- #36
PeterDonis
Mentor
- 47,494
- 23,768
John Duffield said:I beg to differ about the claim that it's impossible to have a static object.
I didn't say it was impossible to have a static object. I said that spacetime inside a black hole's horizon is not static. That is a straightforward conclusion from the metric of said spacetime, and is not in any way controversial. (In fact, the black hole interior is not even stationary, which is a stronger condition than not being static. See below.)
John Duffield said:please note that "the curvature of spacetime" relates to the tidal force
The curvature of spacetime is tidal gravity (not "force"--tidal gravity is not a force). They are the same thing, physically.
John Duffield said:and the second derivative of potential
Only in a stationary region of spacetime, where a "potential" can be defined.
John Duffield said:the force of gravity relates to the first derivative of potential
Gravity is not a force in GR, and the "acceleration due to gravity"--which is better expressed as the proper acceleration required to remain at the same spatial location in a stationary spacetime--is what relates to the first derivative of the potential, which, again, can only be defined in a stationary spacetime.
Since the region at and inside the horizon of a black hole is not stationary, none of the above even makes sense there.
John Duffield said:gravitational potential can be related to the coordinate speed of light
Only in a stationary region of spacetime, where "potential" has meaning. And even there, the coordinate speed of light has no physical meaning; it's not something anyone can actually measure. But that's irrelevant for this discussion, because...
John Duffield said:Hence light emitted at the horizon stays at the horizon forever. It doesn't go up, stop, and then fall back.
No, this is not the reason light stays at the horizon--because the horizon, and the region inside it, is not stationary, so none of the concepts above are meaningful there.
John Duffield said:As for matter falling into the hole, I suspect it doesn't even make it as far as the event horizon, but that's one for another day.
This is wrong too, as many, many previous threads here on PF have discussed. If you continue to post these incorrect claims, you will receive a warning.
John Duffield said:Here's what Don Koks said
I like the Usenet Physics FAQ, and it's often a good source, but that doesn't mean it's always right, or that its authors always are. The coordinate speed of light, which is what "speeds up" as a light ray moves upward in the gravitational potential field in a stationary spacetime, and "slows down" as the light moves downward, has no physical meaning. Don Koks knows this, because he adds the qualification that nobody actually measures it; anyone actually measuring, locally, the speed of light will find it to be ##c##. He attributes this to the measuring device "speeding up" or "slowing down" exactly in sync with the light itself; but that is attributing a physical meaning to the coordinate speed of light that it simply doesn't have.
This is a good illustration of why, when push comes to shove, we don't use pop science articles, even good ones like the Usenet Physics FAQ, as references here on PF; we only use peer-reviewed scientific papers or textbooks, and even then we only use those in which the physics is set out rigorously in math, not heuristically in ordinary language. Ordinary language is simply too imprecise to rely on if you really want to understand the physics.
