Why equal volumes of diferent gases have the same number of molecules @ STP?
In summary, the conversation discusses the concept of equal volumes of different gases having the same number of molecules at standard temperature and pressure. The ideal gas equation, PV = nRT, is used to explain how this is possible, with Avogadro's law stating that one mole of any gas contains the same number of molecules. The kinetic theory is also mentioned, providing an explanation for Avogadro's law and how temperature affects the pressure of a gas. However, modifications may need to be made at extreme temperatures and pressures.
Rashik
Hi,
A silly techiniacal, very basic but logical question. Trying to understand since long but unable to justify myself. Can u help?
Deferent gases have deferent molecular size, then how is it possible that equal volume of deferent gases have same numbers of volume at standard temperature & pressure?
We can analyze it by saying that in two different but same size container say 1 m3 (1mx1mx1m)(each), if filled with Tennis balls and filled with foot balls will be equal in numbers? Which looks bit illogical but is widely accepted in chemistry. Why?
Regards
Rashidk
Keep in mind this is for an ideal gas and applies to most gases at low pressures. The football/tennis ball analogy for different molecules is misleading. The actual space taken up by any molecule is minuscule and most of the volume is empty space. The actual volumes of the molecules are not radically different. for example the radius of Xe is 140 pm and that of N2 is 200 pm even though Xe is about 4.5 time more massive than N2.
It has been shown experimentally that PV =nRT where n is the number of moles. One mole of any gas contains the same number of molecules (Avogadro's Number), The kinetic theory shows that the product PV is proportional to the number of molecules with no reference to size.
Likes Rashik
... technically "in the limit of zero pressure and infinite temperature."
Thanks Gleem and Bystander.
I got the point.
Regards,
Rashik
this relationship is known as Avagadros law and came about (1811)before the development of the Kinetic theory .
The ideal gas equation is PV = nRT. Imagine 2 gases 1 and 2
for gas 1... P1V1 = n1RT1
for gas 2 ...P2V2 = n2RT2
For equal volumes at the same pressure P1V1 = P2V2
If they are at the same temperature the T1 = T2
therefore n1 must equal n2
Likes Rashik
Thanks Lychette.
Nice explanation. I got the point...
Avagadro's law is empirical, but kinetic theory provides an explanation for it.
Temperature tells you something about the average kinetic energy of each molecule. So you can calculate the force of each molecule hitting the wall of a chamber. Multiply this by the particle flux and you have the pressure.
Verify that you get the same pressure for equal volumes and temperature independent of the mass.
over a very wide range of temperature and pressure the Kinetic Theory agrees with experimental observations. At high pressure and low temperature modifications need to be made to the theory to confer with experimental observations.
Related to Why equal volumes of diferent gases have the same number of molecules @ STP?
1. What is STP and why is it important in understanding the equality of gas volumes?
STP stands for Standard Temperature and Pressure, and it is defined as a temperature of 0 degrees Celsius and a pressure of 1 atmosphere. It is important in understanding the equality of gas volumes because it provides a standard set of conditions for comparing the properties of different gases.
2. Why do equal volumes of different gases have the same number of molecules at STP?
This is because of Avogadro's Law, which states that equal volumes of gases at the same temperature and pressure will contain the same number of molecules. This means that at STP, the molar volume of any gas is equal to 22.4 liters, regardless of the type of gas.
3. How does the ideal gas law support the concept of equal volumes of different gases having the same number of molecules at STP?
The ideal gas law, PV=nRT, also supports this concept. At STP, the pressure (P) is 1 atmosphere, the volume (V) is 22.4 liters, and the temperature (T) is 0 degrees Celsius. When plugged into the ideal gas law, the value for n, the number of moles, is the same for all gases. This means that equal volumes of different gases at STP will have the same number of molecules.
4. Can this concept be applied to gases at conditions other than STP?
Yes, this concept can be applied to gases at any temperature and pressure, as long as they are in the same state (gas) and at the same temperature and pressure. However, it is most commonly used at STP because it provides a standard set of conditions for comparison.
5. Are there any exceptions to this concept of equal volumes of different gases having the same number of molecules at STP?
Yes, there are a few exceptions. The ideal gas law assumes that gases behave ideally, meaning that they have no intermolecular forces and occupy no volume. In reality, there are some gases, such as polar gases, that do have intermolecular forces and may deviate from ideal behavior. Additionally, some gases, such as carbon dioxide, can exist in different states (solid, liquid, gas) at STP, which may affect the number of molecules in a given volume.
