Why don't radio waves interact with magnetic fields?
In summary, electromagnetic waves such as TV, radio, and Wi-Fi are not affected by a static magnetic field from a permanent magnet. This is due to the superposition principle, which states that electromagnetic waves can travel through each other and through static fields without being influenced. There is no credible documentation or theory that explains why these waves do not interact with magnetic fields. Additionally, gravity has no effect on the interaction between electromagnetic waves and magnetic fields.
Trevor Porter
I've been told that magnetic field does not mask or influence any GHz transmissions; TV, Radio, Wi-Fi, etc. and should not pose a problem. Can someone explain why they do not interact? Credible documentation such a law or theory? Educational documentation? Thanks in advance.
Superposition principle
Electromagnetic waves travel through each other and through static fields.
Thanks for the reply, however, I'm referring to the field of a permanent magnet. Not an electromagnetic wave.
as said ...
EM interaction with an EM wave isn't any different to an EM interaction with a Magnetic field
davenn said:
radio signals ARE electromagnetic waves ;)
Correct, but a permanent magnets does not emit electromagnetic waves but rather a gravitational force due to the dipole field, from what I understand. Are electromagnetic waves affected by the magnetic field? If not, why not?
read Khashishi's and my previous post again ... they both answer you Q
and gravity has nothing to do with it ...Dave
All of those signals are EM waves. These waves simply don't interact with a static magnetic field in such a way as to be influenced by it. Note that asking why something doesn't happen is hard to answer. The simple answer is that that's just the way the laws work.
Likes Mr. Devisser
Related to Why don't radio waves interact with magnetic fields?
1. Why don't radio waves interact with magnetic fields?
Radio waves are a form of electromagnetic radiation, along with other types of waves such as visible light and X-rays. Unlike sound waves, which require a medium to travel through, electromagnetic waves can travel through a vacuum. This means that radio waves do not need a medium to interact with, and therefore do not interact with magnetic fields.
2. Can radio waves be affected by magnetic fields?
While radio waves do not directly interact with magnetic fields, they can be indirectly affected by them. This is because a changing magnetic field can create an electric field, and vice versa. This is how radio waves are created and transmitted through devices such as antennas.
3. How do radio waves travel through space without a medium?
Radio waves, like all electromagnetic waves, are made up of oscillating electric and magnetic fields. These fields can travel through a vacuum because they are self-sustaining and do not require a medium to propagate. This is why radio waves can travel through space and reach us from distant sources.
4. Do magnetic fields have any effect on radio signals?
In most cases, magnetic fields do not have a significant effect on radio signals. However, strong magnetic fields can cause interference with radio signals, especially if they are in close proximity to the source or receiver.
5. Can radio waves be blocked by magnetic fields?
No, radio waves cannot be blocked by magnetic fields. As mentioned before, radio waves do not directly interact with magnetic fields and can easily pass through them. However, other factors such as obstructions or interference can affect the strength and quality of radio signals.
18K
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
