Why don't electrons fall into the nucleus?.
In summary, the first result to this question in Google says that electrons are always partially in the nucleus. This raises questions like how single electrons can exist and how atoms exchange electrons. However, the quote says that the concept of an electron "falling into" or "entering" the nucleus does not really make sense. Instead, the electron is spread out and has no definite position.
francis20520
TL;DR Summary
Why don't electrons crash into the nucleus or fly away from it?
The first result to this question in Google gives this: "An electron in an atom spreads out according to its energy. The states with more energy are more spread out. All electron states overlap with the nucleus, so the concept of an electron "falling into" or "entering" the nucleus does not really make sense. Electrons are always partially in the nucleus " - https://wtamu.edu/~cbaird/sq/2013/08/08/why-dont-electrons-in-the-atom-enter-the-nucleus/
However as a layman this raises questions like this:
(1.) Then how come you can isolate single electrons and create an electron beam. For example, in the double slit experiment, they fire single electrons. The electron beam has only electrons. It has no nucleus. So how come isolated electrons can exist?
(2.) Atoms exchange electrons like in chemical and nuclear reactions. For example Ionic bonding is the complete transfer of valence electron(s) between atoms.
How can this happen?? Because if an electron is just an extension of a nucleus then how can electrons be exchanged between two different nuclei?
Likes Delta2
Notice that the quote said "An electron in an atom ". You create an electron beam by removing the electrons from the atom so that they no longer qualify as an electron in an atom.
The quote never claimed that an electron is just an extension of a nucleus. It merely said that an electron in an atom is partially in the nucleus. When an electron moves from one atom to another it changes which nucleus it is partially in. In a covalent bond the electron is partially in both nucleii (I believe).
Likes vanhees71 and francis20520
francis20520 said:
Summary:: Why don't electrons crash into the nucleus or fly away from it?
An electron in an atom is part of a so-called bound state. This is analogous to the planets being in bound states orbitting the Sun. At the atomic level, however, bound states are fundamentally different from planetary bound states. This is why the "mini solar system" model of the atom is not valid.
Instead, the electron may only occupy certain energy levels (this is analogous to planets being limited to certain defined orbits) - but, when the electron is in a defined bound state energy level it has no definite position. This is at the heart of QM and the uncertainty principle: if the electron has a well-defined energy, then it does not have a well-defined position.
In that sense the electron is spread out. Although, I think it is far better to say that the question of where the electron is has no meaning. It's not anywhere really.
It doesn't fall into the nucleus because that has no real meaning in QM. It's not in a orbit with a position, velocity and a trajectory. It's in an energy state with no classical analogue. This model of the atom describes how the electron behaves under the electromagnetic interaction with the nucleus.
If a photon interacts with an atom, it can give an electron enough energy to escape its bound state. It then behaves as a free electron. Although still subject to quantum uncertainty it may now behave as a free wave-packet, which is the QM equivalent of a classical particle in motion.
The process of electron capture is more complicated and involes the weak interaction between the electron and the nucleus:
https://en.wikipedia.org/wiki/Electron_capture
Likes vanhees71, francis20520, Dale and 1 other person
Electrons are quantum objects they do not have a definite position until you measure them. Because the are quantum objects they obey the Schrodinger equation.They interfere with thenlmselves.If you apply the Schrodinger equation for any chemical element according to the Born rule there is a 0% probability of finding them at the nucleus.
Likes Delta2
That is not true. There is a small probability the electron is in the nucleus. (Of order a few parts per million) But so what? Most of the time it just flies out again. Rarely it initiates a weak transition, as mentioned in post #2.
One cannot completely understand spectroscopy if this isn't taken into account.
Likes etotheipi
A case in point is the Fermi contact interaction.
Likes etotheipi
Related to Why don't electrons fall into the nucleus?.
1. Why don't electrons fall into the nucleus?
The reason electrons do not fall into the nucleus is due to their energy levels and the forces that govern their movement. Electrons are constantly moving around the nucleus in specific energy levels, and they are held in place by the electromagnetic force.
2. What prevents electrons from falling into the nucleus?
The electromagnetic force, also known as the Coulomb force, is what prevents electrons from falling into the nucleus. This force is created by the attraction between the positively charged protons in the nucleus and the negatively charged electrons.
3. How do electrons maintain their orbit around the nucleus?
Electrons maintain their orbit around the nucleus due to their angular momentum and the centrifugal force. The angular momentum of an electron is a property that determines its stability and the centrifugal force acts as a counterforce to the electromagnetic force, keeping the electron in its orbit.
4. Why do electrons not crash into the nucleus?
The reason electrons do not crash into the nucleus is due to the Heisenberg uncertainty principle. This principle states that it is impossible to know both the exact position and momentum of an electron simultaneously. This means that the electron's position is always uncertain, making it impossible for it to crash into the nucleus.
5. Can electrons ever fall into the nucleus?
No, electrons cannot fall into the nucleus. The energy levels and forces that govern their movement prevent this from happening. However, under extreme circumstances such as in nuclear reactions, electrons can be forced into the nucleus, but this is not a natural occurrence.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
