Why doesn't Graphene have a band gap?
In summary: However, the band gap in MoS2 is theoretically predicted to be much larger than in graphene, due to the presence of a large number of defects.
asheg
54
Is there any simple justification about graphene having no band gap? How bout its linear E-K? Why bilayer graphene has a quadratic E-K and electric field can open a band gap there?
I do not completely understand the broken symmetry argument? Also Why MoS2 which has similar structure, do not have similar properties?
I know that we can create the Hamiltonian, plot the band-structure numerically and answer these questions. But I want to know if we can use some simple quantum theory arguments (like perturbation theory, or Fermi golden rule) or symmetry facts to get a qualitative answer for all of these questions.
I don't know whether you are familiar with x-ray structure analysis. There you encounter a similar phenomenon: Systematic absences. Usually, the splitting of two bands near the Brillouin zone boundary is due to strong reflection of the Bloch waves, or, what amounts to the same, a strong mixing of counter propagating waves, leading to a sin and a cos wave with different energy. However in graphene, these reflections are absent along special directions as you have two reflecting lines of atoms which are not spaced by a lattice vector, but only half of it. You easily see this as follows: Fill the centers of the hexagons with additional C atoms: Apparently you get a primitive closest packed 2d crystal with smaller unit cell. Some of these lattice lines are also present in graphene with equal density of C atoms on them, though they are no longer connected by a lattice vector.
Likes adhasukmaaji and asheg
Thanks DrDu. Do you have a reference so I can take a look into the details? Also do you have idea about the other questions?
No, I have no literature at hand. You can also see it like this: in graphene, each C atom has 3 nearest neighbours. At the conical point, the first C atom is in phase, 1, the second is ##\exp(\pm 2\pi/3)## out of phase and the third one ##\exp(\mp2\pi/3)## out of phase, so that the interaction of a c atom with it's nearest neighbours vanishes. As there are two possible signs of the phase factor, you see that there are two conical points in K space. Hence the two sub lattices consisting of all atoms being next-nearest neighbours don't interact at the conical points and are energetically degenerate, as the atoms are identical. In other substances, like BN, the sub lattices are formed from different elements (B and N, respectively), which have different energies, so there is a band gap.
In MoS2 and graphene double layers, similar arguments as in BN should apply.
Likes asheg
Related to Why doesn't Graphene have a band gap?
1. Why is Graphene considered a zero band gap material?
Graphene is considered a zero band gap material because it has a completely flat and continuous energy spectrum. This means that there is no energy gap between the valence and conduction bands, allowing for the free movement of electrons throughout the material.
2. How does the lack of a band gap affect the properties of Graphene?
The lack of a band gap in Graphene results in its unique properties, including its high electrical conductivity, high thermal conductivity, and exceptional mechanical strength. It also allows for the efficient transport of charge carriers, making it a promising material for various applications.
3. Can a band gap be induced in Graphene?
While Graphene itself does not have a band gap, researchers have found ways to induce a band gap in the material. This can be achieved through various methods, such as doping, strain engineering, or creating heterostructures with other materials.
4. What is the significance of a band gap in materials?
A band gap is a crucial factor in determining the electronic properties and behavior of a material. It affects its electrical conductivity, optical properties, and thermal properties. Materials with a band gap can be used in electronic devices, while those without a band gap, like Graphene, have unique properties that make them suitable for other applications.
5. Is there ongoing research to create a band gap in Graphene?
Yes, there is ongoing research to create a band gap in Graphene, as this would expand its potential applications. Scientists are exploring different methods to induce a band gap in Graphene and studying the effects of a band gap on its properties. However, this remains a challenging task, and more research is needed to fully understand and control the band gap in Graphene.
  • Atomic and Condensed Matter
16K
