Why doesn't ice in Saturn's ring sublime away?
  • Thread starter KenJackson
  • Tags
    Ice Ring
In summary, Brian Cox on Wonders of the Solar System (episode: Order Out of Chaos) on the Science Channel says the rings of Saturn are made up of chunks of water ice.
KenJackson
63
Water ice? In space?
I would expect a chunk of water ice in space would experience a near zero vapor pressure. Wouldn't it? And if so, why wouldn't all those chunks have sublimated long ago?
Astronomy news on Phys.org
It's cold there. What's the vapor pressure of water at -170?
So low that water ice is stable over the age of the solar system.
The other point I forgot is that water molecules and/or hydroxyl ions have been observed coming off the rings, so they do have a very tiny vapor pressure.
Google for "snow line" (AKA "frost line").
qraal said:
...water molecules and/or hydroxyl ions have been observed coming off the rings, so they do have a very tiny vapor pressure.
If the chunks of ice are loosing molecules and ions, they are loosing mass. So either the mass is being replaced or they are very young in astronomical terms.
How is the mass being replaced, or where did it recently come from?
Large chunks lose it slower than small due to their higher volume/area ratio. Slow enough loss means the chunks can last billions of years.
All we know for certain is that the rings are more than 400 years old. However, they are probably hundreds of millions of years old, possibly billions.
How long they last is a quantitative question, and it depends on the vapor pressure of ice, as well as the rate of redposition: if a water molecule sublimes and then condenses back onto a different piece of the ring system the equilibrium can be stable. But the vapor pressure of water is really, really low. Water ice forms a significant portion of the outer moons, and you don't see them evaporating.
Saturns rings are probably fairly recent [< billion years old]. They are believed to be remnants of an icy moon - possibly destroyed by tidal forces or an impact event. It is also known that at least one of Saturn's moons is emitting water vapor that may be replenishing the rings. There are also numerous small moons in the vicinity that have the potential to replenish the rings via collisions or tidal effects.
Related to Why doesn't ice in Saturn's ring sublime away?
1. Why doesn't ice in Saturn's ring sublime away?
The ice in Saturn's ring does not sublime away because the surrounding environment does not allow for sublimation to occur. Sublimation is the process of a solid turning into a gas without going through a liquid phase. In order for this to happen, there needs to be a significant difference in temperature and pressure. However, in Saturn's ring, the temperature and pressure are relatively stable, preventing the ice from sublimating.
2. What are the temperature and pressure conditions in Saturn's ring that prevent ice sublimation?
The average temperature in Saturn's ring is around -220 degrees Celsius, which is too low for the ice to reach its sublimation point. Additionally, the pressure in Saturn's ring is not high enough to cause the ice to sublimate. The pressure in the ring is significantly lower than what is needed for sublimation to occur.
3. Could the composition of the ice in Saturn's ring be a factor in its resistance to sublimation?
Yes, the composition of the ice in Saturn's ring plays a significant role in its resistance to sublimation. The ice in the ring is primarily composed of water ice, which has a higher sublimation temperature compared to other substances. This means that even at lower temperatures, water ice is less likely to sublimate compared to other types of ice.
4. Is there any other process besides sublimation that could explain why the ice in Saturn's ring does not disappear?
Yes, there are other processes besides sublimation that contribute to the presence of ice in Saturn's ring. One of these processes is called "shepherding," where small moons orbiting Saturn create gravitational forces that keep the ice particles in the ring from drifting away. Additionally, collisions between ice particles can also replenish the ring's supply of ice.
5. Could the presence of other gases in Saturn's atmosphere affect the sublimation of the ice in its ring?
Yes, the presence of other gases in Saturn's atmosphere can have an impact on the sublimation of ice in its ring. These gases can create a protective layer around the ice particles, preventing them from reaching their sublimation point. They can also affect the temperature and pressure conditions in the ring, making it less conducive for sublimation to occur.
  • Astronomy and Astrophysics
  • New Member Introductions
  • Other Physics Topics
24K
