Why don't Cooper electrons accelerate infinitely?
In summary: ...superconducting electrons are not little microscopic horses racing around a track and accelerating as they go.
Jirnyak
TL;DR Summary
cooper pairs, composite boson particles (spin number = 0 or 1) from two coupled electrons. The movement of cooper pairs is forming a superconducting current. Superconducting current does not have a dissipation of energy from Resistance as it happens in normal current so Qubit (Quantum bit) circuit could be treated as a system of only conservative forces. Why are not cooper electrons infinitely accelerating?
Hello, I am trying to learn Quantum mechanics and have some questions I cannot answer. cooper pairs, composite boson particles (spin number = 0 or 1) from two coupled electrons. The movement of cooper pairs is forming a superconducting current. Superconducting current does not have a dissipation of energy from Resistance as it happens in normal current so Qubit (Quantum bit) circuit could be treated as a system of only conservative forces. What is a potential for cooper pairs to move into? Why are not cooper electrons infinitely accelerating?
Jirnyak said:
Summary: cooper pairs, composite boson particles (spin number = 0 or 1) from two coupled electrons. The movement of cooper pairs is forming a superconducting current. Superconducting current does not have a dissipation of energy from Resistance as it happens in normal current so Qubit (Quantum bit) circuit could be treated as a system of only conservative forces. Why are not cooper electrons infinitely accelerating?
If you are learning QT then starting with super-conductivity is bold ( and probably unwise). It is an interesting feature of this phenomenon that the equations predict that with a constant voltage applied across the superconductor a constant current flows. We cannot say why - it just happens that way.
Likes Jirnyak
Why do you think they would be?
Probably beacuse the electrical formula ##V=IR## suggests this with zero resistance.
No, they predict that with zero voltage applied a constant current flows.
No, it suggests that ##V = 0## with ##R = 0##. See above.
Likes vanhees71
Sorry if I mislead you. Just to make my point about how tricky 'infinite conductivity' is, look at this (great) paper
https://academic.oup.com/ptps/article-abstract/doi/10.1143/PTPS.86.43/1885987
My mistake is not remembering that it is the time derivative of the Nambu-Goldstone field that must be zero and this is equal to -V ( equation 29 ).
Likes vanhees71 and Jirnyak
To accelerate electrons beyond the total watt power of the source, an outside source of energy is needed. This is how colliders work - they employ ultra powerful electromagnets to do the job.
I think that you could write down the wave-function for the Cooper pair and then apply the acceleration operator. That should give you 0. My understanding is that the wave function of a Cooper pair goes all around the superconducting loop and everywhere has a non-zero current density operator and a zero acceleration operator.
Perhaps one of my colleagues could describe that in more detail or tell me that I am wrong. In any case, superconducting electrons are not little microscopic horses racing around a track and accelerating as they go.
Likes Jirnyak
Apply the concept of plane wave solution that you learned in basic QM. What do you think is the "average position" of a particle having such a wavefunction.
The Cooper pair wavefunction is a combination of such plane waves, meaning that these pairs are not localized. They have what we call "long range coherence", which is why they form supercurrents. You will run into huge conceptual problems if you try to apply classical E&M and classical electric current motion to such a scenario.
Zz.
Likes Jirnyak, vanhees71 and berkeman
Because the maximal speed of electrons is the speed of light.
But perhaps the right question is this. If we put a superconductor in a synchrotron which accelerates electrons by electric field which lasts for a long time, will the electrons approach the speed of light in the superconductor (as they do in the vacuum)? I don't know the answer, perhaps a superconductor looses its properties at very high electron speeds.
Likes Jirnyak
"Photons inside superconductors develop a nonzero effective rest mass; as a result, electromagnetic forces become short-range inside superconductors."
per Wikipedia | Photon | Properties | Experimental checks on photon mass | reference #39 Frank Wilczek, (2010)
Likes Jirnyak, vanhees71 and Demystifier
Interesting. Does it mean that the Meissner effect expels not only the magnetic field from the superconductor (which every textbook says), but the electric field as well? If so, why is it not mentioned in the textbooks?
Likes Jirnyak
I don't know... I've seen the EM force law described as "exponentially damped"
Likes Jirnyak
But this is by default because you have a perfect conductor.
Zz.
Likes Jirnyak
But if the electric field is always zero, then what gives the electrons the initial velocity needed to have the electric current in the first place? It is only during the stationary current that the electric field is zero in a perfect conductor. When the current changes (which is what this thread is about), then the electric field in a perfect conductor is not zero.
Likes Jirnyak
There is no initial velocity the same way that photons have no initial velocity. There are already current flow in all directions. It is just that when a voltage is applied, a particular direction is selected.
Zz.
Likes Jirnyak
Are you saying that it is impossible to have an alternating current in a superconductor?
Likes Jirnyak
Where did I say that, or even implied that?
AC in superconductivity isn't as simple as DC, because now, the AC resistivity is no longer zero. The electrons that do not participate in becoming a supercurrent may start to influence the electrical properties of the superconductor.
Zz.
Likes Jirnyak, vanhees71, Mentz114 and 1 other person
Related to Why don't Cooper electrons accelerate infinitely?
1. Why do Cooper electrons not accelerate infinitely?
Cooper electrons are bound to the atoms in a material, and therefore have a limited amount of energy available for acceleration. This energy is provided by an external electric field, but once the electrons reach a certain energy level, they can no longer gain more energy and accelerate further.
2. What is the mechanism that limits the acceleration of Cooper electrons?
The mechanism that limits the acceleration of Cooper electrons is known as the Fermi energy. This is the maximum energy that an electron in a material can have, and it is determined by the energy levels of the atoms in the material.
3. Can Cooper electrons ever reach infinite speed?
No, Cooper electrons cannot reach infinite speed. As mentioned before, they are limited by the Fermi energy and the energy levels of the atoms in the material. Additionally, as an electron approaches the speed of light, its mass increases and it requires more and more energy to accelerate further.
4. How does the structure of a material affect the acceleration of Cooper electrons?
The structure of a material can affect the acceleration of Cooper electrons in a few ways. First, the spacing between atoms can affect the energy levels available to the electrons. Additionally, the presence of impurities or defects in the material can disrupt the flow of electrons and limit their acceleration.
5. Is there any practical application for understanding the limitation of Cooper electron acceleration?
Yes, understanding the limitation of Cooper electron acceleration is important for many applications in materials science and electronics. For example, it is crucial for designing and optimizing electronic devices, such as transistors and semiconductors. It also plays a role in the behavior of superconductors, which have many practical applications in technology and research.
  • Quantum Physics
  • Atomic and Condensed Matter
  • Quantum Physics
  • Quantum Physics
