Why don't we run out of gravitational force?
In summary, gravitational force is created from the curvature in space-time by the mass of the planet. However, it does not run out because it is not a finite quantity that can be used up over time. Mass and energy are conserved, which means that gravity cannot be depleted. Additionally, consuming the mass of the planet does not affect gravity as long as one stays on the planet. Going to other planets, however, may result in mass export fees.
fredreload
250
We know gravitational force is created from the curvature in space time by the mass of the planet, but why doesn't it run out?
Why would it run out? Can you think of any reason a curvature would "run out"? If you have so please share, however if you do not then I can only advise you to revise some GR.
To bounce of off what Nosebgr said, gravity is the result of the curvature of spacetime, not some finite quantity that is used up over time. Since mass and energy curve spacetime, and both mass and energy are conserved, then it follows that gravity cannot be 'used up'.
Likes Nosebgr
fredreload said:
... by the mass of the planet, but why doesn't it run out?
Because we aren't consuming the mass of the planet.
Likes CWatters and billy_joule
I don't know about you, but I'm about to consume the mass of about a thousand christmas cookies...
As long as you don't leave the planet, it is fine.
If you go to Mars, we'll have to charge mass export fees.
Likes Drakkith
Related to Why don't we run out of gravitational force?
1. Why doesn't the Earth's gravitational force decrease as objects move further away from the surface?
The force of gravity is inversely proportional to the square of the distance between two objects. This means that as an object moves further away from the Earth's surface, the force of gravity decreases, but it never reaches zero. This is because the Earth's mass and density create a gravitational field that extends infinitely into space.
2. Does the strength of gravitational force change over time?
No, the strength of gravitational force is constant. This is because gravity is a fundamental force of nature and is determined by the mass and distance between objects. As long as these factors remain constant, the strength of gravitational force will also remain constant.
3. Why do objects with different masses fall at the same rate?
According to Newton's Law of Universal Gravitation, the force of gravity depends on the mass of both objects. However, the acceleration due to gravity, which determines how fast objects fall, only depends on the mass of the larger object. This means that all objects, regardless of their mass, will fall towards the Earth at the same rate.
4. Can gravitational force ever be cancelled out?
Gravitational force can be cancelled out by an equal and opposite force, such as when an object is in orbit around another object. However, in order for this to occur, both objects must have the same mass and be at a specific distance from each other. In most cases, gravitational force cannot be cancelled out completely.
5. Will the Earth eventually run out of gravitational force?
No, the Earth will not run out of gravitational force. As long as the Earth exists, it will continue to have mass and therefore continue to exert a gravitational force on other objects. However, the force of gravity may change over time if the mass or density of the Earth were to change significantly.
9K
