Why don't absorption and emission spectra "cancel out"?
In summary, absorption and emission lines occur when a photon of the right wavelength is absorbed by an atom, exciting an electron to a higher energy state. The electron then de-excites and emits a photon of the same wavelength. However, due to the random direction of emission, there is a reduction in the number of photons reaching us, resulting in an absorption line. In thermal equilibrium, emission and absorption cancel out. However, the electron can also lose energy to different energy levels and decay to its original state, emitting a photon of a different energy. Other processes such as scattering and stimulated emission can also occur between photons and atoms, leading to effects such as the blue color of the sky and the functioning of lasers.
marksyncm
100
My question is regarding absorption and emission lines.
As far as I understand, when a photon of the "right" wavelength passes through an atom, an electron is excited and takes on a higher energy state, in proportion to the energy imparted by the photon. This is the "absorption" part. However, the electron will rapidly de-excite, returning to its previous energy state and emitting a photon in the process. This is the "emission" part.
My assumption: the emitted photon is of the exact same wavelength as the absorbed one; if a photon of wavelength X was absorbed, then a photon with the exact same wavelength X will be emitted.
If my assumption is true, then how is it that we can tell that absorption happened? If a photon of wavelength X is absorbed and then a photon of wavelength X is emitted, it's as if no absorption took place at all and it would seem to me no absorption lines should be visible on spectroscopic examination.
What am I missing?
Thanks.
It's a complicated question, but the following is a simple answer. Imagine light from a distant light source (like a star) passing through a cloud of gas consisting of atoms in the ground state. An atom in the gas cloud absorbs a photon from the star, and then some time later re-emits it. The light which is re-emitted can be re-emitted in any direction, so the probability that it is re-emitted in the same direction as the original photon is very small. So you see a reduction in the number of photons that reach you, which is an absorption line.
Likes Dr. Courtney and marksyncm
Thank you phyzguy, this makes sense.
(Sorry for the double post; not sure if anyone would notice an edit at this point.)
Does this mean that when looking towards seemingly "empty" regions of space (meaning a region where we do not see a star), we should expect to find hydrogen emission lines from the photons that were scattered under random "angles" by hydrogen atoms inside random stars?
Light scattered by an object appears to come from the object. So light "scattered under random "angles" by hydrogen atoms inside random stars" would appear to come from those stars. We only see light scattered in our direction.
We do see hydrogen elsewhere..
https://uanews.arizona.edu/story/hydrogen-hydrogen-everywhere
Thank you.
Another aspect is that emission and absorption cancel out in thermal equilibrium. E.g. if you look into a hot ceramic oven, you won't be able to distinguish the pots inside when there is no external light source although the light from the glowing pots inside may be very intense.
Actually, electron doesn't always return to its previous state. In many cases it loses its energy to a different energy level than the original one. Then it can decay to its original (presumably ground) state emitting a photon of a different energy. This is known as luminescence.
It can also decay by a non-radiative process (e.g. collisions with other atoms and/or molecules, if an atom is a part of solid or liquid, the energy can be lost due to thermal motion).
Second thing, the loss of energy doesn't always happen quickly. Some excited states have lifetime of the order of hours !.
There are other processes possible between photons an atoms (liquids, solids).
One is a scattering, i.e. simultaneous absorption of the incoming photon and emission of another photon. This could be elastic scattering, that is the outgoing photon of the same energy as the original, (that's what make the sky blue! and sunset orange-red) or inelastic scattering (Raman, Rayleigh). And, of course, stimulated emission which happens when the atoms was originally at a higher energy level - this is how lasers work.
The most common is coherent elastic emission of a photon of the same energy but differing phase. This is what gives rise to things like refractive index and mirror-like reflection.
Thanks DrDu and Henryk, this was very helpful.
FAQ: Why don't absorption and emission spectra "cancel out"?
Why do absorption and emission spectra not cancel out?
Absorption and emission spectra do not cancel out because they represent different processes. Absorption spectra show the wavelengths of light that are absorbed by a substance, while emission spectra show the wavelengths of light that are emitted by a substance. These processes are not the opposite of each other, and therefore do not cancel out.
What causes absorption and emission spectra to be different?
The differences in absorption and emission spectra are caused by the energy levels of the electrons in atoms or molecules. When light is absorbed, electrons are excited to higher energy levels, and when light is emitted, electrons return to lower energy levels. The specific energy levels and transitions involved determine the unique patterns seen in absorption and emission spectra.
Can a substance have the same absorption and emission spectra?
No, a substance cannot have the same absorption and emission spectra. This is because the processes of absorption and emission are dependent on the energy levels and transitions of the electrons in the substance. Since these energy levels and transitions are unique to each substance, their absorption and emission spectra will also be unique.
Why are absorption and emission spectra important in scientific research?
Absorption and emission spectra are important in scientific research because they can provide valuable information about the composition and properties of substances. By analyzing the specific wavelengths of light that are absorbed or emitted, scientists can identify the elements or molecules present in a substance and gather data on their energy levels and transitions.
How are absorption and emission spectra used in practical applications?
Absorption and emission spectra have many practical applications, such as in spectroscopy and environmental monitoring. By comparing the absorption or emission spectra of a substance to known spectra in databases, scientists can identify unknown substances. In environmental monitoring, absorption and emission spectra can be used to detect pollutants in air, water, and soil, helping to keep our environment safe and healthy.
