Jacinta
- 22
- 12
aren't you supposed to measure weight in Newtons? And mass in kilograms/grams?
Next time you are asked, at a doctor's office or elsewhere, for your weight, you should definitely give it in Newtons.Jacinta said:aren't you supposed to measure weight in Newtons? And mass in kilograms/grams?
phinds said:Next time you are asked, at a doctor's office or elsewhere, for your weight, you should definitely give it in Newtons.
Weight is a measure of the force of gravity acting on an object. Newtons are a unit of force, not weight. The correct unit for weight is the kilogram (kg) in the metric system and the pound (lb) in the imperial system. Measuring weight in Newtons would be like measuring distance in kilograms - it's simply not the appropriate unit of measurement.
Weight is a specific type of force - it is the measure of the gravitational force acting on an object. Other types of forces include friction, tension, and normal force. While weight is always measured in Newtons, other forces can be measured in different units such as pounds or dynes.
The formula for weight is W = mg, where W is weight, m is mass, and g is the acceleration due to gravity. This formula takes into account the relationship between mass and weight - weight is directly proportional to mass, and increases as mass increases. The acceleration due to gravity is constant at 9.8 meters per second squared on Earth, but may vary on other planets or in space.
The metric system uses the kilogram as the standard unit of mass, while the imperial system uses the pound. However, both systems use the Newton as the standard unit of force, so weight is measured differently. This is because the metric system is based on the International System of Units (SI), which is a standardized system used by scientists all over the world. The imperial system, on the other hand, has historical roots and is still commonly used in the United States and some other countries.
The main advantage of using Newtons to measure weight is for scientific calculations. Since weight is a type of force, using the unit Newton allows for easier conversion between different types of forces. For example, if an object has a weight of 10 Newtons, it would also have a force of 10 Newtons if pushed or pulled. However, for everyday use, it is more practical to measure weight in units of mass such as kilograms or pounds.
