Why doesn't the normal Zeeman effect produce a band?
In summary, the orbital angular momentum is quantized in the Zeeman effect. The external magnetic field lifts the degeneracy of the states, resulting in only specific values of m(L) being allowed. This leads to equally spaced energy levels, giving a discrete spectrum rather than a continuous one.
quawa99
67
I know that orbital angular momentum is quantized. If the potential energy is developed because of the external magnetic field applying a torque on the magnetic dipole, then from the dot product of the dipole moment and magnetic field we have a cosine term, shouldn't this give rise to all the energies corresponding to the various orientations that the orbital can have w.r.t the external magnetic field?
in normal zeeman effect the orbital angular momentum states for a particular n (principal quantum number) -which has possibility of description in states of L=0,1,2,...(n-1) which are not split normally ,the external magnetic fields lifts the degeneracy in a manner that only those m(L) values are are available /allowed with m(L) taking -L, (L-1) ...0 ,1,2 ... +L in steps of 1 only.
these are the allowed states quantum mechanically
therefore the expectation that all cos(theta) values are possible is not allowed.
For example for L=1 a p state only m(L) are -1, 0, +1 making definite theta with the z axis (magnetic field axis) in a vector model.
thereby
Considering the quantization of angular momentum , this gives equally spaced energy levels displaced from the zero field level by
so the spectrum can not be continuous and will be spaced by the above.
see; http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/zeeman.html for an introductory treatment
Related to Why doesn't the normal Zeeman effect produce a band?
1. Why does the normal Zeeman effect only produce lines and not bands?
The normal Zeeman effect occurs when the energy levels of an atom are split into discrete lines in the presence of a magnetic field. This splitting is due to the interaction between the magnetic field and the magnetic moment of the atom. Since the energy levels are already discrete, the resulting spectral lines will also be discrete and not form bands.
2. Can the normal Zeeman effect ever produce bands instead of lines?
No, the normal Zeeman effect is a purely quantum mechanical phenomenon and will always result in discrete spectral lines. It is not possible for it to produce bands.
3. What is the difference between the normal Zeeman effect and the anomalous Zeeman effect?
The normal Zeeman effect only considers the splitting of energy levels in the presence of a weak magnetic field, while the anomalous Zeeman effect takes into account the electron spin and the interaction between the electron spin and the magnetic field. This results in a more complex splitting pattern and can produce bands in addition to lines.
4. Can the normal Zeeman effect be observed in all atoms?
Yes, the normal Zeeman effect can be observed in all atoms. However, the strength of the effect may vary depending on the atomic structure and the strength of the magnetic field.
5. What practical applications does the normal Zeeman effect have?
The normal Zeeman effect is useful in spectroscopy, allowing scientists to study the energy levels and transitions of atoms. It also has applications in magnetic field measurements, as the splitting of spectral lines can be used to determine the strength of a magnetic field. Additionally, the normal Zeeman effect is used in some scientific instruments, such as NMR spectrometers, to produce a magnetic field for experiments.
  • Quantum Physics
  • Other Physics Topics
  • Atomic and Condensed Matter
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
14K
