- #36
- 8,938
- 2,947
PeterDonis said:Because Hawking radiation and Unruh radiation aren't the same thing.
I guess I had the idea that they were---that Unruh radiation + the equivalence principle implies Hawking radiation.
stevendaryl said:I meant the radiation in both cases is a manifestation of doing QFT in a noninertial frame.
PeterDonis said:I don't think this is correct. Unruh radiation is a manifestation of the fact that which state of a quantum field is the vacuum state is different for accelerated observers vs. inertial observers.
Hawking radiation is a manifestation of the fact that, in a particular curved spacetime (Schwarzschild spacetime in Hawking's original derivation; Schwarzschild-anti de Sitter in some more recent versions), a quantum field state that looks like a vacuum to observers at infinity in the far past, looks like a thermal state with a radiation temperature equal to the Hawking temperature of the black hole to observers at infinity in the far future.
stevendaryl said:That sure sounds to me like a manifestation of doing quantum field theory in a noninertial frame.
stevendaryl said:I don't understand the distinction you're making.
stevendaryl said:the derivation of the Hawking temperature in Wikipedia
PeterDonis said:George Ellis's presentation
PeterDonis said:No, it's a manifestation of doing QFT for an accelerated observer. You can analyze an accelerated observer using an inertial frame.
And your choice of frame can't affect any actual physics. When you say "a manifestation of doing QFT in a noninertial frame", to me you are implying that your choice of frame can affect the physics--that if you did the same QFT for the same observer in an inertial frame, somehow that would make the Unruh effect vanish. It wouldn't.
You should know better than to give Wikipedia as a source, particularly in an "A" level discussion.
As remarked by Unruh, this phenomenon [Hawking radiation] can be demonstrated in the laboratory according to the principle of equivalence: an accelerated observer in a gravity-free environment experiences the same physics (locally) as an observer at rest in a gravitational field. Therefore, an accelerated observer (in zero gravity) should find him(her)self in a thermal bath of radiation characterized by temperature ##T = \frac{\hbar a}{2πck}## , (2) where a is the acceleration as measured in the observer’s instantaneous rest frame.
stevendaryl said:I don't understand the distinction you're making. To me, to talk about observers means describing things in the observer's (accelerated) frame.
stevendaryl said:If you are describing things from the point of view of an inertial frame, then the fact that the "vacuum" is different for accelerated observers does not seem relevant. You stick to the inertial frame, and use that notion of vacuum.
stevendaryl said:the derivation of Unruh effect comes from applying QFT to an accelerated frame.
stevendaryl said:I was trying to diplomatically suggest that maybe you're wrong.
stevendaryl said:I'm very unconvinced by this discussion.
stevendaryl said:here's a slide show that definitely states that Hawking and Unruh radiation are not the same thing, and that both come into play near a black hole
