Why Doesn't the Sun's Core Contain Heavy Metals Like Earth's Core?
  • Thread starter leonstavros
  • Tags
    Center Sun
In summary, television shows about astronomy explain that our solar system was formed from remnants of a supernova. Gravity pulled everything together, including the sun and planets. The sun's shining is due to the fusion of hydrogen atoms at its core. The Earth's heat comes from the fission of heavy metals at its core. It is logical to think that the heaviest elements would be at the center of the solar system, but the sun's composition is mostly hydrogen, helium, and a small amount of other elements, such as carbon and oxygen, due to the high temperatures and turbulence during its formation. The sun also has a higher percentage of heavier elements compared to the planets. Fission is not mentioned because it is insignificant compared to the power of
leonstavros
78
Television shows about astronomy explain the formation of our solar system as a result of remnants of a supernova. Gravity pulled everything together to form our sun and planets. The explanation given for the sun to shine was that hydrogen atoms at the core were being fused together to create helium. I hope I'm correct so far.
At the same time the planets were forming including Earth. The explanation why the Earth is hot is due to fission of heavy metals at its core.
My question is why doesn't the sun have heavy metals at its core like the Earth? And if it does why isn't fission ever mentioned?
Another question I have is: During the formation of the solar system wouldn't it be logical that the heaviest elements would end up at the center of the solar system that is the core of the sun?
Astronomy news on Phys.org
It does. They are most likely not forming a iron-nickel core, though, it's not the environment for such a thing.
It's insignificant compared to the fusion power.
It would be logical that you find more heavy elements the nearer you are at the center. But that's a general trend only, the elements are not cleanly separated by atomic weight. Too much turbulence, heat, solidity, and everything went too quick.
That is not what theory says and it is not what observations of the sun tell us about the composition of the sun. Think of it this way: Carbon dioxide is considerably more dense than nitrogen and oxygen, and yet the CO2 in the atmosphere does not fall to the bottom of the atmosphere and form a suffocating three meter thick layer of pure CO2. Instead, that CO2 is pretty well dispersed throughout the atmosphere.
The high temperatures, turbulence, and convection in a protostar would have made the initial protosun have a rather uniform makeup throughout: 72 percent hydrogen, 26 percent helium, and 2 percent heavier elements (and almost all of that 2% is carbon and oxygen). Thanks to fusion, the Sun's core is now somewhat depleted of hydrogen. Just as earthquakes give a window into the Earth's core, vibrations in the sun give a clue as to the makeup of the Sun's interior. That picture is consistent with theory: Hydrogen (depleted compared to the outer parts of the Sun), helium (enriched compared to the outer parts of the Sun), and 2% other stuff, most of which is carbon and oxygen.
See http://atropos.as.arizona.edu/aiz/teaching/nats102/mario/solar_system.html for discussion of elemental abundances in the solar system. The sun, while predominately composed of hydrogen and helium, still has a respectable amount of heavier elements in the mix. The percentages look small, but, the totals far exceed that of all the planets combined. The heavy elements in the sun are more diffusely distributed than on Earth for reasons already noted.
I can provide some clarification on the content mentioned. The center of our sun, also known as the core, is a region of extremely high pressure and temperature. It is primarily composed of hydrogen and helium, with smaller amounts of other elements such as oxygen, carbon, and iron. The high temperature and pressure in the core allows for nuclear fusion reactions to occur, where hydrogen atoms combine to form helium, releasing a large amount of energy in the process. This is what powers the sun and allows it to shine.
Regarding the formation of our solar system, it is believed that it originated from a giant cloud of gas and dust, known as a nebula. As this cloud collapsed under its own gravity, it began to spin faster and flatten into a disk shape. The majority of the material in this disk went on to form the sun, while the remaining material clumped together to form the planets. The sun's core, being the most massive and dense part of the nebula, was able to pull in the majority of the hydrogen and helium, leaving behind a smaller amount of heavier elements.
As for the question about fission, it is not a process that occurs in the sun's core. Fission is the splitting of heavy atoms, such as uranium, into smaller atoms, releasing energy in the process. This process is not sustainable in the sun's core due to the high temperature and pressure needed for fusion to occur. Additionally, the sun does not have enough heavy elements in its core for fission to be a significant source of energy.
In terms of the heaviest elements being at the center of the solar system, it is true that the sun's core contains the majority of the mass in our solar system. However, the heaviest elements are actually found in the outer layers of the sun, as they were formed through nuclear fusion reactions in the core and then transported to the surface through convection processes.
In summary, the sun's core is primarily composed of hydrogen and helium, with smaller amounts of other elements. Fission does not occur in the sun's core, and the heaviest elements are found in the outer layers of the sun rather than the core. The formation of our solar system is a complex process, and the distribution of elements is a result of various factors such as temperature, pressure, and gravitational forces.
FAQ: Why Doesn't the Sun's Core Contain Heavy Metals Like Earth's Core?
What is the center of our sun made of?
The center of our sun is primarily made up of hydrogen gas, which is compressed under immense pressure and heat. This creates the extreme conditions necessary for nuclear fusion to occur, which is the process that powers the sun.
How hot is the center of our sun?
The temperature at the center of our sun is estimated to be around 15 million degrees Celsius. This intense heat is generated by the nuclear fusion reactions happening in the core.
What is the density of the center of our sun?
The density at the center of our sun is incredibly high, estimated to be about 150 times denser than water. This is due to the extreme pressure created by the immense gravity of the sun.
How does the center of our sun produce energy?
The center of our sun produces energy through the process of nuclear fusion. This is when hydrogen atoms fuse together to form helium, releasing large amounts of energy in the process.
Can we see the center of our sun?
No, we cannot see the center of our sun. The intense heat and pressure at the core make it impossible for any light to escape. We can only observe the outer layers of the sun, known as the photosphere, which emits the light and heat that we see from Earth.
