Why dont we feel the tilt in an aeroplane?
  • Thread starter anonymoussome
  • Tags
    Tilt
In summary: They give just a minor movement in some direction, but your body thinks that you're still going in that direction until some counteracting movement occurs.In summary, the tilt of a fighter airplane does not affect the trajectory as much as you would think.
anonymoussome
59
Specially in a fighter airplane. We don't feel much of the tilt as the plane tilts or flips, even though its velocity is not too high at that time?
Because tilt normally changes trajectory aswell. Therefore you are accelerated to the bottom of the plane.
If the turn is coordinated, then you only feel a downwards force with respect to the plane. If g forces are high, you'll definiately feel that. You will also feel a sudden roll.
If the turn is uncoordinated, you'll feel an inwards force if the plane is in a slip, and an outwards force if the plane is in a skid.
The US Air Force has been looking at this for a number of years and should have a lot of info available. As an aside, that is part of what led to the fatal crash of John Kennedy Jr. Your body has two kinds of accelerometers in the inner ear - angular and linear. If the roll is slow, the angular accelerometers barely notice and it's up to the linear ones. Normally, you maintain up-down through three mechanisms: the inner ear accelerometers (vestibular system); proprioceptors in your lower extremities; and vision. In a plane, you will already have lost the proprioceptors and, if you lose or confuse vision (haze, looking sideways, looking down at instruments, etc), you can slowly roll and not be aware of it, which then leads to ground coincidence.
Edit: I forgot to mention that the linear accelerometers are not terribly sensitive as to direction.
TVP45 said:
The US Air Force has been looking at this for a number of years and should have a lot of info available. As an aside, that is part of what led to the fatal crash of John Kennedy Jr. ... you can slowly roll and not be aware of it, which then leads to ground coincidence.
Oh. So the crash was caused in essence because he went into a roll without realizing it?
This makes perfect sense to me, as someone who has occsaionally tried to play flight simulators. With such a highly restricted feedback loop (visual only) I can find myself wildly out of control before I know it.
"Ground coincidence." I like that.
Me too. I got it from an Air Force researcher who was looking into crashes. I guess they don't like negative words.
The NTSB report does not specify which movement, roll, pitch, or turn was a probable contributary factor, only that one was likely.
I like "controlled flight into terrain" for crashing and "loss of situational awareness" for not knowing which way up you are!
These terms actually have much deeper meanings than you're supposing. Controlled flight into terrain literally means the pilot flew the aircraft in a controlled, intended, and properly-executed manner, in a trajectory that just happened to intersect the ground. This sort of thing often happens in instrument meteorological conditions, when pilots have no visual contact with the ground. They fly a perfectly controlled straight-and-level path... directly into a mountain. This is an error in flight planning or instrument procedure, not an error in actually flying the plane. Contrast it with, for example, entering a spin and not being able to recover.
Situational awareness is a very broad term that includes several dozen pieces of information of which the pilot must be constantly aware. If you stop looking at your vertical speed indicator for several minutes, you are now unaware of your situation. It doesn't have to be as dire as losing track of which way is up!
- Warren
I still think people create the terms with a certain 'tongue in cheek' - we used to have 'prompt criticallity' = your research lab is now a crater + mushroom cloud.
That's also the essence of why real flight simulators are so effective. They give just a minor movement in some direction, but your body thinks that you're still going in that direction until some counteracting movement occurs.
I am a pilot, and I've actually found some of the PC-based simulators are harder to fly than a real airplane!
It's a while since I've flown a real one, unfortunately. :cry:
The only computer game that I tried (Flight Simulator?) had keyboard input. I gave up in utter disgust and frustration after about 10 minutes. I'd probably enjoy one with a yoke or stick and rudder pedals.
There have been plenty of prompt criticality accidents, and no labs have been blown up yet,
altough some people died of the radiation. The degree of criticality reached in lab accidents, or fuel reprocessing is so small that thermal explansion is enough to keep the reaction at a constant rate. People further away then a few metres will live if they immediately evacuate.
here:http://www.orau.org/ptp/Library/accidents/la-13638.pdf"
Ya man i hear ya. I never played flight simulator but i love flyin jets.
Lucky dude.
Unfortunately, I never had a chance to progress that far. I got grounded on a medical over 30 years ago. (You couldn't fly if you were diabetic back then).
I never really had much interest in jets, but I did have a particular fondness for the F5 and would like to have played with one.
Related to Why dont we feel the tilt in an aeroplane?
1. Why don't we feel the tilt in an aeroplane?
The sensation of tilt is caused by the movement of fluid in the semicircular canals of the inner ear. However, in an aeroplane, the fluid is not able to move as freely due to the stable and consistent motion of the aircraft. This results in a lack of sensation of tilt.
2. Is it safe to not feel the tilt in an aeroplane?
Yes, it is completely safe. The lack of sensation of tilt in an aeroplane is due to the design and technology of the aircraft. It is a normal and expected phenomenon during flight and does not pose any safety concerns.
3. Can we feel the tilt in a helicopter or smaller aircraft?
Yes, it is possible to feel the tilt in smaller aircraft such as helicopters. This is because they have a different design and technology that allows for more freedom of movement, resulting in a greater sensation of tilt.
4. Does the lack of tilt sensation affect our balance and coordination during a flight?
No, it does not. Our body is able to adapt and maintain balance and coordination based on other cues, such as visual and proprioceptive information. As long as the movement of the aircraft is stable and consistent, our body is able to adjust accordingly.
5. Can the tilt sensation be felt during turbulence?
Yes, during turbulence, the aircraft may experience sudden changes in its motion, causing the fluid in the inner ear to move and resulting in a sensation of tilt. However, this sensation is temporary and does not affect the overall stability of the aircraft.
  • Other Physics Topics
