Why electromagnetic waves do not stand still?
In summary, the fields can move because there is a delay in the value of the field at a point on the path of the wave. This delay produces a variation in field with distance and that changes in time (along with the variations of the current in the antenna).
Yubal M
I know that the electromagnetic waves are alternating electric and magnetic fields. But I don't get why the fields can't stand still and alternate at the same point. Why they always move ?? I would prefer a logical and verbal answer rather than a mathematical answer. But if mathematics helps to explain the logical answer then it's fine.
Waves arise from disturbances that propagate, so they move. They can appear to be 'standing' if there are two waves moving in opposite directions. That can happen to electromagnetic waves as well as to water or sound waves.
Likes sophiecentaur
They can. You can have standing EM waves inside a cavity with reflecting walls, just like you can have standing sound waves inside a room.
That's true, but I think the OP was asking about photons.
EM waves, in the form of photons, always move at the speed of light. At the beginners level, you can't ask why; it just is. At more advanced levels, you can study wave equations and Maxwells Equations.
Similarly, you can't ask why gravity makes us fall down rather than up ; it just does.
What in the OP makes you think that he asked about photons?
Not always: http://extremelight.eps.hw.ac.uk/publications/Science-Express-slow-photons-Giovannini(2015).pdf
Yeah, I seen similar claims. Some even claim to stop a photon completely. Frankly, I don't understand them. They seem to violate QM and Maxwells Equations. The paper cited says that it applies only to transversely structured photons, whatever that means. Other papers say that they only modified phase velocity, but this paper says both phase and group velocities. I would be grateful if someone can explain how they do this without violating the laws of physics.
Photons don't provide the answer that the OP needs, I think. He seems to want a 'wave' explanation and that is in no way inferior to an explanation involving photons. Also, the same basic description applies to any kind of wave - even a Mexican Wave.
The 'movement' of a wave through space is because there is a delay in the value of the field at a point on the path of the wave, The current in an antenna changes and so does the local field but, the field thirty metres away will take 10-7 seconds to change - and so on, with increasing distance. That produces a variation in field with distance and that changes in time (along with the variations of the current in the antenna).
Yubal M said:
... I don't get why the fields can't stand still and alternate at the same point. ...
I'm not an expert like your earlier respondants, so don't rely on my ideas, but I don't understand why you say this. At least in the context of radio waves, which is what springs to my mind when someone says "electromagnetic waves", you can.
If I stand still near an oscillating tuned circuit, then I can "see" (or detect, measure, observe on an oscilloscope, etc) an alternating electric field and an alternating magnetic field. The fields oscillate at a fixed point - indeed, at any fixed point, though their strength will be lower, the further away from the source I am.
If by some magic power I were able to travel along with the radiating radio wave at the speed of light, then I think I would not observe any oscillation in the fields at all! I would see constant phase, though monotonically diminishing amplitude..If there is a constant current flowing in a wire near me, I expect to observe a constant magnetic field at my position. I also expect everyone else to observe the same constant magnetic field at their position - weaker if they are further away, stronger if they are nearer. Similarly if there is an electrically charged object.
If that current now varies periodically, as I first said, I expect to observe a varying field. And I expect everyone else to now observe a varying field.
So is your thought that they should not observe this varying field? That only I at some special position can observe it, but nowhere else can it be observed?
Or is your question more subtle, about why they can't observe the variations at the same time as I do,? Is the problem not that they see the same field as I do, but that they apparently see it later than I depending on how much further away they are?
So could you clarify a bit, what you mean by a field "standing still"? And perhaps whether you consider non-oscillating fields to be moving or standing still.Although I can't really imagine the situation you speak of, if we did have an oscillating magnetic field in some fixed region and nowhere else, would that not give rise to an electric field, just as a changing magnetic field causes an emf in a wire? And since a wire loop could be anywhere where the magnetic field passes through the closed surface defined by the wire, would not that electric field have to exist, if not everywhere, at least in places going away to an indefinite distance? So even if the oscillating field could be trapped, the electric field would inevitably escape.
And I think maybe there is a similar argument for the electric field letting a magnetic field escape (though I don't understand that one, even in my naive way!).
Adding to responses by @BvU and @jtbell ...
(with chocolate)
(with marshmallows)
(with cheese)
Neat Microwave demonstrations... (safety first!)...
I think your claim is wrong. That's precisely the kind of question Newton is assumed to ask himself. And this question led him to formulate the Gravitation concept and theory. Asking question about things looking "obvious" is the root for real breakthroughs.
Thanks a lot to ALL for their replies. I find now just one reply by 'sophiecentaur' that is somewhat on the same track of my question's intention. But I need to discuss more with 'sophiecentaur' about his reply.
Propagating waves propagate... by definition.
Standing waves stand...by definition.
Thanks for your reply.
Please let's leave antennas aside. Let's take just 1 atom in which an electron suddenly jumps to a lower orbiting level and so emits a photon (1 packet [quanta] of alternating electric and magnetic fields). There are no other currents or fields near this atom. So this emitted packet of alternating electric and magnetic (electromagnetic) fields is an independent packet of energy. As we already know, the electromagnetic waves (like the light) do not need any existence of any external electric or magnetic fields for moving in the Speed of Light. These waves move in empty space only by the virtue of their own alternating electromagnetic fields. So I am asking, why in the first place these alternating electromagnetic fields don't continue alternating at the same point ?? What makes these alternating electric and magnetic fields to displace their location with each cycle of their alternation ??
The problem with jumping right into the quantum physics of a single atom transition is where you say "suddenly jumps". What do you actually mean by that? How long does the transition take and what is actually involved? You want an explanation about 'waves' so the explanation really needs to involve waves, surely.
I was using the antenna description because it describes a wave phenomenon in terms of waves. You are wanting a wave / field phenomenon described in terms of particles. That is loaded with problems. How would you actually describe the photon in terms of waves (essential if you want it to work your way)? How big is it? Where is it? We know you can't treat a photon like a little bullet - or give it an 'extent', that's meaningful.
This is a very fuzzy area in many people's minds and it will remain fuzzy unless people accept the mutually exclusive nature of the two models. It's QM and that means it will be hard / impossible to appreciate fully.
At least, consider the wave answer (based, in my case, on RF frequencies and an antenna) and see where things fit together there. I have looked all over the place for a source that links the two models together in a satisfactory way and it isn't surprising that I can't.
You ask why the fields don't keep continue alternating after the wave has 'left'. There is no energy left to sustain that oscillation as it has radiated away, being dissipated in the Radiation Resistance.
Possibly beyond the scope of the OP question but a second quantisation approach resolves the problem ie a field mode excitation.
I hoped I was answering the question at the appropriate level. The OP was asking for an answer that could be explained in terms of waves and was trying to reconcile things that are not reconcilable without digging pretty deep - if at all. :smile:
Likes BvU
In the wave, a changing electric field causes a changing magnetic field. That changing magnetic field then causes a changing electric field. Etc. Etc. So the wave propagates.
But in a wave in free space, the two fields are in phase so where does that causal chain apply?
What ia an "energy medium"?
Are you claiming that we don't know what a wave is and there is a need for a different definition?
Thanks for trying to resolve my question. But I must say you are focusing upon various famous quantum enigmas which are not the issue of my question. It doesn't matter in my question how precisely the electromagnetic wave gets created, it doesn't matter in my question the wave-particle duality. What we know for sure, beyond any doubt, that the electromagnetic waves are alternating electric and magnetic fields in empty space (consider empty space for our simplicity). Also we know for sure that these alternating electromagnetic fields always advance and never stay at the same location (the issue of my question). It doesn't matter here their particle-type behavior in some very specific cases. I mentioned the term "Photon" just for convenience -- for to show that it's an independent and specific packet of alternating electromagnetic fields and nothing more. So there's no need to link together any models of wave and particle in my question... and so on.
So your question is basically about 'what makes any wave progress'.
I'm afraid you can't just wave your arms about and describe a "specific packet of alternating electromagnetic fields" and equate it to a photon. You can talk in terms of an EM pulse or a burst of a carrier wave because that's a classical entity. There is no way that you can take that directly into what happens when a single atom changes state. You cannot get away from those quantum enigmas if you want to use the word 'photon'.
You could say gravity defines up and down.
This needs a bit of expanding. When waves travel in both directions (back and forth and back and forth) - on a transmission line or between Etalon mirrors - the result will appear as a series of peaks and troughs of energy when a resonance is struck. But you still have moving waves and the name "standing wave" is only a word to describe what the wave pattern looks like. The Energy still goes somewhere. In fact, if there were no losses in the system, the energy in the 'cavity' (or whatever) would build up without limit. The limit to the amplitude that the pattern reaches is dependent on the amount of loss, The multiple waves (sloshing there and back, along the line) are all carrying energy which is being dissipated internally as heat or being lost by leakage to the outside. The Q of the line or cavity represents the inverse of fraction of energy lost during each cycle. It also represents a measure of how many times a wave travels back and forth before dissipating. (At least, the number of times multiplied by the number of wavelengths of the wave)
The principle is well known and quite simple and it doesn't violate QM or Maxwells Equations: https://en.wikipedia.org/wiki/Bessel_beam
And in order to keep it on-topic: Such a beam is a standing wave in its own rest frame (at least for a limited period of time).
Likes sophiecentaur
The OP appears to be asking what it is about an electromagnetic wave that allows it to propagate through empty space under its own steam. Is that not answerable?
Likes Yubal M
This thread is tagged B for beginner level. The challenge is to provide an answer at that level.
There are many physics questions that can not be answered without math and basic knowledge. In this case, the simplest answer I know it's to derive Maxwells Equations. But maybe someone more clever than I can give a beginners answer.
Precisely ! You got it almost perfectly. Kudos. I think I have phrased my original question clearly and then also repeated it in different forms very clearly in my later posts. So I don't know why some complicate my question unnecessarily. I agree that perhaps the answer to my question might be very complicated, but my question is simple. I shall just correct you a little bit and say that the main point of my question is to ask, why the EM fields (of the EM radiation) don't alternate at the same point but advance at each cycle of their alteration ??
Thanks for your input.
not without going into deep physics
you were given the simple answer way way back ... waves, by their nature, propagate
to go any deeper than that leads to some of the other answers you were given and many of those are only scratching the surface of a very complex topic
Dave
I know it's hard to read over the length of a thread before making a post but the first few posts of their thread dealt with the question quite reasonably. In post #8 I introduced the idea of delay and how that produces a wave motion. The OP didn't like the idea of introducing (classical) radio waves and their generation - because I assume he saw this as an additional problem to deal with and he/she was first in with the word 'photon'. The fact that wave motion also works the same way for mechanical and sound waves should be useful because it does not involve the dreaded photons, which are responsible for more confusion amongst 'entry level' Scientists than enlightenment.
Likes davenn
  • #31
Dave
You are defining them as waves because they propagate. I am asking why they propagate in the first place. Your answer is just turning upside down the issue without really giving any meaningful way out.
  • #32
It should be. And it appears my former response about the changing E field giving rise to a B field and vice versa is not correct. So let's try something else:
Suppose you have a charged particle oscillating up and down at some location. Let's consider when it is in the middle of its oscillation. The particle will give rise to an E field throughout space but not instantaneously - it propagates at the speed of light. So at some time later, a point, P, in space will "see" an electric field. But the particle is moving up and down so when it is, say, at the top of its motion, it will again generate an electric field moving outward at the speed of light and so at some later time the point P will experience an electric field different in magnitude from the previous one considered. So considering the continuous motion of the particle, the point P will experience an oscillating electric field. Points further out from P will also experience an oscillating field, it will just take longer for the fields to reach it.
"But I don't get why the fields can't stand still and alternate at the same point. Why they always move ??"
When you step back and look at this process, what you have is an alternating E field at each point in space with further points experiencing that at later times, i.e., they move. Etc. for the B field.
  • #33
I (the OP) did not like the idea of antennas because they do not represent correctly the issue I am asking and additionally they also complicate things. You used the antenna and its fields to explain why the EM radiation propagate. I suggested to use just one atom in empty space to discard any arbitrary influence, like that of the antenna's fields, on the EM radiation. When just one atom emits a single packet of EM radiation into empty space, there's no other fields which influence the EM radiation, but the radiation still propagates by its own virtue. This is precisely what I want to understand. The term Photon I used was just as a matter of convenience to make it in a short form to describe emission from a single atom. In my original question I used just the EM fields and waves, no photons at all. Later I used Photons just to clarify the issue in response to your first reply. No need to get too much attached to the semantics (of photon). What's important is what is meant behind the verbal semantics. I have now already explained twice what I was meaning really in using the term Photon.
  • #34
OK, in the OP you said that you can understand some math. Try this.
First, you should understand the general wave equation. It applies not only to electromagnetic fields, but to waves at sea, sound waves, or to plucking a guitar string. Important is that all waves described by the wave equation propagate (move) at some speed. They don't stand still in space or time. (Standing waves as mentioned in post #3 are simply the sum of left moving and right moving waves.)
https://en.wikipedia.org/wiki/Wave_equation#Scalar_wave_equation_in_one_space_dimension said:
##\frac{\partial ^2u}{\partial t^2}=c^2 \frac{\partial ^2u}{\partial x^2}##
which leads to the general solution
##u(x,t)=F(x-ct) + G(x+ct)##
In other words, solutions of the 1D wave equation are sums of a right traveling function F and a left traveling function G. "Traveling" means that the shape of these individual arbitrary functions with respect to x stays constant, however the functions are translated left and right with time at the speed c.
Next you should understand Maxwells Equations, see Wikipedia https://en.wikipedia.org/wiki/Maxwell's_equations#Vacuum_equations.2C_electromagnetic_waves_and_speed_of_light
where you will see that solutions of Maxwells equations are a wave equation like the one above that propagates at the speed of light c.
If this answer is too difficult for the OP, and the previous answers too simple, then we have a problem in being unable to communicate. This is a case where explanation takes more a few paragraphs from a post on an Internet forum.
If you can do basic calculus, I recommend a video course https://www.youtube.com/playlist?list=PLD07B2225BB40E582 where all this stuff is explained very simply step by step. If you really yearn to know, that is admirable. You should be willing to invest some time and effort to study the topic.
Likes davenn
  • #35
I would suggest that insisting on you own interpretation and use of a term like 'photon' is not a good start for understanding an idea that is easily dealt with in classical terms. You need to realize that the example of an antenna is much easier to cope with than your 'atom' which you haven't characterised in any way. If you don't like em waves from an antenna then go for a sound wave produced in front of a loudspeaker diaphragm. Anything, in fact, that doesn't require you to involve QM. It isn't just a matter of 'symantics'. If you want rational discussion, it's only right to stick to the Physics we know and agree on.
<h2>1. Why do electromagnetic waves travel at the speed of light?</h2><p>Electromagnetic waves are a type of energy that consists of oscillating electric and magnetic fields. These fields are self-propagating, meaning they can exist and move without the need for a medium. According to Maxwell's equations, the speed of these waves is determined by the properties of free space, which is approximately equal to the speed of light.</p><h2>2. How do electromagnetic waves differ from mechanical waves?</h2><p>Unlike mechanical waves, which require a medium to travel through, electromagnetic waves can travel through empty space. This is because they are not vibrations of particles, but rather oscillations of electric and magnetic fields. Additionally, electromagnetic waves can travel at the speed of light, while mechanical waves have much slower velocities.</p><h2>3. Why do electromagnetic waves have different frequencies and wavelengths?</h2><p>The frequency and wavelength of an electromagnetic wave are inversely proportional to each other. This means that as the frequency increases, the wavelength decreases and vice versa. The frequency and wavelength of an electromagnetic wave depend on the source of the wave and the properties of the medium it is traveling through.</p><h2>4. How do electromagnetic waves interact with matter?</h2><p>Electromagnetic waves can interact with matter in a variety of ways. When they encounter matter, they can be reflected, absorbed, or transmitted. The type of interaction depends on the properties of the material and the frequency of the wave. For example, materials that are good conductors of electricity can reflect and absorb higher frequency waves, while transparent materials allow lower frequency waves to pass through.</p><h2>5. Why do electromagnetic waves not require a medium to travel through?</h2><p>Unlike mechanical waves, which require a medium to travel through, electromagnetic waves do not require a medium because they are self-propagating. This means that the electric and magnetic fields can sustain themselves and continue to move through space without the need for particles to vibrate. This is one of the key differences between electromagnetic and mechanical waves.</p>
Related to Why electromagnetic waves do not stand still?
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
20K
