- #36
Ibix
- 14,690
Ok. But in that case ##Mg_{obj}H\neq mg_{earth}h##. So are you now retracting your claim that they are equal?rajen0201 said:conservation of momentum is not violated. refer below explanation.
The magnitudes of the forces on the objects are the same, but accelerations will not, that is because the masses are too different. Therefore, the changes in the velocity of an object will be higher than the earth.
Now introduce masses M earth, and m, the products of the mass and the change of velocity will be equal in magnitude.
MdV/dt(earth) = mdv/dt(object).
Now, we know the masses of the Earth & object do not change during the interaction.
d/dt(MV)(earth) = d/dt(mv)(object).
d/dt(P)(earth) = d/dt(p)(object). So, both Earth & oject momentum is same at every location & every time.
Also, it will be 0 on Earth surface & 0 at the highest elevations when no force is applied. In the object's return condition(due to gravity), same is also true.
