Why don't birds get shocked on power lines?
In summary: In a power line, the electrons are constantly being pushed around and never really build up to a significant level.
  • #36
b.shahvir said:
Electricity works in mysterious ways.
that's a poor misquote
in fact electricity is pretty well understood
Likes Dale
  • #37
Sooty said:
. This will bring -the suit's- voltage (and that of the guy inside!) up to that of the power line
(NO)
if it were the case, there would be no point wearing the suit
  • #38
There's a huge difference between 'pretty well' and 'perfectly'.
  • #39
it's well enough understood to totally negate your comment and has been for a long time
  • #40
davenn said:
(NO)
(YES)
The point of the suit is not to somehow 'stop the occupant's voltage from becoming that of the line'... it's to prevent voltage -gradients- from being created across any part of his body. What 'does the damage' is not the voltage per se... it's the current that flows solely 'cos a gradient permits it to do so. No gradient, no current... or is that (NO) also?:cool:
PS
If (NO), you forgot to explain what IS the point of wearing the suit...
  • Skeptical
Likes davenn
  • #41
Sooty said:
PS
Unbelievable seriously !
It is as you stated but maybe you don't believe ... an example of a Faraday shield
The electric field DOES NOT penetrate the suit ... skin effect ensure that
There's a number of www sites that will give you that answer :smile:
you continue to contradict yourself ...
  • #42
I never said it 'penetrated' anything. Believably! Seriously! Read it again - I said it prevents voltage -gradients- from being created across any part of his body.
PS - Any more examples of me 'continuing to contradict' myself?... maybe starting with one example of where I did actually contradict myself... :biggrin:
  • #43
Sooty said:
So, as he approaches the line, he reaches out with a conducting rod that is connected to his suit. This will bring -the suit's- voltage (and that of the guy inside!)
Yes you did say it ... there is the contradiction !
to bring the guy's body inside up to the line voltage ... it MUST penetrate the suit DOH
and as I have told you, that doesn't happen ... the guy inside is shielded
  • #44
Hmmm...
followed by
Right, got it! 😄
  • #45
It is, in fact, perfectly understood. There is no known EM phenomena which cannot be explained with our current EM theory. It can correctly give the outcome of every EM experiment performed to date.
Likes davenn
  • #46
The OP question has been answered over and over and over again.
Thread closed.
  • #47
@davenn in this case @Sooty is correct.
A Faraday suit forms an equipotential surface. An E field is the gradient of the voltage. So the Faraday suit forces the E field inside to zero, but does not force the voltage to zero. It is equipotential, not zero potential.
  • Skeptical
Likes davenn
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
  • Other Physics Topics
