conclusion, BUT ... 10 people a minute? Suppose they had 10 cash registers (a large assumption for most stores). They would need to process one person every MINUTE through the checkout station to keep the store from filling up. Does your time through a checkout average under a minute? Mine sure never has.
Likes sysprog and russ_watters
Oil, really? Interesting. :smile: But, does oil not evaporate at all or is it just slow to? I see black oil marks all over Walmart parking lots (or any parking lot). They seem to dry (even though there can be "damp" areas). I guess some parts look dried (unless my eyes are fooling me).
So, combining the alcohol with a less and/or non-evaporative fluid makes the alcohol evaporate slow?
The oil is disappearing because it is sinking into the asphalt, not evaporating into the air.
Yes, basically. Mixing two liquids together will affect the vapor pressures of the liquids. The simplest treatment (of ideal liquid mixtures) leads to Raoult's law, but most mixtures are far from ideal.
I don't know for sure, but that is what I would do. They will probably need a kind of emulsifier. E.g. I have an alcohol based mouthwash which doesn't evaporate either, at least not fast. However, besides alcohol, water and the typical odors, there are quite a few additional substances. E.g. sorbitol, which is a carrier substance for humectants, and a poloxamer which Wikipedia describes as
Poloxamers are low-foaming and foam-suppressing nonionic surfactants that are used for dispersion and emulsification in the chemical-technical industry.
So it seems plausible that there are various possibilities to bind the alcohols and avoid (a fast) evaporation. I wondered that there was no glycerol in it, but this might be disguised by another ingredient or is left out because it dries out the oral mucosa.
Another example are perfumes or after shaves. It takes quite a while until they lose their alcohol.
If true, that would blow my mind. Oil does not evaporate AT ALL?
If it "sinks" into the asphalt, why doesn't water just get "absorbed" into as well? I'm using absorb and sink in the same sense, by the way.
Apologies if my questions are simplistic.
The vapor pressure of most of the components of oil is very low, meaning that it would take an extremely long time for oil to evaporate at ordinary temperatures and pressures. You can leave a dish of oil (or a drop of oil, for that matter) out in the open and basically nothing will happen.
Water does get absorbed. Not to the same extent, since oil and asphalt are much more similar chemically than either oil and water or asphalt and water. That’s one reason why asphalt is used: it’s relatively water-repellent.
Likes kyphysics and sysprog
shoplifters? 🤔
Related to Why Doesn't Alcohol Just Evaporate when Cleaning Wipes are Left "Open"?
1. Why doesn't alcohol just evaporate when cleaning wipes are left "open"?
Alcohol, like many other liquids, can evaporate when exposed to air. However, the rate of evaporation depends on various factors such as temperature, humidity, and surface area. When cleaning wipes are left open, the alcohol may evaporate at a slower rate due to the presence of other chemicals and materials in the wipe that can hinder the evaporation process.
2. How long does it take for alcohol to evaporate from cleaning wipes?
The time it takes for alcohol to evaporate from cleaning wipes can vary depending on the factors mentioned above. In general, it can take anywhere from a few minutes to a few hours for the alcohol to completely evaporate. However, some residue may still remain on the surface even after the alcohol has evaporated.
3. Can using cleaning wipes with alcohol be harmful to my health?
Most cleaning wipes contain a small amount of alcohol, which is generally safe to use for cleaning surfaces. However, prolonged exposure to high concentrations of alcohol can be harmful to your health. It is important to use cleaning wipes in a well-ventilated area and to avoid inhaling the fumes.
4. Do cleaning wipes with alcohol kill germs and bacteria effectively?
Yes, alcohol is known for its ability to kill germs and bacteria. However, the effectiveness of cleaning wipes with alcohol depends on the concentration of alcohol and the amount of time the surface is in contact with the wipe. It is important to follow the instructions on the package and allow the surface to air dry after wiping it with the cleaning wipe.
5. Can I use expired cleaning wipes with alcohol?
Using expired cleaning wipes with alcohol is not recommended. Over time, the alcohol in the wipes can evaporate, making them less effective in killing germs and bacteria. It is best to use cleaning wipes within their expiration date to ensure their effectiveness.
48K
  • Art, Music, History, and Linguistics
  • STEM Academic Advising
