Why don't we feel the Earth moving?
  • Thread starter alingy1
  • Tags
    Earth
In summary, Voko says that we feel a constant acceleration upward, not downward. Gravity is the only force acting on us, and so we feel weightless.
alingy1
325
Okay, so, this is not really a homework question but it is still related to coursework.
I wonder why we don't feel that we are moving. Our velocity is constantly changing since we are going around the Earth's center. My research tells me that we can compare this situation to a car. But, in the car, the vector of velocity doesn't change orientation... Can you help me understand this?
We do not feel velocities. We feel accelerations. What is the acceleration due to the rotation of the Earth? Compare it with the acceleration due to gravity.
In the car example you should compare it to a car going around a bend with a very large diameter so that the direction of the velocity is changing. Voko suggests that you compare the centripetal acceleration we experience due to the Earth's rotation with gravitational acceleration. What fraction is it of g?
Hihi, I don't have a car and I haven't taken a ride for a long time. But, I got some new insight. If the acceleration is pulling us towards the center of the Earth, that sums up the effect of gravity. I don't understand what you mean by the fraction of g. Since our velocity vector and our acceleration vector (of a normal human being on earth) are perpendicular, the magnitude of the velocity vector doesn't change, only its orientation does. But, how come our body doesn't feel that change in orientation?EDIT: I understood that the acceleration caused by centripetal force is very small compared to g since
A=v^2/r
As already indicated, our bodies (as opposed to our visual systems) feel accelerations, not velocities or "changes in orientation". And if you are standing "upright", for example, the body feels constant acceleration "downward", which it recognizes as "normal" gravity and does not signal to us in any particular way.
Yes, we need a centripetal force to let us go around on the spinning earth. Gravity supplies this force as you rightly remarked. But it is larger than is needed for this type of motion. The required centripetal force can be calculated via
FC = mv2/R
where v is the speed with which we are going around - large at the equator and zero at the poles of the Earth and R is the radius of the circle in which we are going around, which also depends on the latitude where we are located. The speed can be calculated with
v = 2∏R/T
where T is about 24 hours so that the above formula becomes
FC = mR(2∏/T)2
We feel a constant acceleration upward, not downward. We can't feel gravity. Nothing can.
What we can feel is everything but gravitation. We feel the centripetal force that keeps us moving with a car as the car turns a corner. We feel the upward normal force from the ground whilst gravity pulls us downward.
Gravitational acceleration onboard the International Space Station is about 90% of Earth surface gravity. The reason astronauts in the ISS are called "weightless" is because that's exactly what they feel. They can't feel gravity, and since gravity is the only force acting on them, they feel weightless. What the astronauts feel is the same queasy queasy sensation many of us get when a roller coaster reaches the top of a climb and then starts dropping. Gravitational force hasn't changed one iota, and yet we feel very different. What's different is that those other forces that we can feel has changed. We are very accustomed to feeling that constant one-g upward acceleration throughout our bodies. It's the sudden lack of that ever-present feeling that makes us feel a bit queasy.
Getting back to the original question, you *do* feel the consequences of the Earth's rotation. It is part of what makes you a bit lighter (scale weight) at the equator than at the poles.
I did not say we feel gravity.
I agree that the acceleration we feel is physically upward, yet our sensory organs report the sensation as "downward", even though this might also be debated. I hope we can all agree it is "vertical".
The crux of the matter is that this variation in acceleration is only in magnitude, not in direction, and is very tiny. It is probably below the noise floor of our built-in sensors.
It's tiny, but not "very tiny". You feel a tiny bit heavier when you toss on a light jacket or when you drink two cups of water. That's about the magnitude of the effect were one to instantaneously teleport from the equator to the North Pole. The reason we don't feel it is because, sans the ability to teleport from the equator to the North Pole, it's both small and constant.
It does vary in direction with latitude. Down, as measured by the direction a plumb line points, points to the center of the Earth only at the poles and at the equator. Everywhere else, toward the center of the Earth and down are slightly different directions.
This is an interesting question. Even if the Earth was spinning 16 times faster than it is so that the centripetal acceleration to keep us on the surface was 256 x as strong as it is (about 9 m/sec^2) we would not feel the Earth moving. We would just feel a lot lighter. But we would feel no centrifugal effect as we would if we were tethered to a rotating body in space. Of course if the Earth rotated much faster, gravity would not be sufficient to keep us on the surface. We would then feel the Earth because we would be bouncing up and down a lot.
AM
I still think that our natural chaotic vibrations and oscillations, even in a state that we would consider "stationary", could result in a greater variation of perceived acceleration. Nor do I think our sensors are so sensitive to begin with. I did a back-of-an-envelope calculation yesterday, and the variation of acceleration with latitude was, I think, about 0.003 g. Perhaps not very, but still quite tiny.
Andrew, if the Earth spinned much faster, wouldn't we feel heavier? The centrifugal force would be pulling us towards the center?
Man, I love physics. Seeing the formula F=mv^2/2 popped a new question in my head. a=v^2/rHow could we calculate the maximum speed that an asteroid should have to still be in orbit around earth?
Let's consider a=9,8m/s^2 and r=7000000m. Do we simply isolate the v in the formula with the radius of the orbit?
That would not be the maximum speed. The would be the minimum speed. It is known as the first cosmic velocity. Slower than that at the given altitude, the asteroid crashes.
True. However, I don't understand how a smaller radius has a smaller minimum velocity at the same acceleration. Shouldn't that asteroid have more velocity to not crash on the planet?
Smaller radius generally means the orbit is more "curved". Greater curvature generally means greater acceleration. But you have the acceleration fixed. That can only be satisfied by slowing down.
This phenomenon is very important in driving vehicles and especially in motor racing involving turns. A vehicle has a finite amount of sideways friction. It is this sideways friction that causes a vehicle to turn. Which means there is only some max acceleration it may have in a turn, otherwise it will just skid away. Which pretty much forces any sensible driver to go slower as turns get tighter. In racing, drivers try very hard to stay just at this max acceleration, and frequently fail very spectacularly.
Awesome insight for the motor racing industry. The acceleration doesn't change much if you don't get too far from Earth no? Thank you so much all of you!
There would be no difference in the force pulling us toward the Earth - that is always GMm/r^2. The other force is the normal force. Those two forces must sum to your mass x your acceleration. The only acceleration is the centripetal acceleration: v^2/r toward the centre of the earth. So, letting the direction of gravity be [itex]-\hat{r}[/itex] (ie. opposite to the direction of the displacement vector from the centre of Earth to your position):
[tex]-\frac{mGM}{r^2}\hat{r} + \vec{N} = -\frac{mv^2}{r}\hat r[/tex]
[tex]\vec{N} = \frac{mGM}{r^2}\hat{r} - \frac{mv^2}{r}\hat r[/tex]
From that you can see that the normal force N is reduced as centripetal force increases.
AM
Hmm, why would v^2/r be the only acceleration? Isnt there the gravitational pull?
Sorry for my incompetency in understanding your equations. I'm in grade 11. But, in my head, the centrifugal force is pulling us towards earth. The gravitational pull too. So, if you combine those two, you get a bigger force. The normal force will consequently be bigger too. I did my research on yahoo and ask a scientist, and they say you are right.
Could you please explain it to me again?
You may want to memorize that "-petal" and "-fugal" are derived from Latin words which mean "to seek" and "to flee" ("-fugal" is cognate with "fugitive"), so "centripetal" is "toward the center", and "centrifugal" is "from the center".
Knowing that, you would never have said that the centrifugal force is pulling us towards Earth.
Centripetal! Sorry :)
There is only one acceleration. It's the derivative of velocity. Newton's second law describes the relation between the total force acting on some object and the acceleration of that object. The total force acting on some object is the superposition (vector sum) of all of the individual forces that act on that object.
Two corrections: Newton's law of gravitation, GMm/r^2, applies only to point masses and non-point masses with a spherical mass distribution. It's an OK representation of Earth's gravity field for low fidelity purposes. It would not apply to your hyper-rotating Earth (16x current rotation rate, one day = 90 minutes). That Earth would flatten out to such an extent that GMm/r^2 would only be valid at very, very large distances from the Earth.
The other correction is that the v^2/r centripetal acceleration points toward the Earth's rotation axis, not the center of the Earth (and the r is the distance to the rotation axis rather than to the center of the Earth).
Ok. I was assuming that the Earth's shape would not change which is obviously not true. Let's pretend Earth is a solid metal ball held together by intermolecular bonds that are much stronger than the gravitational forces.
Quite right. I was thinking of a person was standing on the equator of a spherical earth.
AM
There are two forces acting on us standing up straight. The gravitational force, F, acting towards the center of the Earth and the supporting force, S, from the surface of the earth. We will accelerate according to the resultant of these two forces according to Newton's 1st law. Since we are spinning around the axis of the Earth we know that we are should be accelerating towards the centre of the of the circle in which we are spinning (which is actually not the centre of the earth). So that means that the resultant of these two forces supplies the centripetal force giving us a centripetal acceleration towards the centre of the circle in which we are spinning.
Related to Why don't we feel the Earth moving?
1. Why don't we feel the Earth moving?
The Earth is constantly rotating and orbiting around the sun, but we do not feel this movement because it is happening at a constant and gradual pace. Our bodies are able to adjust and adapt to this motion, making it imperceptible to us.
2. How fast is the Earth moving?
The Earth rotates at a speed of about 1,000 miles per hour at the equator, and it orbits around the sun at a speed of about 67,000 miles per hour. These speeds may seem fast, but they are relatively slow compared to the vastness of space and the size of the Earth.
3. Do we ever feel the Earth moving?
There are some instances when we may feel the Earth moving, such as during earthquakes or when we are on a moving vehicle like a plane or a boat. However, these sensations are not caused by the Earth's rotation or orbit, but rather by other forces such as tectonic plates shifting or air and water currents.
4. What would happen if the Earth stopped moving?
If the Earth were to suddenly stop rotating or orbiting, it would have catastrophic effects on the planet and all living beings. The sudden stop in rotation would cause a massive shift in the Earth's atmosphere and oceans, potentially leading to extreme weather events and tsunamis. It would also disrupt the Earth's magnetic field, which protects us from harmful solar radiation.
5. How do we know the Earth is moving?
There is a lot of evidence that supports the fact that the Earth is moving. This includes observations of the stars and planets in the sky, the changing of the seasons, and the existence of time zones. Additionally, scientific instruments such as satellites and GPS systems rely on the Earth's movement for accurate measurements and navigation.
