Why don't we consider Earth's forces/movement in problems?
  • I
  • Thread starter alkaspeltzar
In summary, according to Newton's third law, every time we move or apply forces, there is a reaction. This means that activities such as walking, driving and stopping would all affect Earth in some way. However, these effects are usually ignored in physics problems because they are so small. Even if we were to include all the movements happening on Earth, they would largely cancel each other out. The effects of celestial bodies and the Earth's motion can also be ignored in most cases, as the differences they would make to the calculations are too small to matter. Thus, in most practical cases, we can simplify and ignore these factors in our physics problems.
alkaspeltzar
354
37
According to N3L, every time we move or apply forces, there is a reaction. Therefore, walking, driving and stopping would all affect Earth right?
Then why don't we have to consider that in our physics problems? Wouldn't falling down to Earth's surface mean Earth was moving towards us too, so wouldn't the force be different than if we just fell onto an immovable object?
I know Earth is big, but still it wouldn't it matter? I know this is elementary, but i has my brain questioning and wondering. So insight would be appreciated.
You could, if you want, include movement of Earth in such a problem, but it is usually ignored because it is so small.
...why don't you try calculating the acceleration and motion of the Earth for a 100kg mass dropped from 1m and see just how small?
Or, maybe, flip it over and calculate how much mass is required for a 0.1% threshold of relevance?
Likes Vanadium 50 and etotheipi
If it did matter, then you would have to take into account everything happening around the world: everyone driving, walking, jumping in all different directions.
Likes alkaspeltzar
i did a calc...based on force applied to the Earth based on force applied to 100kg block via gravity. Yeah values 10^-24 small. And given everything else, i can't see it ever even being the case. That would only happen if Earth was 100% rigid, and i was only force happening at that time.
From a non technical standpoint, that makes a lot of sense. I don't know how you would include everything. And from what i am reading, everything all over the world also happens to cancel everything out. So these effects IF ANY, can always be ignored unless we are talking about Planet size forces and such
Or, the tides caused by the orbit of the Moon. That has a measurable effect.
Likes russ_watters
Even for the moon, the barycenter (which the Earth wobbles around) is only about 1% of the distance between the Earth and moon. Still pretty small.
If you're referring to the cumulative effects of motions on Earth, note that most start and end stationary on the surface of the Earth and an awful lot even start and end in the same place. So their net effects largely even cancel themselves out.
Likes alkaspeltzar and PeroK
Why stop there? Why not include the gravitatioinal forces from all the celestial bodies in the universe? After all, they are all there, aren't they?
At some point, the decimal places where this actually occurs is so far down the line, will it matter anymore? Have you noticed the effect of the gravity from alpha centauri in your daily lives? Are you pulled to the side when a truck passes by in front of your house?
This is why I always recommend students, even at elementary schools, do "experiments". Because there is something to be said about "realistic" situations and what it means. People need to learn why reading all 12 digits off a number spewed by a calculator makes as much sense as telling someone that the distance between New York City and Chicago is 790.5`1221554538823 miles.
Zz.
Likes alkaspeltzar
Another thing to consider is how large the difference in the answer would be when taking into account all these other effects when compared to the uncertainty of your initial conditions.
So for example, to find the fall-time for a 100 kg object over a given height, you need to know the gravitational parameter(Gm) for the Earth. But our best value for this is only good to 10 significant digits. The acceleration the Earth has towards the block is 1.667e-23 of that the block has towards the Earth. Thus the uncertainty of the value for Gm is much, much larger than the difference in answers between considering the Earth's acceleration and ignoring it.
If the entire population of the Earth were all standing at a single location and jumped up together with an initial speed of 5 m/s, the Earth would acquire a recoil speed of order 10-13m/s. That's assuming an average mass of 50 kg (110 lbs) per person. The motion of the Earth is quite unperturbed by our antics.
I guess the question in my head is this:
Say i was walking (2 m/s) and collide with a wall. There is a certain force required to bring me to a stop. But if Earth was actually moving toward me prior to the collision, even if super small velocity like 10^-23, wouldn't that change the force i feel?
I wish i could put numbers to it but i start getting confused.
You hitting the Earth at 2 m/s or the Earth hitting you at 2 m/s has no difference.
Zz.
Zz.
But the Earth is moving at me too? How is that not different.
What if two equal masses collided. One at V and other at -2V. Wouldnt the magnitude of the force be different compared to both hitting at equal but opposite velocity?
The relative velocity is what matters. If one is v and the other is -2v, then the relative velocity is 3v. It is no different if you hit the Earth at 3v.
Zz.
Likes vanhees71
ZapperZ said:
790.5`1221554538823
Per Ben Affleck in "The Accountant", people making up numbers have an unconscious propensity to use 3's.
[Then too, humans have a propensity to see patterns where none exist]
  • Haha
Likes vanhees71
I used more 2's and 5's in there than I used 3's. That hypothesis has just been falsified.
Zz.
Likes russ_watters
Okay but didn't mythbusters show hitting a wall at V and hitting another car at -V were the same.
So a car at V hitting a car at -V is the same as hitting it at V, not 2V.
A +v car and a -2v car colliding would be the same as a +1.5v and a -1.5v car colliding. Which would, in turn, be the same as a +3v car hitting a parked car.
A +v car and a -2v car colliding would be the same as a +1.5v car hitting a rigid and stationary earth. Or a -1.5v rigid Earth hitting a stationary car.
Hitting a wall vs hitting another car is a completely different scenario. It is not the same scenario from a different frame
Likes jbriggs444
Okay I knew I had made a mistake. Back to my original question then, that's why Earth's movement,if any doesn't matter.
Say I am traveling at V and hit a wall. Even if Earth has some micro velocity in the other direction, such at the wall was coming at me, it would be like hitting a wall at V + (something on order of 10^-22). With everything else going on, errors in rounding, measurement, that can safely be ignored.
Correct?
Likes Dale and jbriggs444
Car on car is a different problem than car on solid wall.
Say that when a car hits a solid object at speed ##v## meters/sec, its nose is crushed back by ##x## centimeters. That means that its speed goes from ##v## to 0 in the time that it takes the car to travel distance ##x##; we can calculate the force required to do that. (Try it - it’s fun! Assume constant deceleration so the average speed of the car while it crumples and comes to a stop is ##v/2##; that will tell you how much time the collision takes, from that you can calculate the acceleration and ##F=ma## will get you home from there).
But in a car to car collision you have twice the crumple distance. Run through the same math and you will find that car on wall at closing speed ##v## is the same as car on car at closing speed ##2v##. Two cars both moving at ##v## and colliding head on is the same as hitting a parked car at ##2v## or a solid wall at ##v##
The difference between hitting a wall that is infinitely rigid and infinitely massive and hitting a wall that is infinitely rigid and attached only to a finitely massive Earth is likely on the order of 10-22.
The difference between hitting a wall that is not nailed to the foundation, to the other walls or to the ceiling and hitting a wall that is tied in -- that could range up to 50 percent.
Likes alkaspeltzar
[Edit I assume the cars are traveling towards each other at equal speeds]
The bumpers (fenders?) of both cars will ideally be at the mid point of their centres of mass at all times during the collision. So each car will be doing work on its own crumple zone as the cars come to a halt. Replace the front of one of the cars with a solid wall and there is no way that the moving car would know the difference. Its crumple zone would end up with the same amount of crumple because exactly the same work was done to dissipate its KE.
Likes jbriggs444
Related to Why don't we consider Earth's forces/movement in problems?
1. Why is Earth's movement not considered in problems?
Earth's movement is not considered in problems because the forces and movements of the Earth are constant and predictable. In most scientific problems, the focus is on understanding and analyzing changes or variations in forces and movements, rather than the constant ones. Therefore, the effects of Earth's forces and movements are often assumed to be negligible in these problems.
2. How do Earth's forces and movements affect scientific problems?
Earth's forces and movements can affect scientific problems in various ways, such as causing changes in weather patterns, influencing the motion of objects on Earth's surface, and impacting the behavior of living organisms. However, these effects are often considered separately and not as a whole, as the forces and movements of the Earth are constant and predictable.
3. Can Earth's forces and movements be ignored in all scientific problems?
No, Earth's forces and movements cannot be ignored in all scientific problems. In some cases, such as in the study of plate tectonics or climate change, the forces and movements of the Earth are the main focus of research and analysis. In these cases, they cannot be ignored and must be considered carefully in order to understand and predict their effects.
4. How do scientists account for Earth's forces and movements in their research?
Scientists account for Earth's forces and movements in their research by using mathematical models and simulations that incorporate these forces and movements. They also collect data and observations from various sources, such as satellites and ground-based sensors, to track and analyze changes in Earth's forces and movements over time.
5. What are some examples of scientific problems where Earth's forces and movements are considered?
Some examples of scientific problems where Earth's forces and movements are considered include predicting the path of hurricanes, studying the effects of tides on coastal ecosystems, and understanding the impact of Earth's rotation on the Coriolis effect. Other examples include analyzing the movement of celestial bodies in the solar system and studying the effects of Earth's orbit on climate change.
  • Science Fiction and Fantasy Media
